my 86 fiero |
Page <12 |
garrym ![]() Member ![]() ![]() Joined: 09 December 2007 Location: Canada Status: Offline Points: 53 |
got the nuts of of them finally, used the air chisel and well, its now has some small cuts into it. ill replace them and whats with the bolts being a 18mm its a rare bolt to begin with, let alone 23 years of rust. time to replace some of these bolts anyways so its easier to get off next time i want to pull them apart. and funny enough i do not have a digital camera. but i can remember alot of things. its going to be easy when its time to reinstall the cradle into the car again and hook things up :) i didn't cut one wire and the new engine has the whole harness up to the computer and what not so i am excited
If you don't already know what "Copper Coat" anti size compound is, go to your parts store NOW and buy some. I have a 6 or 8oz jar of it, and have been using that same jar for nearly 3 years. I put it on EVERYTHING that goes together. My cradle bolts once you release the initial torque load on them, can be removed with your fingers. Same goes for control arm bushings, brake caliper bolts and other related parts. I even put the stuff on the long screws that hold the tail lights in place. Its a paste like stuff, kinda goes on like nail polish, comes with a brush. Remember the old rubber cement jars from school. (don't know if they still have them) But there is a brush attached to the inside of the cap, you brush it on and it simply stays put, never dries out, and works wonders. Never having another rusty bolt makes it all worth it for me when I have to take it apart in 6 months because of one to many clutch dumps, high speed pot holes or other related abusive causes. |
i willl buy some. does anyone know where i can buy some new cradle nuts? the ones for the 18mm hinge ones? i have the cradle out already but im calling it quits for a few days as im working night shifts and its hard to sleep when its sunny :)
You didn't soak 'em down overnight with PB Blaster before removing them, did you?
Alder Auto has a great selection of Metric bolts. They have a store in Port Kells on 96 and I belive another location in Aldergrove on Fraser Hwy. If you totally get stuck, I am sure I have a few of the cradle bolts and nuts herei n my bolt bucket.
i soked them down with liquid wrench for about a week and tried using air guns, pry bars and wrenches hammers and wrenches. so i used the air chisel and although there in ok shape i put some cuts in them with it so i want new bolts, maybe a diff size than 18mm since its hard to find sockets for them
I'm glad to hear that you at least tried some kind of penetrating fluid (although a lot of people swear by PB Blaster and nothing else), but it's possible because of the extensive rust you found that I suppose your cradle bolts and nuts were really stuck badly on there. Anyway, you got 'em off. That was the biggest challenge!
so an update, yesterday i managed to get the old engine off the cradle me and my friend took all the bolts and heat sheilds and what nots off in order to get to the engine bolts, without a hoist but a lot of balls we used a 2x6 and a tie down strap and wrapped it around the 2x6. picked the engine up my friend on one side me on the other, man that thing is heavy! most important thing to know always keep your work space clear because i tripped on my tool box and luckly i was able to catch myself although the engine started swinging and i lost my balance because of the mass weight and i completly was pulled over. good thing i let it down as gently as possible. for sure im renting a hoist for the day when i put it back together it was so funny. good news my clutch is pretty new! but i noticed im missing some of the bolts on the engine im pulling out. the more i discover the more i think i was sold a dud. although this new engine will be a saviour.
the exaust manifold on both sides the heads of the bolts were broken off some just sheared off and nuts were put on the ones left. im so surprised i got the thing even running, not even grounded properly and what not. but all is good. im going to vegas in 2 weeks but next weekend i hope to have it at least on the cradle and in the car. does anyone know anything about the rear breaks i know i talked to you capt about it, i think you said trans am calipers and roters were cheeper or something ? but then no ebrake? or anyone know where to get cheep brake pads my calipers are in good shape still, and the disks are alright but wouldnt mind new ones, maybe use trans am ones with fiero calipers? or something similer? |
Page <12 |
