FS; 1986 Fiero V8 CADILLAC 4.9PFI Seattle |
diesel_ ![]() Newbie ![]() Joined: 15 September 2013 Location: United States Status: Offline Points: 1 |
![]() ![]() ![]() ![]() Posted: 15 September 2013 at 10:45am |
![]() Hello everybody, I got this 1986 Fiero SE 2M8 with 92 Cadillac 4.9 V8 PFI and 4sp Muncie for sale! It started out as a project for a friend and after he quit on it(after year and halve and spending $10k US)it became mine! I need to sell it so, any reasonable offer will be considered! 144k miles on the car and about 100k on a Cadillac motor that has been rebuild >6k miles ago! Cadillac V8 rebuild, with; Rod and Main bearings, Tri Metal Timing gears and Chain Complete engine Gasket set Machine shop heads rebuild(Jay's Automotive Machine Shop in Everett) Delta camshaft stage 1 street, Mustang 19# Injectors, 4 hole, Distributor, Hydraulic Lifters and new Head bolts Also less than 6k miles ago: Suspension Techniques 1.7" Lowering springs KONI RACING Shocks, Rear Adjustable - 4 different settings, Add-on Rear Sway bar, Polyurethane mounting hardware, Big Brake Kit, Stage 3 clutch 9-11/16" Bronze Ceramic Disk with steel Flywheel and Pressure Plate, Engine and Tranny Mounts and Brackets, Aluminium Cradle Mount Bushings, set of 6, A-arm Bushings, Delrin, rear, serviceable, Lower front Control arm Bushings, Injection Technolugy Wireing harnes, Additional Electric Water Pump in front - Davis Craig EWP80L, Racing 4 Core Radiator, High Flow fuel pump, 20HP ECU chip, Custom Exhaust, Engine oil Cooler, Rodney Dickman Short Trow Kit , Shift Cables and Custom Shifter Toyota MR2 slave cylinder, CV axles, wheel bearings, ball joints, tie rods, interior carpet, most engine switches and sensors... Pioneer CD Deck, Fresh oils and fluids all around, Front tires 215/45/17, >3k on them, Brand new Pirelli 225/45/17 rear tires and alignment >500 miles. AC blows cold! ![]() ![]() ![]() Thanks Adam |
2M8 Cadillac 4.9 V8 PFI 4sp Muncie
Adam, I had considered buying that Fiero from Larry two years ago. If I hadn't just brought an '88 Formula up from Washington State a month ago, I might've considered making an offer on this Fiero... but that ain't happening now. Edited by Patrick |
