  New Posts New Posts RSS Feed - 3400 Heads
3400 Heads
 Post Reply Post Reply Page  <1 456
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2010 at 3:38pm
SO, UPDATE.
No need getting big fancy brakes unless the engine can make them worthwhile, right?
So, found the filter I want to run on the modified Fiero intake, the Part RC-0981 from K&N. http://www.knfilters.com/search/product.aspx?Prod=RC-0981
Run that directly off the throttle body (Almost, I need a small bit of a spacer to run the MAF) and pull in some nice warm air for increased mileage. Should still pull in more net air than the stock system, especially when the engine starts spinning past 6000RPM. Will do a drawing tonight to see what kind of dimensions I'm looking at inside the bay, then I'll steal the infrared at work on Monday and see just how warm the air will be in that particular spot.
