  New Posts New Posts RSS Feed - ECM
ECM
RegCharie View Drop Down
Post Options Post Options   Quote RegCharie Quote  Post ReplyReply Direct Link To This Post Topic: ECM
    Posted: 13 February 2014 at 9:08pm
Hope someone has an answer.
When I got my Fiero it was not running with a thermostat.
I put the one in that was included in the spare parts and after a short drive the "Service Engine" light came on.
I got a new thermostat and tried again, with the same result.
To check the problem I shorted the ECM's A & B termianals, turned the ignition on and the Service Engine light flashed 1 - 2  (pause) 1 - 2, which did not tell me anything.
Any suggestions?
Thanks
Reg Charie
New Fiero Owner
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2014 at 10:51pm
Originally posted by RegCharie RegCharie wrote:
When I got my Fiero it was not running with a thermostat. I put the one in that was included in the spare parts and after a short drive the "Service Engine" light came on.
If you're wondering why the "Service Engine" light came on with the thermostat(s) installed, and not without, it's probably because without a thermostat the engine never got hot enough for the ECM to go into closed loop operation.
How many times did you watch it repeat that pattern? It'll show that response three times before it shows any stored trouble codes.
Post Options Post Options   Quote RegCharie Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2014 at 9:13pm
I think I let it run 5 or so times..but there might have been a break due to me not having a solid connection on the jumper.
Reg Charie
New Fiero Owner
