Supercharger
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1239
Printed Date: 25 June 2025 at 8:11am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Supercharger
Posted By: Guests
Subject: Supercharger
Date Posted: 04 April 2009 at 1:32am
Hey im sorry if theres already a thread, i serached coudlnt find it but, i am looking to supercharge my fiero. right now its 2.8 v6 5 spd. what are my steps? lookin to spend minimal knowing itll be very costly. Please help or should i say guide me into completing these steps thnks guys:)
Date Posted: 04 April 2009 at 2:01am
Well your best bet is to talk to Tony, owner of the fierosound.com domain. He has a custom built, bored out, and tweaked to crazy levels, 3.4 supercharged V6. Its not a "Roots" blower that sits on top of the engines, (IIRC on the name of the blower) Its a Centrifugal blower, slightly larger than an A/C Compressor, and he mounted it right in that location.
I think he was able to get est 245hp out of it.
As for cost, complete start to finish I would budget at least $6000. Probably spend a good 1500-2000 for a good blower, then you need all the custom intake pipes to get the air from the passenger side over to the drivers side, where your Throttle Body i located. Then Custom Computer with Custom programing. Oh and oil or water feed lines. 2 bar map sensor, assorted vacuum check valves.
If money is no object, and you want a boosted 3.4 just simply because thats what you want. Thats cool and I wish ya the best of luck with it. If you are looking for performance getting away from the 2.8 in the Fiero's is really the best starting point. GM has made some really giant leaps ahead since the 2.8 was built. I would even think you should able to do a 3800 S1 Naturally aspirated, for less than the supercharger kit is going to cost you.
Or just go with a nice 3800SC or 4.9 V8.
Date Posted: 04 April 2009 at 6:35am
And if you really want to spend that much...
Come talk to me first (second?) and we'll strike a deal for my turbo engine.
I've got more than 6 grand into that I'm sure.
Posted By: Guests
Date Posted: 04 April 2009 at 10:54am
haha i dont really want to spend that much. Its hard especially since im a full time student and im workign only part time. Im thinkin maybe by next year i can have sum good noise under that hood. I woudlnt mind either supercharged or even turbo. Just want a nice sound under it and maybe a lil extra power. Thats y i was wondering wat would be minimal cost:) I will continue to persure this so called " mission" haha . If thers anythign else i shoudl kno please let me know. If there are sites or places where i cant find or buy the stuff let me know. THnx alot guys
Posted By: Guests
Date Posted: 05 April 2009 at 11:11pm
also. woudl it be possible to just turbo charge a stock v6 2.8, if so, where do i begin
Posted By: Bobz0r
Date Posted: 06 April 2009 at 4:44pm
http://www.design1systems.com/turbo/index-fiero.html - http://www.design1systems.com/turbo/index-fiero.html
Try there. You can read up a bit on a kit they have. I don't know anyone who's tried it, but it's a site I've stumbled upon before.
Date Posted: 12 April 2009 at 8:44pm
inder_hira wrote:
also. woudl it be possible to just turbo charge a stock v6 2.8, if so, where do i begin |
My sister's boyfriend's uncle (I kid you not, we're actually quite close) supercharged the stock 2.8L engine in his old Fiero using the Turbo from a Pontiac Firefly. It's quite small (About 6PSI) but it spools up quite quickly, and you don't have to worry about timing and knock. I'll get him to tell me how he did it, if you still plan on doing this.
Posted By: Bobz0r
Date Posted: 12 April 2009 at 9:15pm
What have you got done to that motor?
Posted By: Guests
Date Posted: 12 April 2009 at 9:26pm
how much did it run u guys Romeo? money wise..
Date Posted: 12 April 2009 at 11:49pm
Please don't put a small turbo on a 2.8. This is a grenade. Small turbo = hot air = detonation. It will spool very quickly before it blows up (Or shift at 4k rpm).
Learn about turbos first. Start here:
http://www.gnttype.org/techarea/turbo/turboflow.html
Do some calculations based on the formulae. Get an idea of what pressure ratios are etc. Read turbo efficiency maps.
Then, by all means turbo it, don't use a cent. super. Your performance will be better. Why? Cent superchargers make good boost, and good hp numbers (VERY Impressive), but take longer than an equally sized turbo to spool. You'll be waiting for boost and the turbo car will leave you in the dust.
------------- 86 SE 3.4
Date Posted: 13 April 2009 at 12:13am
This is an excerpt from my Turbo for Dummies page I wrote it a long time ago, but it will give you a good baseline to work from,
If the formating comes out funny, hop to http://www.captfiero.com/turbo.htm
Turbo's Turbo's Who's got the Turbo.
This page is a work in progress but this is what I have so far. It will give you some basic info that you may not have found on other pages.
Well if you are looking for turbo's and turbo info you have came to the right place. I am not selling anything, so if you think I am going to be giving you a turbo for your Fiero eeh don't count on it. LOL What I am going to try and show is really how easy or hard it is to turbo charge a V6 Fiero. I am going to try and show you a list of parts that just could save your motor in the long run. Everything that I am going work with will err on the side of caution. I will always try to run a little on the rich side, (rich = more gas than air) I will keep the boost levels under 10psi Especially with the stock Fiero compression ratio of between 8.5 and 8.9. Well enough chatter lets get right down to business
Parts who's got the parts. Well there are a ton of parts that you can and some that you will need to buy. Then there are some more that can be argued if you need it or not. Well getting right down to business
Fuel Injectors --Starting with the fuel system, injectors, it has been said that the stock 15# injectors when new can support 200hp with the right programming. The design one turbo kit has proven this. But if we flash to the real world here, none of us have brand new injectors in our cars. Some of them only perform as well as a new 10# injector. So we should be looking at some larger injectors. This can be a massive expense if you just run with credit card in hand down to the local tuner shop and say "Big Injectors Please" sure you could drop as much as 1000$ for a set of 6, but are we Bill Gates here. I don't think so. Well so where do we get our new injectors. FORD, yep FORD I hate to say it, but the 5.0 Mustang has created such a huge amount of buying power that you can get the Mustang injectors for Pennies on the $$ and they plug right into the Stock Fiero Fuel Rail. If you are lucky like I was, I managed to find a set of near New 19# injectors on ebay for a grand total of 28$, no I did not leave off a zero there. Some guy was upgrading his stock 19's because he had just bought the car new and was installing a supercharger so the 19's were useless to him. I believe if you were to buy this set brand new you could get it for about 300$. Well now you have injectors that will safely support up to 240hp on a 2.8 block.
Fuel Pressure -- Ok your stock regulator is set for aprx. 28lbs at idle and when your stand on it the fuel pressure rises to about 50psi. This is great and fine and dandy, but as you start to make boost, you no longer have an 50lbs of fuel pressure going to atmosphere you have 50lbs being pushed back by 10lbs. So you get 40lbs oops. That is not going to do, as you are making more power, but you fuel system is now flowing less fuel. That is the perfect recipe for lean out, and melted pistons as well as the possibility for detonation. The solution is a "Rising Rate Fuel Pressure Regulator" this is a neat little gadget that can either replace your stock regulator, or go depending on style that you buy can be hooked into your fuel return line going to your tank. As this gadget senses boost, it will block the flow of fuel to your tank from the fuel return line. When it does this, your fuel pressure will go up, this is a Very Good Thing. Now you think this is all fine and good, well it sorta is, but there is still room for the bigger injectors. So it is a good idea to keep those Ford Injectors in the back of your mind.
Pistons and Rings, hmm, well this is a debatable subject on what will and will not work.
Forged Pistons-- Obviously the best pistons are Forged Pistons, but they are also the most expensive, around 400$ for a set of 6.
Hyperutectic's-- Next in line is a set of good Hyperutectic's the only problem with hypereutectic pistons is they will crack under heavy detonation, but the plus side is that they will not burn or melt nearly as easy as a cast piston. Burning holes in pistons is a problem caused when your fuel system gets too lean, (not enough gas).
Cast Pistons-- Cast Pistons are by far the cheapest out there, and will work with a turbo motor. Many a person has done a low boost 7-10lbs of boost on cast pistons. You just have to be more careful with them and not run high boost as well as make very sure that you don't run lean.
Piston Rings-- This can get very argumentative. I personally have heard really good things and really bad things about the new Gap-less rings when used in turbo applications, so I can not recommend them or tell you to stay away from them. The rings I do know about are the Chrome-Moly rings and the Cast Rings.
Chrome-Molly are very hard, and when seated in your cylinder walls should not wear out EVER. In most cases you will end up wearing your motor out before you wear out the rings. These should give you a good safe guard against cracking a ring when running boost or even Nitrous. (more to come on that later)
Cast Rings again it is kinda the same boat as the cast pistons, they can be used, they will work, but if your motor has more than 100,000 miles on it, it is a good bet that your stock cast rings are wearing a bit thin and you might want to consider replacing them before you toss all your money into a turbo kit. If you don't you might end up with a 3000$ Fiero a 1000$ turbo and a 10$ blown motor that smokes like Mt. St. Helens.
Rockers-- Well the rockers are the things on top of the heads that change the cam shaft lobe motion into the valve motion. So for every time the piston moves up and down each rocker has to open and close a valve for that cylinder. The stamped steel stock rockers are all well and good, but if you plan to run your motor hard a set of 1.52 roller or roller tip rockers will save you a ton of grief in the long run. The roller tip rockers reduce the lateral friction on the valve guides this reduces wear and will keep your motor smoke free for a much longer time than the stock steel rockers. This is especially true with high revving turbo motor's.
Ignition System Oooh Spark's. HeHe.
Well your stock ignition if it is in like new shape will work, but it is recommended against it. There are several manufacturers of good aftermarket ignition systems, but I am a fan of the tried and true MSD series. I personally use the MSD 6A ignition box that hooks right to your Battery, it is triggered by your stock wiring to fire an MSD Blaster II coil that sends the juice out to your cap and rotor and on to your spark plug wires, Via MSD Superconductor Wires, out to Plain DELCO STEEL CORE PLUGS. This is what MSD recommends is the steel core plugs the regular ones you buy not some fancy platinum or other funny plug. I am considering giving the AC Delco Rapid Fire Plugs a shot though.
Intake and Exhaust. Now comes some more arguable stuff. When you "boost a motor" you are no longer trying to just let the air flow in and flow out. Your are cramming it down its little throat, and when it is burnt your are shoving it out like wild fire. Headers and bigger intake manifolds and porting is still of value but not nearly as important now.
Engine Electronics
ECM the good news is the stock ECM will work. Any and all Fiero ECM's will work. If you choose to go with the Stock ECM your best bet is to find an 85ECM as it is modifiable to work exceptionally well with a turbo. The only confirmed details I have are the fuel mapping on the 85 V6 is different (better) and the prom chip and be changed to work with a knock sensor)
Map Sensor. The stock MAP (Manifold Absolute Pressure) only reads 1 atmosphere negative that means it can read 14.7 pounds of vacuum but it can not read boost. A 2-Bar map can read + or - 14.7 pounds of Vacuum up to 14.7 pounds of boost. Unless you are building a full blow race motor and are shooting for over 15lbs of boost you will only need to buy a 2 bar not a 3 bar.
Ignition Timing Controls. MSD makes a neat unit that plugs into a vacuum source on your motor and can pick on boost conditions and retard your timing as boost increases. This is a really good thing as detonation is the leading cause of engine failure in almost any performance application. You can also get knock sensors these neat little guys screw into your engine block (the 2.8 already has the mounting boss for it) and listen to your motor, yes it can hear what is going on in your motor. When they hear detonation it starts retarding your timing. The nice thing about knock sensors is that you set your timing up at the most advance you would ever want to run. Then when you put say 100 oct.. race gas in your car it will allow the timing to be advanced on its own, but when you put say the cheap gas in your car it will retard the timing so it can save your motor.
The Boost Gauge, yes you will NEED a boost gauge, this will mounted in your car someplace within easy view. This will monitor how much pressure is in your intake when you first get this in your car, it will be hard to keep your eyes off of it. As you will be so proud to see your engine making boost. Aside from the huge grin on your face as you are sucked into your seat as the gauge reads higher and higher boost levels.
Air Fuel Meter, ah the never ending challenge to keep your motor from leaning out. This little doo-hicky plugs into your O2 sensor or can be hooked to a second O2 sensor that can be welded into your down-pipe. Generally they have a series of LED's (light emitting diode's) in 3 colours Red for too lean, yellow for getting a little lean, green for just right, and last one for too much fuel. Priced at around 100$ they are nice to have but are not needed. However I like lots of bells and whistles especially ones that show me what my motor is doing.
The Turbo---, Ok now for the biggie, you have all the stuff that you think you will need to have for this beast, it is time to start looking for a suitable turbo. Now this is where I get stuck myself, not being a turbo freak until about 6 months ago this is what I have learned so far. The turbo's on the dodge Daytona 2.2 and the turbo's on the Ford Thunderbird's are T3 turbo's and they are almost perfect for our applications. They are small enough that they will spool up at a relatively low rpm and begin creating boost at or near 2000rpms. The draw back is that they will run out of oomph at around 6000-6500 rpms. Don't worry if you are using a stock motor and stock fuel system this will be more than enough for a 2.8. If you have a modified motor you can still run this very well, and should be happy with it. The kicker to this is that there is a common swap with the T3 and that they take the compressor housing and exhaust housing apart, the compressor side is machined a bit and a larger compressor is installed, this allows the turbo to push a lot more air when the exhaust side is spinning at the same speed. This is called a (you guessed it) T3/T4 hybrid. A T3/T4 can be used to make up to 400hp, Just don't think your stock motor will do it. There are literally hundreds of variations of turbo's on the market today, ranging from Water Cooled, Oil Cooled, Oil and Water cooled. Ceramic bearing turbo's, ball bearing turbo's and the list can go on and on. I am looking into the Oil Cooled style myself. I understand that the water cooled is better but for cost purposes it will be an oil cooled unit. Prices can range anywhere from 20$ for a bone yard turbo up to as much as your wallet will allow. I have seen them for over 2000$ for a single turbo unit. You can count on spending around 100$ for a good used one or about 500$ for a new entry level model. Don't take this as the "die hard numbers" as I am new to this turbo thing myself. One thing that is nice about using a T3 turbo is there are lots of them out there, so the price is usually decent and you can find upgrade parts for less than some of the more exotic kits out there.
Getting Oil or water to the Turbo, as I know nothing about water cooled turbo's I am going to be talking about oil cooled turbo's. This was one thing that scared the heck out of me at first when looking into the designs of turbo's and Ya know what, it shouldn't. Why because as always the most confusing questions generally have the simplest answers. I have some pics of this that I will post someplace on this site. 1st you need to get your oil from someplace. That someplace is your oil pressure sending unit location, you use a T-fitting that runs splits off, one side goes to your turbo and the other side goes to your Oil Pressure sending unit. Ok that makes that easy, till you realize that all the oil is going into your turbo and on to your floor. Oops, quick hurry get the bucket. No No I am just kidding. The oil return line coming out of your turbo goes into your oil pan. You must punch a small hole in your oil pan and have a "bung" (bolt) welded onto your pan, that so that the oil coming out of your turbo goes back into the pan. The alternate source for oil is with a remote mount oil filter and you would get your pressure feed for the turbo from the oil filters exit side. This would give you cleaner oil and slightly cooler oil as it is no longer bolted to the block and has a chance to cool slightly in the filter. Especially if you use a filter cooler (filter cooler, is a large heat sink with fins that wrap around your stock filter and held in place with a large hose clamp) They do not do a whole lot, but it has been proven that they do reduce oil temps slightly.
Air Pressure its got to get into your motor somehow. Well most people use either stainless or aluminum tubing to duct the air from the turbo into the motor, this is a relatively straight forward thing. I am not to familiar with how the bends are set up or if you can get rubber or poly elbows to correct the problem of tight spaces.
Intercooler-- An Intercooler will always help a turbo motor, but the question is do we need one considering we will be running under 10psi. For whatever reason 10psi seems to be the magic number for an Intercooler to be used. I am sorta looking into using one on my car, but with the already awesome cold air intake that we have and the relatively low boost I plan to run it should not be a problem. I have seen intercoolers that were the size of a shoe box, and had the inlet and outlets in almost the perfect locations for us to use on our cars.
Exhaust Y-Pipe-- Ok here is some more things that are odd, well, from what I understand having the turbo as close to the exhaust manifolds as possible is your best bet, but with the Fiero 4 and 5spd cars, that is not always possible as the shifter linkage seems to plop right down between the 2. I have seen a couple of different ways to mount it, the best being near the cruise control location. It does make for the distance of the rear manifold to be much longer than the distance of the front manifold, but I think that will be alright. I have seen the easiest way to do this seems to be to go to your local "BIG CHAIN" auto parts stores and buy some raw exhaust tubing in different sizes and bends then go back to your car and play tetras for a little bit until you get an idea of what design your new Y-Pipe is going to take, then you take you design to the local exhaust shop and explain what you want and how you want it routed and weld it all up and probably even show you a thing or 2 that you may not see. Like the way your EGR should be mounted and such. There are several different designs of y-pipes ranging from ones that will bolt a turbo right into your stock exhaust system right up to ultra high end ones that require a totally new exhaust system.
Date Posted: 13 April 2009 at 6:38am
Bobz0r wrote:
What have you got done to that motor? |
I went nuts on it.
Everything is ported & port matched, fat injectors, balanced to 7K (at 6 grand that engine feels like a stocker at 4500), gapless rings, one off custom cam, custom pistons, roller rockers... then all the turbo gear (started off as a KFG setup), regulators, ignition, bla bla....
Posted By: bill
Date Posted: 15 April 2009 at 1:32pm
Dr.Fiero wrote:
Everything is ported & port matched, fat injectors, balanced to 7K |
Sorry, I don't get that. Engines are not balanced to any particular RPM, they are balanced to within a certain weight tolerance - often somewhere between 1 gm. for street and 1/10 gm on a race engine.
As the cast iron heads don't flow enough to be making useful power up at 7000 anyway, I don't understand what you meant by that description.
Did you simply do the usual porting and matching on all the manifolds, and the heads?
------------- 1988 3.2 turbo Fiero
1957 3.4 in Jamaican MG
2009 2.0 Pontiac GXP coupe
Date Posted: 15 April 2009 at 6:04pm
| Funny you say that, because we had absolutely no problems to speak of after doing it, and that was even running stock pistons/cams/bore and all. And that last statement isn't completely true. A large Turbo will not spool up as quickly as a Centrifegal Supercharger, but will produce more peak power and doesn't suffer parasitic power-loss at low RPM. And a Positive-Displacement Supercharger spools up nearly-instantly, and has no parasitic loss, yet doesn't produce big peak power numbers. Both foms of Supercharging are harder to work with, as they're application specific, and significantly more expensive than Turbocharging.
Now, if you want to run a good peak set-up while eliminating spool-up, your only real option is a dual-turbo set-up or a twin-charger set-up (A PD Supercharger and a Tubocharger). Twin-charging is difficult to do from what I've read, which is why running a pair of Turbochargers is more common. A basic rule of thumb, according to Honeywell-Garrett, is two 10psi Turbos will spool up in 75% of the time a single 20psi Turbo will, and four 5psi Turbos will spool up 75% as fast as the two 10psi ones. Simply put, if you want to run big-boost while eliminating Turbo-lag, four 5psi Turbos will hit peak boost almost twice as fast as a single 20psi unit will.
Date Posted: 15 April 2009 at 6:05pm
Perhaps balanced safely up to 7000RPM? Don't know, just tossing ideas.
Date Posted: 15 April 2009 at 7:07pm
Thats what I also thought. When I had my first "performance" 2.9 built. The machinist was also a friend of mine, he asked me just how nuts I wanted to go. I said I needed it to safely rev to 7000rpms, we went with 0.030 over lightweight Hyperutectic pistons to reduce some of the rotating mass, then he balanced the entire assembly. We specked out a very specific set of lifters and a cam that we felt would suit the motor. I honestly don't know remember what the exact weights were, but after all the porting was done and the big cam and ported exhaust, it was smooth as silk. It still did not make any more power over 6000rpms, as I still had the stock intake, but I would run 1st gear out that extra 1000rpms, so when I grabbed 2nd I was right in the power range of the motor, then 2nd would go to 6500 and 3rd depending on the situation would be 6000rpms if I was done accelerating, or 6500 if I needed the extra RPM to grab 4th into the power range for a Wide Open Run. Only bad thing was my choice in pistons was GREAT and Awesome for Daily Driver Street Use, however I added Nitrous to the car, and one night on the way home from the race track, I still had the Nitrous hooked up and live and I wanted to see just how fast my car could go. I came onto the highway at 264, ran the 1st 2 gears on motor, hit 3rd and pushed the button, the Nitrous overcomes the weak intake, so I ran it to 6800 or so, grabbed 4th and held it Wide Open. I think I was damn near at the 232nd exit before I lifted. Only reason I lifted was I was out of usable RPM with a 3.65 4spd. I was in 4th just over 6000 and car just wouldn't pull anymore. The weak 180kph speedo was well off the scale. I have no way to justify it, nore prove it. However if my math is correct, and I do know that the tach was correct on that car, I was just north of 150mph. (240kph). The funny thing is, I drove the car the rest of the way home, didn't notice anything wrong. It felt fine, until the engine had cooled down and I went to re-start it the next morning. I had torn chunks of the #1 piston away, shattered the compression ring on that cylinder, melted the rings into chunks of debree on the remaining 5 cylinders. Put .120 gouges in the cylinder walls on the #1 cylinder. If I can find the pics of the aftermath I'll post em up. The good Dr, helped me tear the motor down in his shop, we were both amazed that the car made it to my place, let alone the fact that I drove it to his place to pull the motor.
If I didn't use the nitrous on that motor, I am betting I would still have it in use today. I would have installed the Truelo system on it, as to date I think that is the single greatest mod you can do to a 2.8 or 2.9 or 3.1 or 3.2 or 3.4 Fiero.
Date Posted: 13 January 2010 at 1:48pm
Truelo? What is Truelo?
Date Posted: 13 January 2010 at 1:59pm
Romeo wrote:
What is Truelo? |
Expensive.
http://www.trueleo.com/Fierointake.htm - http://www.trueleo.com/Fierointake.htm
Date Posted: 13 January 2010 at 2:00pm
Truelo is the ONLY bolt on kit that can go on any Fiero V6 and add extra power,
http://www.trueleo.com/Fierointake.htm - http://www.trueleo.com/Fierointake.htm The entire kit includes, intake, exhaust headers, exhaust Y pipe and custom chip.
Date Posted: 13 January 2010 at 2:01pm
LOL, the Dr. beat me to it. But ya, read over the site, then do some searching on Pennocks for lots of non bias user testimonials.
Date Posted: 13 January 2010 at 3:07pm
Oh, jinkies. Funny, I have a report due on Friday about things I could do to make my engine more efficient. Thank you Truleo.
Posted By: specialk53
Date Posted: 15 June 2011 at 5:09pm
I was just wondering if you ever bought a supercharger for your car?
