Coolant leak
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=120
Printed Date: 22 November 2024 at 12:58am
Topic: Coolant leak
Posted By: Guests
Subject: Coolant leak
Date Posted: 27 March 2007 at 12:28am
my coolant leaks i found the leak its udner the car and it coems from a type of metal pipe wat should i do ..help
Date Posted: 27 March 2007 at 11:56am
We would need more info, what metal pipe, where under the car.  There are 2 main coolant pipes that run under the car one on either side, as well as 2 smaller pipes that run near the middle of the car.  The larger pipes are nearly impossible to replace without a hoist. So if those are leaking, the most common option is to cut out the leaking section and replace it with a rubber hose, or take it to an exhaust shop that has stainless pipe and have a new section welded in.
Posted By: Guests
Date Posted: 28 March 2007 at 12:52am
its liek a long pipe under the passenger and driver side goes right across  and also the pipe that goes to the radiator in the front of the car gets really really hot is that because of the coolant?
Date Posted: 28 March 2007 at 9:47pm
At this point.  I am going to suggest you take the car to a professional qualified mechanic.
