1985 v4 Fiero D.I.S Firing order
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1140
Printed Date: 23 April 2025 at 5:29pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: 1985 v4 Fiero D.I.S Firing order
Posted By: shore_Core
Subject: 1985 v4 Fiero D.I.S Firing order
Date Posted: 28 January 2009 at 11:34am
HI. I need help !! I brought my fiero in to the shop instead of working on it myself. (first bad move) He removed the spark plug wires and forgot the firing order. I can not find any info in the firing order from the Distributorless ignition system to the plugs. The haynes manual is only for engines with a distributor and so is all online info i can find. All cap diagrams...
Date Posted: 28 January 2009 at 11:42am
Ok your 1st problem is NO 85 Fiero EVER came with DIS. GM did not start DIS in Fiero's until 87. So if you really do have DIS in an 85 it was done by someone and who knows what they did.
However here are the plug wire locations for all Fiero's.
Date Posted: 28 January 2009 at 11:44am
Thanks alot man. I was typing way to fast. I didnt notice i called it an 85 till it was posted. It is a late year 87. thanks a alot. ive been lookin for the firing order nonstop.
what manual is that. i would like to pick one up. the one i have is pretty much useless
Date Posted: 28 January 2009 at 11:54am
I'll dig up the exact edition, but its the Chilton's Manual for the Fiero. I don't think it is produced any more, however you might find an old copy on E-Bay.
Date Posted: 28 January 2009 at 6:36pm
Looks like a Chiltons. But - if you're going to keep the car, go to helminc.com and buy the REAL factory service manual. Nothing like it.
Yes they're expensive. What was this one little thing here worth to you?
