My little Pontiac and donor |
danht ![]() Newbie ![]() ![]() Joined: 24 January 2010 Location: United States Status: Offline Points: 14 |
![]() ![]() ![]() ![]() Posted: 24 March 2010 at 12:01am |
![]() ![]() When I first got the red 85 coupe it had no headlight funtion and a clutch problem, not knowing anything about Fieros I replaced master,slave no fix. found out the pedals bend replaced that with steel and that problem fixed. decided it sat too high with the thirteen steel rims went to 14 alum replaced all rotors,calipers,shocks and struts,urathaned bushings, went with 2 in drop springs. put guage pod in. got a spoiler and proper tortion bars for rear decklid off ebay. I am hopeing this summer to remove the roof off the donar and get a sunroof in. had back surgery about five years ago and found out I can't do things as fast as when I was 20. The Duke seemed sluggish, replaced plugged cat and added GT exhaust, MSD coil, got rid of the air intake restriction added the side scoop and much more. it'll get there. |
Dan, you're allowed to post some text describing your Fiero and what you've done to it! [EDIT] That's better. Now we know a little something about it!
This is what the car looked like when I first got it. |
