  New Posts New Posts RSS Feed - slaves and masters
slaves and masters
marcelvdgn View Drop Down
Post Options Post Options   Quote marcelvdgn Quote  Post ReplyReply Direct Link To This Post Topic: slaves and masters
    Posted: 06 May 2010 at 2:44am
No its not a game .... or ?????? but
Whats the slave of choice on an 85 2m4 with the isuzu 5 speed
Need to get a good one or a new one
Any advise will help in regard to cost and source.
will be checking lordco tomorrow
thanks
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 7:13am
There can be...  only one...
And they're NLA from Lordco.
Give me a call though, as I just 'happen' to have what you need.  :)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 7:44am
 Yep you have no choice the only slave that will work on an Isuzu is the Isuzu Slave, and the good doctor just happens to have bought a few of them.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 12:39pm
Marcel, PM sent.
(No, I haven't got one to sell.  )
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 7:15pm
Speaking of slave cylinders, just finished doing a bleed yesterday, and after making it worse, I think I've only gotten it as stiff as what it was when it started (Not the brick wall it was when David and I installed my new clutch, sadly...)
This is the procedure listed on AllData:
  1. Fill supply tank with suitable brake fluid.
  2. Remove floor mat or any other object which may impede full travel of clutch pedal.
  3. Back out bleed screw on slave cylinder until fluid can be pumped out (approximatel 1/2 turn).
  4. Depress clutch pedal fully, then apply three short, rapid strokes.
  5. Release pressure to allow clutch pedal to return quickly to its stop.
  6. Repeat steps 2 and 3 until all air has been released from bleed screw.
  7. Close bleed screw immediately following last downward stroke of pedal when air bubbles no longer appear.
    Is that correct?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:21pm
Nope that is WAY overcomplicated.
    Park car nose up on a slanted driveway.  Flat will work, but slanted is better.
      Block both passenger side wheels
       Use the stock jack at the stock lift point to jack up car, front wheel will come up first, keep jacking until the rear wheel just starts to leave the ground.
      Open master, fill it to the brim, open slave cylinder port.
              Now for the hard part.
   Go have a beer, smoke, fake sugar, whatever.
Keep an eye on the clutch master, making sure it does not go empty.
This is what is called a gravity bleed.  It can be done with one person, in a relaxing manor.
        Let the master go down to about 1/4 full, then replace the bleeder screw and top up the master.   Gently get into the car and test the pedal, if it is firm enough, you are done, if not, give it one more round of bleeding.
             It really is much more simple than it sounds the way I typed it out, but this is the procedure I use on ALL the standard trans cars I do and it works awesome, in fact that is how I bled your car out the first time.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:35pm
I would add one step to the procedure that Dave has posted.
After opening the slave bleeder valve, grab the slave rod with vicegrips and push the slave piston in as far as you can, and wedge a piece of wood or whatever to hold it there during the gravity bleed.
When the bleed is done, close the bleeder valve and slowly allow the piston/rod to position itself back into the clutch lever on the tranny.
This extra step gets rid of air trapped in the slave itself.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 9:17pm
Normally I would agree with this Patrick, but in this case, the air bubbles should migrate to the bleeder side of the slave automatically because the car is leaned over.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 10:29pm
Sure, they "should" migrate.
When bleeding Fiero clutch hydraulics, every little bit helps!
You do it your way, I'll do it mine. And Tristan can decide for himself how he chooses to do it.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 11:45pm
GAH, CHOICES?!?! lol
Thanks for the heads up, boys. I will do that tomorrow. I don't suppose anyone has an estimate on how much DOT3 I'll need, do they?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 12:48am
Tristan, because you won't be sucking air into the system (which necessitates yet more bleeding) using the gravity bleed method, you shouldn't need a lot of fluid. Obviously you want at least enough to fully flush the system if the old fluid is cruddy.
Of course, this is also based on the assumption that your connections are tight and your seals are in acceptable condition, thus not allowing air to be drawn into the system as soon as you start using the clutch normally.
There are probably more threads at Pennock's addressing clutch hydraulic issues than any other single tech topic.
Good luck!
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 11:03am
Mad house. Thanks brothers!
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 11:17am
I should be here from 2pm till 5pm, if you wanted to stop by and I'll help you with the gravity bleed.
