  New Posts New Posts RSS Feed - CFM
CFM
danht View Drop Down
Post Options Post Options   Quote danht Quote  Post ReplyReply Direct Link To This Post Topic: CFM
    Posted: 06 April 2010 at 1:47pm
does any one know of a formula for figuring Cubic feet per minute using diamater of a venturi or throttle valve plate?
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2010 at 7:08am
http://www.efunda.com/formulae/fluids/venturi_flowmeter.cfm
That's through a venturi (which gets weird).
You're almost better off to just figure out the difference in flow if you want to hog out a throttle body (which has almost no venturi effect when you're looking at EFI vs. Carb).
Post Options Post Options   Quote danht Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2010 at 1:34pm
I guess that was what I was thinking. that the throttle plate is the only unchangable part, where as the body can be massaged to a larger diamater.
I have a spare intake for the duke and wanted to play with my dremmel. I havn't taken a mic to one but understand that the later duke TBI's had a larger diamater. (since the Holley TBI's for the dukes seem to be gold)
every little bit.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2010 at 1:38pm
WTF - go nuts on the thing, and turn it into a dry throttle body, then rig up an MPFI setup (which is what all the later setups are - like what's on the 2.2L in my Cavalier).
