Leaking Caliper |
![]() ![]() ![]() ![]() Posted: 08 September 2011 at 9:15pm |
Well, I am glad we didn't loose our brakes last Sunday Allan...I was changing tires and noticed on the front right side the wheel splattered with fluid... The bleeder valve is tight and the brake line was dry...but it was coming from this area, top of caliper. Inside where the piston is was dry...I can take pics tomorrow and post. Question, how can I test and trace where the leak is coming from?, clean the area all up, run the car and pump on the brakes? Thanks for the help all |
If that much brake fluid is missing, your master cylinder reservoir will be low.
Dawg |
It dropped but not much...pedal is softer for sure...I want to look at it tonight, what are you up to?:)...
AllanJ ![]() Senior Member ![]() Joined: 28 July 2010 Status: Offline Points: 254 |
That sucks, Brian. Hopefully you find the leak pronto and it's something simple.
Fingers crossed! |
Just got back from what I was up to...:)
Tomorrow (Sat) I'm working on my trailer so should be home most of the day. Come on over and we'll have a quick look. ps. My jack is at the storage so bring yours and if you do pop over bring my code reader, I need it. Dawg |
Was a simple fix...tightened the bleeder valve...lol I am out all day today, it's mow 8:40am, I can drop off the scanner on my way to the Lion's game, will call ya or call me:) |
Excellent news! |
Ya:)...
