  New Posts New Posts RSS Feed - MSD-6AL Does Not Power Off
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Topic: MSD-6AL Does Not Power Off
    Posted: 02 April 2010 at 2:36pm
Hi all,
My unit does not power off, is this supposed to happen?...I am draining my battery dead after 2 days just recently, just installed a new Yellow Top and Capt has my old one...I think I now know what the problem is...not just the alarm
Is it's not supposed to power off, guess I should install a kill switch to the battery?
Cheers...
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2010 at 6:10pm
I'm thinking it SHOULD power off.  Sure you're not the only one who parks his car for more than 2 days!!!
If it doesn't though...  hook the power to it through a relay.  Hook the coil of the relay to a switched power source.  There's tons right in that corner of the bay, so it'd be really easy.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2010 at 7:57pm
Thanks John...somethings not right:)
grokan View Drop Down
Post Options Post Options   Quote grokan Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2010 at 10:51pm
mine powers off
Lets get it sideways
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2010 at 11:44pm
I have the power direct to the battery as instructed and the GM harness, is yours?.
Post Options Post Options   Quote grokan Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 9:30pm
ya, Ive got mine directly wired to the battery And I'm using the Msd
GM harness adaptor
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 9:41pm
Same...does your power down?...mine doesn't, even when I disconnected the negative the status light was still on with only the positive connected...lol
Post Options Post Options   Quote grokan Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 9:51pm
I've never actually looked but I have left it for 4 days without running it
and didn't drain my battery, so I'm assuming it does
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 9:52pm
Curious...can you check next time you turn off the car, or check prior:)...thanks
Post Options Post Options   Quote grokan Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2010 at 8:10am
I will take a peek right after work
