Headlight motor keeps spinning? |
Claycam ![]() Member ![]() Joined: 28 August 2011 Location: Canada Status: Offline Points: 57 |
![]() ![]() ![]() ![]() Posted: 16 November 2012 at 2:11pm |
Had to disconnect the battery ั put the headlights down last night after a
ride and one of the headlight motors just kept spinning with an awful rattle- buzz. Even with the car turned off. When I put the switch into the parking lights position only, it stops. You can see why I had to disconnect the battery... Any ideas? Motor needs to be rebuilt? Electrical? Headlight switch worn? ![]() |
The entire light assembly has an ELE plug in
at the light assembly.Just unplug it at the light pod an then you can use the car.an it sounds like the motor assembly needs a rebuild.there are 4 nuts that hold the entire light pod to the body of the car. then you can remove /rebuild what you need. Looks like this when removed. Good luck ![]() ![]() |
Hey thank you for that!
