efi and pfi cadillac engines
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1118
Printed Date: 24 November 2024 at 2:57am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: efi and pfi cadillac engines
Posted By: gtexotic
Subject: efi and pfi cadillac engines
Date Posted: 07 January 2009 at 6:22pm
I am looking to buy a cadillac engine for my fiero and I was just wondering what exactly is the difference between the two. I have my eye on a 1992 cadillac fleetwood and im not sure if its efi or pfi. Any info would be great thanks
Date Posted: 07 January 2009 at 7:44pm
Well, I can't comment on what PFI is, unless it's port fuel injection. EFI simply stands for Electronic Fuel Injection, and essentially it means there's a few factors that affect the Air/Fuel ratio, such as throttle, air temperature, RPM, etc... Essentially, EFI is the Fuel Injection you grew up on! lol
Date Posted: 07 January 2009 at 11:21pm
Romeo wrote:
Essentially, EFI is the Fuel Injection you grew up on! lol |
Speak for yourself young fella. When I was a kid it was MFI. (Figure it out. )
Date Posted: 07 January 2009 at 11:48pm
Multi-Port, I'm assuming?
Date Posted: 08 January 2009 at 6:58am
PFI is Port Fuel Injection. It's a hybrid of MPFI (whats on a Fiero) and TBI (throttle body injection).
It uses individual injectors at each cylinder, yet uses a 'dry' throttle body (looks much like a carb, but flows air only, no fuel).
EFI simply refers to electronic fuel injection, regardless of technology (TBI, MPFI, TPI, PFI.... etc).
Posted By: gtexotic
Date Posted: 08 January 2009 at 11:48am
So the pfi engine is not anymore powerful than just the standard 4.9 just more efficient?
Date Posted: 08 January 2009 at 12:05pm
AFAIK, they were all PFI. Some had one, or two O2 sensors, that seemed to make a difference power wise.
The Alante (sp?) had a better intake.
Dave has done more research on this note, so I'll pass the torch to him.
Date Posted: 08 January 2009 at 12:39pm
Ok short answer. PFI is a type of EFI. EFI is just the blanket for all fuel injected cars. PFI is what type of EFI the car has.
All Caddy engines from the 4.1 - 4.9 used individual injectors, (one per cylinder) The allante motor was a 4.5 with a much better intake and would rev better, however had lower torque than the 4.9, its common practice if you can find Allante heads and Intake to swap it onto the 4.9 so you get the torque from the longer stroke and the much better intake and valve train. From what I understand its worth about 30hp on a 4.9.
The best 4.9 to get is the latest model you can find with dual O2 sensors. It has one O2 sensor for each bank of cylinders, which allows the computer greater control over which side of the engine needs more or less fuel trim. Due to that mod, "Fast Chips" was able to tweak the stock caddy motor to gain 20hp just from re-tunning the chip. From the factory GM set the motor up to be dead smooth, and produce as much torque as it could to haul around grandpa and grandma in a heavy Caddy. The re-tune moves the power band up richens the fuel curve and tweaks the timing.
Date Posted: 08 January 2009 at 3:03pm
I thought the Fiero used Batch Fire Fuel Injection, also known as wet carb... Hm...
Date Posted: 08 January 2009 at 3:52pm
Romeo wrote:
I thought the Fiero used Batch Fire Fuel Injection, also known as wet carb... Hm... |
The Fiero is MPFI, but happens to do batch fire (vs. Bank or Sequential injection - but that's more a programming thing than a physical layout thing).
It is a dry throttle body (the injectors are at the ports, unlike TBI which places the injectors above the throttle plates, and is thus a wet throttle body).
Date Posted: 08 January 2009 at 5:23pm
Romeo wrote:
Multi-Port, I'm assuming? |
No sir, you're not going back nearly far enough.
Date Posted: 08 January 2009 at 6:16pm
Patrick is referring to mechanical fuel injection.
Debuted on the '57 corvette for GM.
Now, before this thread goes EVEN FURTHER from the OP's question....
Date Posted: 08 January 2009 at 6:23pm
Ding, ding, ding... we've got a winner! (Great picture by the way.)
Date Posted: 08 January 2009 at 8:40pm
Hey, I was just trying to be nice, and not go back too far. Wouldn't want to hurt someone's ego now, would I?
Date Posted: 08 January 2009 at 10:10pm
Careful now, it's not like I date back to the age of steam.
What's this thread about again... John's truck?
Posted By: marcelvdgn
Date Posted: 08 January 2009 at 11:05pm
Arent you guys forgrtting the gravity fed mechnical pumped fuel injection systems such as Hilborn
Marcel
------------- Marcel 86SE V6 Auto
Date Posted: 08 January 2009 at 11:07pm
I may have a 4.9 avail from a 99 deville
ill be checking it out on monday
if anyone interested ....let me know
Date Posted: 09 January 2009 at 8:06am
4.9? You sure?
Or is it a N*?
Date Posted: 09 January 2009 at 9:34am
93 was the crossover year, some cars got the 4.9 and some got the 4.6 after 93 All caddy's were 4.6 Northstar. The Northstar is a far Superior engine, however at 10x the work and cost to install it. There are more economical choices out there.
Date Posted: 11 January 2009 at 1:29am
sorry, my mistake
it is a 1990 deville with 147k
ill let u all know condition monday evening
M
