85 Fiero GT |
Bryan ![]() Newbie ![]() Joined: 25 July 2010 Location: Canada Status: Offline Points: 2 |
![]() ![]() ![]() ![]() Posted: 25 July 2010 at 4:25am |
Hello: Have a 85 Fiero GT sitting in my underground parking for the last 10 years. Does not run. Turns over, but I have pinpointed it down to a defective fuel pump. Any idea how much it is worth, need to get rid of it. Thinking it might be a good project car or for parts. Has about 125,000 Km, tires are in good shape. Typical Fiero clutch that needs replacing or worked on. -=Bryan=-
Well without seeing pics, as 10 years is a very long time for a car to sit so most likely their will be a lot more than just a fuel pump needing to be done, probably frozen brakes, seals in the motor will have dried out. Like you said it will be a good long term project car or a parts car. The low kms on it make it at least worth something, however, and please don't take this as rude, current market value to sell a non running notchback Fiero is around $300 Post up a couple pics and or also hit up Craig's list, you might find someone that is looking for an 85GT to do an engine swap into and they will buy it just for the frame and Vin number |
Capt Fiero I probably overstated sitting in the underground for 10 years, would insure it on and off, but in the last 4-5 years it has pretty much sat there collecting dust. I already found one of the calipers was seized when i tried to push it alst night. I kinda figured about $500.00,so think I will start around there. -=Bryan=- |
