Brake upgrade.
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1284
Printed Date: 28 November 2024 at 12:49am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Brake upgrade.
Subject: Brake upgrade.
Date Posted: 02 May 2009 at 10:05pm
Hey, I was wondering a few things about big brake upgrades. I had been looking at the West Coast Fiero brake section ( http://www.westcoastfiero.com/brakes/brakes_12.html - http://www.westcoastfiero.com/brakes/brakes_12.html ), specifically the bottom set. They're twelve inches, and I was wondering how that would affect daily drivability. Secondly, they're $440, when the others are all over $1000, is there a reason why anyone can figure out? Lastly, how much does it cost to replace the standard, weak-brakes (Rotors and pads) the Fiero ships with. Any answers would be greatly appreciated, as my Fiero is in dire need of new brakes soon.
Date Posted: 02 May 2009 at 10:09pm
Look at what they each include.
The last set is just 4 rotors, and 4 adapter plates. You recycle your calipers etc.
Look into the Lebaron setup too.
Date Posted: 02 May 2009 at 10:54pm
My calipers are still in tip top shape (Surprisingly) so apart from that, is it much more expensive than a standard new rotors/new pads set-up?
And sorry, I'm a bit of a noob (And by a bit, I mean completely): What's the LeBaron set-up?
Date Posted: 03 May 2009 at 6:43am
Just go and grab this - problem solved. Although the add is a bit misleading, the stock Fiero brakes are 9.75" all around. What he is selling is a very nice complete brake kit, and I know the seller. Its a fair price for what he is offering.
http://vancouver.en.craigslist.ca/pts/1132259541.html - http://vancouver.en.craigslist.ca/pts/1132259541.html
Date Posted: 03 May 2009 at 8:14am
Thats a great deal:)
------------- Brian (Bassman)
Posted By: Bobz0r
Date Posted: 03 May 2009 at 9:59am
Hmmm, sounds good. I know I need to do a good overhaul on my brakes anyways. Maybe it'll be a nice pick up.
Date Posted: 03 May 2009 at 11:13am
If you do give him a call (whichever of you), make sure you mention you're a WCF member and that you saw the ad on the forum.
FYI - this is the brake kit that I mentioned at the last meeting.
Date Posted: 04 May 2009 at 6:17am
Bidding war, FTW. =)
Date Posted: 04 May 2009 at 7:17am
He does have all the parts pretty much listed, sure you can purchase most local...
Date Posted: 04 May 2009 at 4:45pm
Question is, how much would it cost to do so? I'm on a student's budget, so I can't go completely nuts on the job (Or else I'd run 13's all around, with two piece rotors).
Date Posted: 04 May 2009 at 8:07pm
Unfortunately, you can't just go out and buy that conversion, as you need very specific parts like the brackets. The only "cheap" brake upgrade that can be done is the Grand Am conversion, however you lose your parking brake.
I recommend against doing front only Grand Am conversions as you will end up with really bad lock up on the fronts before the rears are doing anything. Want to get an idea, na I won't recommend this, but imagine if you were to use vise grips on your rear brake lines, take your car out to say 80kph and try to stop in the rain, darn near impossible to do with any short distance in mind.
Date Posted: 04 May 2009 at 8:20pm
Yeah, I don't want the vehicle to be dangerous, that's for sure. I think I'll probably go with this one, I'm just trying to juggle finances, I've got schooling to pay for, and I have to travel to get to my sister's wedding which doesn't leave a whole lot of funds left over for a brake overhaul. Then again, I'd also rather not completely annihilate my vehicle due to postponing brake repairs for too long either. Bit of a lose-lose situation.
Date Posted: 04 May 2009 at 8:47pm
That's what I have David, you helped me install...lol, and I race...certainly dependent on the driver
Date Posted: 04 May 2009 at 10:09pm
Well I'm certainly no expert driver either (As I'm sure both David and Austin can now attest to!) so perhaps I should scrounge my pennies in the mean time, and hope I have enough to float for the brakes.
Date Posted: 05 May 2009 at 8:34am
Bassman wrote:
That's what I have David, you helped me install...lol, and I race...certainly dependent on the driver |
Brian your situation is kinda the odd man out, you and your car are setup with race tires and racing in your blood. Your front tires are sticky enough that that won't lock until you are really hard on the brakes, and by that time the rear calipers are finally doing something. I'll bet you do still end up with one front wheel locking up before the rears do though. In my 85GT with stock type front brakes and good pads with grand am rear brakes and moderate pads, when I hammer the brakes, All 4 lock up at the same time. Under moderate braking situations, I feel the rears start to grab before the fronts, its like someone dropped an anchor out the back of the car. I personally prefer a slight rear bias to the brakes, I always run a larger rear tire and usually have removed any extra weight in the front of the car, so I want the rears to be working quicker than the fronts. When I do the front Grand Am's I'll be removing the spring in the proportioning valve completely.
Date Posted: 05 May 2009 at 8:54am
I hear ya:)...wish there was an economical way to do the rears and not loose the e-brake...if one does not drive on the edge you would be alright:)
Date Posted: 05 May 2009 at 5:45pm
Someone must have picked out those brakes already, that Tim fellow phoned me back today to say they were gone already. Any other ideas guys?
Date Posted: 05 May 2009 at 6:27pm
I would track down Austin he was working on a Cadillac brake conversion that is very similar to the brake setup that Tim was selling. May have very well used the same callipers and rotors, just have to locate the brackets from someone on Pennocks.
Edit for Spelling
Date Posted: 06 May 2009 at 3:18pm
The same Austin who went on the run with us? Auto-Cross-Austin?
How would one go about contacting him?
Date Posted: 06 May 2009 at 3:34pm
Yep same guy, just pop over to the member list and send a PM to Austin. Racing, Autocross, Austin.
Date Posted: 10 May 2009 at 12:55am
No word on Austin yet, and as Patrick saw, I've barely got anything left for brakes... Hopefully he'll be at the tech session.
Date Posted: 10 May 2009 at 1:07am
If your rotors get any more worn, you'll be having to drag your left foot out the door to slow down!
Date Posted: 10 May 2009 at 4:50pm
I'll just use-engine braking down to first gear, then throw it into fourth so it stalls.
Although I'd much prefer not to get to that point, of course. lol
Date Posted: 11 May 2009 at 3:46pm
Romeo if it gets that bad, that you are in danger of destroying parts due to lack of pads. Arrange a time to come by here, we can go through my garage and then zip down to the storage locker, I am sure I have a bunch of stock brake parts. It'll be no charge thing as I still kinda feel bad about how that lower ball joint turned out. I don't do much with the stock brakes anymore as I already have Grand Am rear on my Fiero 87, Lisa has Grand Am / Corvette Front on her Fiero and I'll be doing Grand Am Front on my 87 shortly after it hits the road.
Date Posted: 11 May 2009 at 11:31pm
Nah, don't feel bad about the lower ball joint, it was an honest mistake. And are you sure you'd be willing to part with those things? I don't think you understand the severity of the situation: All four corners and nearly gone, calipers, rotors and pads. lol
Posted By: Austin
Date Posted: 12 May 2009 at 9:46am
Ooops sorry been really busy lately, trying to catch up on replying to all the new posts. Good to see the club is getting really active again!
Anyway I've got a shopping list with part #'s for doing the 11.25" 'Lebaron' brake upgrade. I'm going to have to start looking seriously into it soon as my pads are starting to get thin as well. I've currently got the GrandAms on the fronts only which definately are a worthwhile upgrade from the stock solid non-vented rotors. They stood up to the test of Mission roadcourse well enough. The stock solid rotors definately don't cut it as I found out a couple years ago. I still managed to get the stock non-vented rear brakes smoking though lol.
I started to collect a few parts like caliper cores for the 11.25" upgrade but that's about as far as I've gotten so far. Once you've got the part #'s it's just a matter of going shopping and you'll also need the adaptor brackets. I've got the CAD drawings of them as well that you could take to a machine shop to have made or you might be able to find someone on Pennocks that still makes them.
I could email or if you use MSN add me mailto:Austin_sod@hotmail.com - Austin_sod@hotmail.com
Aus
Date Posted: 12 May 2009 at 3:41pm
Romeo wrote:
Nah, don't feel bad about the lower ball joint, it was an honest mistake. And are you sure you'd be willing to part with those things? I don't think you understand the severity of the situation: All four corners and nearly gone, calipers, rotors and pads. lol |
Well let me know when you want to come out, and we'll see what we can do.
Date Posted: 12 May 2009 at 7:09pm
Austin wrote:
Anyway I've got a shopping list with part #'s for doing the 11.25" 'Lebaron' brake upgrade... |
Austin, is http://myfiero.oceanmoon.com/?p=475 - This what you guys are talking about?
Date Posted: 12 May 2009 at 11:34pm
Aus
Hey, I could totally use those CAD drawings, my old highschool has a 3D cutter which cuts from CAD and RHINO drawings. That's some small way I can help I suppose. =)
Date Posted: 13 May 2009 at 12:26am
Romeo wrote:
Hey, I could totally use those CAD drawings, my old highschool has a 3D cutter which cuts from CAD and RHINO drawings. That's some small way I can help I suppose. =) |
Romeo, I don't know yet whether what I found is what these guys are talking about, but if it is, have a look at the bottom of the link in my last post.
Posted By: Austin
Date Posted: 13 May 2009 at 1:48am
Yeah that's pretty much the list cept there has been a more recent discovery on the calipers. Use of the noted 'Blazer' calipers vs the 'Camaro' ones allows the bleeder screws to be on the correct top position:
4 each Raybestos P/N 7993 11.260" Vented Rotors (rear, 89-94 Chrysler LeBaron) 1 each CarQuest P/N 18-4071 Front Caliper, rebuilt, 82-92 Chevrolet Camaro (note 1) 1 each CarQuest P/N 18-4072 Front Caliper, rebuilt, 82-92 Chevrolet Camaro (note 1)
or from 4WD '83-'94 Blazers. The left is CarQuest P/N 18-4129 and the right is CarQuest P/N 18-4128 for unloaded calipers. The loaded caliper P/N's are 16-4128(9) for right and left, respectively.
Do NOT get 2WD calipers. Those are exactly the same as the F-body calipers.
1 each CarQuest P/N 18-4138 Rear Caliper, rebuilt, 80-85 Cadillac 1 each CarQuest P/N 18-4139 Rear Caliper, rebuilt, 80-85 Cadillac (These calipers must be identified with casting Nos. 020 and 021) 8 each Caliper bolts 2 sets CarQuest P/N D-154 Disc Pads (Front and rear are same) 1 each CarQuest P/N 2218 Master Cylinder, (92-94 Chev/GMC Blazer/Jimmy) Aluminum, 1.125" bore 4 each 3/16" X 24" Teflon stainless steel braided brake hoses. (Stock hoses are too short) 4 each Earls P/N 600773 .400" Banjo fittings for above 4 each Earls P/N 989534 Female 10mm X 1 adapter ends for above 4 each 1/4" AN-type rubber insulated clamps (to secure brake hoses) 10 each Dorman P/N 610-323 Wheel studs, 12M1.50, X 55mm X 12.67mm knurl diameter wheel studs for front hubs. 2 each Caliper adapters for front, (burned, drilled and tapped 3/8" steel plate) 2 each Caliper adapters for rear, (burned, drilled and tapped 3/8" steel plate) 4 each 12M1.50 X 40mm Hex head cap screws for front adapters. 8 each 12mm or 1/2" Split Lock washers for 12 mm bolts 4 each 12M1.50 X 25mm Hex head cap screws for rear adapters. 4 each 1" Round X .500" X .435" thick spacers for front caliper adapters. 4 each .060" thick SAE flat washers for rear caliper spacers. 2 each E-brake cable housing stops (burned and drilled 1/4" plate) 1 quart SAE 3 or better Brake Fluid 1 each 12M1.50 Starting tap 1 each 27/64 High Speed Twist Drill
Re-used Materials
4 each Banjo fitting bolts from Fiero calipers 2 each Front hub assemblies, modified with the disc rotors machined off to leave hub flange approximately 5/8" thick. 2 each Fiero E-brake cable return springs. 1 lot Fiero E-brake cables.
Date Posted: 13 May 2009 at 6:00am
That... Sounds like alot to keep an eye out for. I'll Craigslist the living daylights out of it when I get back today.
Date Posted: 13 May 2009 at 3:32pm
Checked with the highschool, they said it should be fine. Austin, I'll need the CAD sketches, as well as what metal type you'd like. I'll also email the both of you the details.
Posted By: Austin
Date Posted: 13 May 2009 at 11:28pm
Romeo wrote:
Checked with the highschool, they said it should be fine. Austin, I'll need the CAD sketches, as well as what metal type you'd like. I'll also email the both of you the details. |
Another set of drawings I have specify the caliper brackets to be cut using 3/8" Mild Steel. The Ebrake Stop is 1/4" Mild Steel.
Date Posted: 13 May 2009 at 11:54pm
Splendid, I'll pass that.
Posted By: Ron Philipchalk
Date Posted: 20 May 2009 at 8:34pm
I just finished the 11.25 upgrade. I have an extra set of rear adapters you can have for $25. I also have the templates for front and rear. You can email me at philipch@twu.ca Ron
Date Posted: 20 May 2009 at 10:20pm
I'd just like to be the first to say, if he does not take them, I'll take the 2nd shot in line.
Date Posted: 20 May 2009 at 11:12pm
Anyone interested in doing a brake conversion might wish to have a peek at http://www.fiero.nl/forum/Forum4/HTML/046895.html - This thread in the Mall at PFF.
Date Posted: 20 May 2009 at 11:36pm
Does "he" refer to me? I'm interested in them, personally, but is there any chance you have a rough estimate on the total cost?
Date Posted: 22 May 2009 at 2:03pm
Sorry for not replying sooner. Fiero messages get put in a different folder that I don't see often. Anyway, if you're interested please call me at 778-232-0902.
Date Posted: 23 May 2009 at 5:13pm
Well I just got the rear caliper adapters from Ron, which is perfect for me seeing as I am going to take the Rear Grand Am parts and simply move them to the front, so all I really needed was the rear brackets. The ones that are listed in the thread Patrick Referenced seem to be a really good deal considering the quality of the brackets.
I am going to source as many of the core parts for testing over the next few months and go from there.
Ron I know I saw your brakes installed however did you by chance take many pics? If you did, would you mind dropping them in an email to mailto:capt@captfiero.com - capt@captfiero.com and I'll post them up here for people to look over. With next weekend being the Tech Session, the weekend after that is Arlington and the weekend after that being the All Pontiac show.n I can see it being nearly a month before I really get started on locating the conversion parts to do this.
Date Posted: 26 May 2009 at 10:44am
Dave, I took a few. I found the Pennock's thread was pretty good, although kind of long.
Date Posted: 26 May 2009 at 1:48pm
LOL, it is pretty long, I surfed through it trying to find relevant data, (basically showing how it looks completed) I know what all the parts are and know where they go, but getting a good look is usually worth well, a thousand words.
Date Posted: 30 May 2009 at 6:08pm
Hey Dave, here's what I had been referring to: http://www.westcoastfiero.com/brakes/brakes_12.html - http://www.westcoastfiero.com/brakes/brakes_12.html
Go down to the bottom kit, the Corvette 12" kit, and look at the price. It's $440 for both axles, although the stock calipers are used, meaning people such as Nigel would have to find new ones. However, it still fits the Fiero hub (Although 15" rims wont fit around the large brakes) and later on down the road, two-piece rotors can be applied to cut down on weight and decrese brake fade.
Date Posted: 30 May 2009 at 6:10pm
Sorry, on that same topic, you can also get the 13" brakes from the Dodge Viper, which fit in the same manner the Corvette ones do and still allow for e-brake in the same way the Corvette's do for $742, on this page: http://www.westcoastfiero.com/brakes/brakes_13.html - http://www.westcoastfiero.com/brakes/brakes_13.html
Date Posted: 30 May 2009 at 7:47pm
That cheap price is for the 4 rotors and brackets and does not include the calipers or lines. You must supply 88 calipers on all 4 corners and 88 hoses. I'd have to even research it to see if they can be used on early model cars.
Date Posted: 30 May 2009 at 9:47pm
Ah, see I knew you used you're existing calipers (Hence the retention of the e-brake) but I wasn't aware they had to be '88 calipers. That puts a dent in that plan.
Date Posted: 31 May 2009 at 10:27am
Romeo wrote:
That puts a dent in that plan. |
Tristan, with money as tight as it is for you being a student and all, why are you even considering any kind of a brake upgrade?
I realize you need to repair your brakes, but wouldn't it be a whole lot simpler (and cheaper) to just re-do what you have with stock off the shelf (or off a donor car) parts?
And then you could afford to pay someone (and/or some shop) to replace your clutch.
Date Posted: 31 May 2009 at 2:34pm
Well, truth be told, I was looking for future reference, as David already pulled my backside from the fire in terms of brakes. Like I said though, down the road (Perhaps during my work terms) when a little bit more money is available, I wouldn't mind putting some extra stopping power into my car, as the stock brakes are woefully underpowered.
Date Posted: 15 June 2009 at 12:25pm
Ok, going in to "Dream level" brake upgrades here, does ANYONE (As I asked a few people at the meeting) if it would be possible to retrofit C5 Corvette brakes to the Fiero? I know it's possible to remachine the C4's rotors to fit the Fiero calipers, but what I want to know is if you could re-purpose the entire assembly (Calipers and rotors). Doing so would allow for 6-piston calipers, with either 14.5 or 15" rotors, either of which would be, in technical terms, SICK.
