85 fiero
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1219
Printed Date: 24 April 2025 at 1:32am
Topic: 85 fiero
Posted By: synn007
Subject: 85 fiero
Date Posted: 14 March 2009 at 6:28am
Hey my first time here and it looks like a great site with lots of helpful info on here. I dont have a fiero yet, Im looking at one and its a 85 fiero with a 2.8v6 4spd. I wanna know if you guys have any info on problem areas to look for before buying, other than the obvious tires,cosmetics and accessories.Any info would be great. THanks
Date Posted: 14 March 2009 at 11:02am
The only odd thing to check is listen for a cracked exhaust manifold.  It will sound like a tick or old sewing machine sound.  If there is a cracked exhaust.  The repair could end up being over $1000.  1 in 2 cars that need the exhaust manifold removed end up with a busted stud in the head.  When that happens the head has to come off.  Which means an entire head job on a motor.
Aside from that, you are pretty much fine.  Look for rust around the battery box, under the trunk carpet.  Give all the wheels a good shake to check for loose ball joints or bearings.  Take it for a drive and note how it shifts.  Hard to shift is OK that is usually just hyd issue.  However if it is easy to shift, but grinds into gear its more a problem with the trans and possible shot synchros.   This is more of an issue with the 5spd cars than the 4spd cars.
