FS Kenwood Amp |
nightvision ![]() Newbie ![]() Joined: 22 February 2007 Location: Canada Status: Offline Points: 25 |
![]() ![]() ![]() ![]() Posted: 17 November 2008 at 11:46pm |
For Sale Kenwood Subwoofer Amp. Like new conduction.
$220.00 Specifications: Cast Aluminum Heat Sink: with Sandblast Finish Power Indicator: Blue Logo Triangle POWER RATINGS Maximum Output Power: 1000 Watts Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1 Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1 AUDIO FEATURES Class D Operation Ground Isolation Circuit Quiet Turn-On RCA Audio Inputs: Gold-Plated RCA Line Outputs: Gold-Plated Selectable Infrasonic Filter: Off/15/25Hz, 18dB per Octave Speaker Connectors: Gold-Plated, Screw-Type Speaker Level Input Terminals: Plug-Type Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave Bass Boost: Off/+12dB (90Hz) POWER SUPPLY FEATURES 1-Ohm Stable |
