Swaybar: pros & cons... |
Post Reply | Page 12> |
Car-2-Lo
Senior Post God Joined: 14 February 2007 Location: Canada Status: Offline Points: 1266 |
Topic: Swaybar: pros & cons... Posted: 10 July 2007 at 10:17am |
I have an extra front swaybar that want to install in rear.
Question: Is "The Fiero Store's" rear swaybar better than using front bar? |
beken
Admin Group Joined: 12 February 2007 Location: Canada Status: Offline Points: 1464 |
Post Options Quote Reply Posted: 10 July 2007 at 11:57am |
A few people in the club have installed rear anti-sway bars. Out of the factory, our Fieros understeer. The purpose of the rear anti-sway bar is to reduce understeer. Our Fieros are balanced such that if the (anti)swaybars on the front and back are the same stiffness (read thickness), your car will OVERSTEER....fun, but definitely not safe. Your front swaybar needs to be stiffer than your rear. Figuring out that balance is the tricky part. You might consider adding a thicker swaybar on the front of your car also. The front swaybar on the rear is mounted under the engine cradle. This will reduce ground clearance under your car. The Fierostore and other purpose built rear swaybars (I will erroneously call it swaybar to reduce the typing of 4 letters) for our Fieros are bent in such a manner as it does not reduce ground clearance as much. Anti Swaybars reduce the ability of your 4 wheel independent suspension to act independently. I say this just as a reminder. Your ride will be stiffer and not as smooth over normal road surfaces. Adding a rear swaybar reduces understeer up to the limits of your tires. You need to make sure you have good tires particularly in the rear. Finally, when adding (in particular) a rear swaybar, be careful you don't add one that might take you beyond your driving skill. It may be great fun to have stiffer handling but your car will have the ability to come back and bite you. Having said that, if you get the right balance, a rear swaybar is the best bang for the buck handling improvement you can make to your car.
Car-2-Lo
Post Options Quote Reply Posted: 10 July 2007 at 12:13pm |
WOW, beken that's to heavy for me!
Last week Clynt did install front 1" heavy duty swaybar from Fiero Store. Now I have an extra front bar, just wondering if the Fireo Store's rear bar is better than using front bar at rear. |
Post Options Quote Reply Posted: 10 July 2007 at 3:47pm |
Jon with the size of your rear tires, you could go with a very stiff rear bar and still be fine. What are your rears, 325/20/20's or something to that effect. You will have a hard time getting that car into a slide assuming you don't drive it like I do my car.
Car-2-Lo
Post Options Quote Reply Posted: 10 July 2007 at 4:26pm |
Okay which is stiffer, the Fiero Store swaybar or the extra front swaybar at rear? What would you use? I got lots of bump steer with those(325/25/20) steam rollers. |
Post Options Quote Reply Posted: 10 July 2007 at 5:03pm |
I belive the front bar will be stiffer. The Fiero store rear bar is designed to be used with a stock front bar. (so it should be softer than a stock front bar)
beken
Post Options Quote Reply Posted: 11 July 2007 at 4:23pm |
[QUOTE=Car-2-Lo]WOW, beken that's to heavy for me! Sorry. As long as the front bar is slightly stiffer than the rear, you should be safe.
Post Options Quote Reply Posted: 11 July 2007 at 6:44pm |
Ken you also have to take into account the larger front bar rule is really geared towards a front engine rear drive or front drive car. Having so much of the weight moved rearward allows the use of a move even sized bar front to back. When you take into account as well that people running larger rear tires than their front tires have more grip on the back end which helps to alleviate (sp) oversteer.
Oh Jon, one last thing, if you are going to buy a bar and want to go full boat on it, there is a really nice adjustable sway bar you can get for the Fiero. The arms are adjustable which greatly increases or decreases the effective strength of the bar. |
Car-2-Lo
Post Options Quote Reply Posted: 11 July 2007 at 10:19pm |
I just want to keep it simple, bolt on and go ( no bump steer). |
beken
Post Options Quote Reply Posted: 12 July 2007 at 2:28pm |
I was wondering if there was an adjustable bar available for the Fiero too. Thanks for the update, David.
beken
Post Options Quote Reply Posted: 12 July 2007 at 2:34pm |
I was wondering about this too. A couple of years ago, I pulled out of a street on Heritage Mountain in Coquitlam (Pt Moody?) and ran over some black ice and found my self sliding down the hill pointed the wrong direction. Just managed to pick up enough traction to avoid hitting anything. My car is totally stock and the suspension is worn and soft. So it will be the first thing worked on when I get around to doing a restore on my car. I've been thinking and researching the effects of suspension changes and still have lots to learn.
Bassman
Post Options Quote Reply Posted: 18 July 2007 at 4:54pm |
All I will add it that the rear FS bar Blair installed for me did nothing but improve my performance and feel...andn since you put the red front one John, you have to make it look pretty also and put the RED rear one also:)...lol When I get my front end work done next week, I wish I had bought the FS front...I may down the road |
Bassman
Post Options Quote Reply Posted: 18 July 2007 at 5:00pm |
John...this is for you:). I saved this as David posted it back some time ago, but heavy duty adjustable sway bar...very nice. |
Car-2-Lo
Post Options Quote Reply Posted: 19 July 2007 at 10:31am |
Thanks Brian, it's to complex for me, I'm just thinking using the spare front swaybar, painting it red and installing it on rear. (I do like your FS rear swaybar) |
Car-2-Lo
Post Options Quote Reply Posted: 14 August 2007 at 8:21pm |
This is what I ended up doing... Using an extra front swaybar (painted red) installed at rear. INSTALLED BY CLYNT |
Post Options Quote Reply Posted: 14 August 2007 at 9:46pm |
So John, how does it handle. I am assume with those large rear tires it must be great.
Bassman
Post Options Quote Reply Posted: 14 August 2007 at 10:00pm |
Look good man:)
Car-2-Lo
Post Options Quote Reply Posted: 16 August 2007 at 7:46am |
Well, I did notice with new front 1" heavy duty swaybar and now swaybar at rear, the ride feels a lot more solid and tracks nice & flat. (last year new tie rods, KYB shocks & coilovers, slowly getting there) |
beken
Post Options Quote Reply Posted: 16 August 2007 at 10:26am |
That looks very cool. Especially in red.
Car-2-Lo
Post Options Quote Reply Posted: 16 August 2007 at 10:24pm |
Thanks Ken, Dave and Brian for your info...
(Clynt for installing everything) Ken, you're the TechMan... Your technical info makes more sense to me now. Well, everybody knows me by now... It doesn't have to perform, it just has to look good, hehe John |
