  New Posts New Posts RSS Feed - 2.8 Engine
2.8 Engine
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 11:14am
Resized all the pictures in this thread to make it readable (especially for Patrick!  Figure if it was big enough to bother ME, it'd be KILLING him!  Hahaha)
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 11:50am
Much appreciated.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 11:43pm
That's going the other way around.
I was saying that:
 Al heads with tiny chambers + dished 3.1 pistons = a good 9:1 (ish)
 Iron heads with big chamber + dished 3.1 pistons = {who knows but it'll be low!}
 Or take a 2.8 block with it's flat tops, plus 3.1 Al heads and tiny chambers...  should stick you around 12:1?  More? Ha!  Who knows - never bothered to do the exact math.  But if a stock ~80cc chamber nets you around 8.9:1, a 28cc chamber has GOT to be high!
Iron Block + Alum Heads + 20cc Dished Pistons (3.4L Alum Stock) = 9.3 (with .020" worth of milling)*
Iron Block + Iron Heads + 20cc Dished pistons = 7.3 (With .020" worth of milling)
Iron Block + Alum Heads + Flat top pistons = 12.9 (With .005" worth of milling)
http://60degreev6.com/content.php/101-CR-Calc?s=692be9f95d82 4c0d0dcf013263ebd532&
*That .020" worth of milling is necessary just to get 9.3:1, and brings the pistons within .006" of the head (Which is BEGGING for trouble).
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2010 at 11:58pm
Sorry about the pics guys,ive had a @#% bit of a time posting pics here,ill
resize them to a reasonable size,when i figer out why it won't except my .JPG
file@135k,sometimes it will load ok an sometimes it won't.so i copy an paste
the last file to upload an then change the file number an then it works?i have
no idea why?-file is .JPG an under a 150k?
CFoss View Drop Down
Post Options Post Options   Quote CFoss Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 8:23am
I use a freeware program called 'pixresizer' and have had no problems.
Not sure what your issue is, but you might want to try it.
http://bluefive.pair.com/pixresizer.htm
The nice part is you can do multiple images at once.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 11:08am
Sorry about the pics guys,ive had a @#% bit of a time posting pics here...
I've posted here about the following free utility numerous times...
It has been my experience in many forums that posting images no wider than 800 pixels works best within the confines of a thread.
I use IrfanView to quickly resize my images. Works great.
And again...
IrfanView will do batch re-sizing and re-compression of numerous images.
Try it, you'll like it.
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 11:09pm
OK ive resized the pics,in hope there ok. not!-all so? will a 2.8 MPFI
ALUM heads out of an 89 Camaro.will my 2.8 iron heads bolt on that
block don't know what the pistons tops are like in there,flat or
dished.
ive tryed to up load pics?-jpg file 135k????? an resized it.so here it is?the
file ive posted that worked-MY Fiero pic page #1- is below,an above is
the pic ive tryed to post-2.8 MPFI-.what is the different here,user name
an another set of numbers an file size--Medium.jpg[/IMG] are added to
it.all so DrFiero/2010-06-17_.how that is there iam not sure.any one got
any ides,thanks
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2010 at 11:48pm
what is the different here,user name an another set of numbers an file size--Medium.jpg[/IMG] are added to it.all so DrFiero/2010-06-17_.how that is there iam not sure.any one got any ides,thanks
Did you see the top post on this page? John (Dr Fiero) re-sized all your HUGE images. That would explain why the "user name an another set of numbers" are now different.
Snow Man, save this JPG image to your hard drive and then let's see you upload it to your next post.
We need to see if you're uploading the images properly without worrying/wondering if the file itself is somehow incorrect. We know this image file is fine for uploading (as I just did it).
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2010 at 6:35pm
all right,ive copyed the AKA-cat pic to my desktop an know i will try to
re/post it!lets see18_234650_cat-smile.jpg">
an this is what happins some times. but was able to post some pics on other
post? ill figger it out,thanks
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2010 at 12:30am
Okay, we now know that it isn't necessarily the actual JPG image that's causing the problem.
When you try to upload an image from your computer to post in this forum, which icon are you clicking on? It should be the tree with the "up" arrow, the one that says Image Upload when you hover your curser over it.
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2010 at 8:51pm
Allright! this seems to work so far,but when i try to upload multiple pics it
wont work,anyhow the pic ive uploaded is the new/used eng ive got to do
the RE/RE on the dead one in my car,its a 2.8 an it was free,good price.ive
had it a cuppl of days know an have got it apart an can see that it will
work,wasnt sure if the block was the same.the crank is in good shape an i
have 10 good flat top pistons to choose from.a new set of rod bearings an
oil pump an back to gether she goes mith my iron heads,ill do a little more
than just that.
[IMG]
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:20pm
it was my file EXE,to long
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:43pm
I have no idea what you mean, but if you've got it figured out, great!
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 4:15pm
Yes I'll Delete this tomorrow.
Oh yeah?
How many months has it been now?
[EDIT] And "poof", it was gone...
