WTD: Frame
Category: Buy / Sell
Forum Name: Body Panels and Related
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1009
Printed Date: 02 June 2025 at 3:49pm
Topic: WTD: Frame
Subject: WTD: Frame
Date Posted: 20 November 2008 at 11:48pm
I know it sounds odd, but the next time someone parts out a Fiero, could they keep the frame so I can haul it home and go nuts? I'd pay anything reasonable. =)
Posted By: johnking
Date Posted: 27 November 2008 at 11:46pm
if i could find a place to part my 88 out, id give you the frame
Date Posted: 28 November 2008 at 3:49pm
Sooper dooper! Time to clear out the garage, and finish my vacuum forming table... =P
Date Posted: 28 November 2008 at 8:47pm
Just beware if you use an 88 Frame, you are going to need the rare and expensive 88 Suspension parts when you go to rebuild the car.
Date Posted: 28 November 2008 at 9:16pm
Were I using it to make a kit car, I could probably play around with the frame to get another car's suspension to fit. With any luck.
Posted By: marcelvdgn
Date Posted: 28 November 2008 at 11:42pm
Vacuum forming table??????
Romeo, talk to me.
What you doing and do you need any thermoplastics to play with???
Marcel
Date Posted: 30 November 2008 at 1:20am
Well, if I clean out that bloody garage, I'll probably try making a few iteration of a 1/16 model of what I have in mind, and try it in the world's most pathetic wind-tunnel (Clear tubing on the exhaust outlet of a vacuum cleaner, with an incent in front of the model). After that, I'll see if I can find a way to make a larger table, for hoods, body panels and possibly even the dash. Then I hope to fabricate only the necessities from there on, everything else I'll try and steal from donor cars or junkyards. As for the thermoplastics, I'll probably stick to fibreglass, it's about the only stuff I've ever played with. And a vacuum forming table can be made (relatively) cheap, I'll PM you how if you want to know later. PS, does anyone know if there's such a thing as clear fibreglass?
