MSD-6AL Does Not Power Off |
![]() ![]() ![]() ![]() Posted: 02 April 2010 at 2:36pm |
Hi all, Is it's not supposed to power off, guess I should install a kill switch to the battery? |
I'm thinking it SHOULD power off. Sure you're not the only one who parks his car for more than 2 days!!!
If it doesn't though... hook the power to it through a relay. Hook the coil of the relay to a switched power source. There's tons right in that corner of the bay, so it'd be really easy. |
Thanks John...somethings not right:)
grokan ![]() Member ![]() ![]() Joined: 20 February 2007 Location: Canada Status: Offline Points: 88 |
mine powers off
Lets get it sideways
I have the power direct to the battery as instructed and the GM harness, is yours?.
ya, Ive got mine directly wired to the battery And I'm using the Msd
GM harness adaptor |
Same...does your power down?...mine doesn't, even when I disconnected the negative the status light was still on with only the positive connected...lol
I've never actually looked but I have left it for 4 days without running it
and didn't drain my battery, so I'm assuming it does |
Curious...can you check next time you turn off the car, or check prior:)...thanks
I will take a peek right after work
