Trouble starting
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1315
Printed Date: 21 February 2025 at 9:20pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Trouble starting
Posted By: Bobz0r
Subject: Trouble starting
Date Posted: 17 May 2009 at 6:39pm
I'm having lots of trouble starting my 85 GT. When I try to start, I get a few slow cranks and that's it. My battery cables are heating up and my battery won't hold a charge when the car is off. My multi-meter says my battery drain with the car off is just a few milliamps. Using a booster pack to try and start my car results in VERY hot cables, and after a few tries, if it doesn't start my booster pack is half dead.
My battery is good, my alternator is charging and I've replaced the starter. Does anyone have any info that may help?
Date Posted: 17 May 2009 at 8:00pm
Did you ever check the ignition timing? Are you using the black or red starter, I might be inclined to try the red starter, OR just bite the bullet and get a new one.
Posted By: Bobz0r
Date Posted: 17 May 2009 at 8:04pm
How would I check the ignition timing? I am using the black one. I am also in Kelowna now and wouldn't be able to change to the other starter you gave me until I get home tomorrow, if I get home. But this starter is doing the exact same thing as the last one. It's both battery cables getting hot too, and not just the one. Does that have any significance?
Date Posted: 17 May 2009 at 8:57pm
Well the only thing that will cause hot cables is
A. Really corroded connections at the Battery and or starter and or ground to the engine block.
B. Bad or worn out starter.
I can't remember but we did not pull the cables off when you were here did we? I would remove both cables and clean the hell out of them, or run to a local parts store and buy 2 replacement ends, then cut off the OEM ends and put the new replacements on. Replacement ends are about $4 each.
Date Posted: 17 May 2009 at 9:35pm
I'm 100% voting for 'change the cables'.
You can have corrosion inside the rubber molded boot and never be able to see it. Also, because of where the ground cable bolts on (front side of the head) it gets pissed on all the time when it rains. Guess what... more corrosion! Had to do a field call once on a no-start. Cracked off the nut, wiggled the wire, cranked it back down - Vroooom.
Make sure to put penatrox or http://www.idealindustries.com/products/wire_installation/accessories/noalox.jsp - noalox (latter can be got at home depot) all over the terminal ends before you bolt them down, and clean the crap out of whatever you're bolting to with some coarse grit paper.
Posted By: Bobz0r
Date Posted: 17 May 2009 at 11:22pm
Make sure to put penatrox or http://www.idealindustries.com/products/wire_installation/accessories/noalox.jsp - noalox (latter can be got at home depot) all over the terminal ends before you bolt them down, and clean the crap out of whatever you're bolting to with some course grit paper.
I was reading up on the internet and that seems to be the solution to similar problems. Of course it just has to be the last thing I change
Posted By: Bobz0r
Date Posted: 21 May 2009 at 8:44pm
Well, I went and changed the cables today and guess what? NOTHING. Car starts while it's cold, but as soon as it heats up a bit, nothing, just continuous slow cranking and heating cables.
Posted By: Bobz0r
Date Posted: 08 September 2009 at 4:42pm
Problem is back AGAIN. Last time I changed the starter and it worked great. Since then I've also got a new Optima Red Top battery as well.
Today I tried starting it after stopping off at the grocery store for a quick pickup, came out and nothing. Just a bunch of really fast clicking. Sounds like the starter or solenoid is giving me trouble again. ARGH! It only needs to last me another 2 months until I swap the motor! lol.
Date Posted: 09 September 2009 at 6:24pm
If your cables were indeed that bad there is a possibility that you damaged the starter.
All that heating in your cables is sinking voltage away from the starter which makes it even harder for it to do the job. It will then demand even more current because the rpm's are lower.
If you sat there cranking and cranking stubbornly, you just might have a buggered starter now.
Cheers,
Damien
Date Posted: 16 September 2009 at 7:02pm
I'm also starting to have trouble starting. The car makes a rapid clicking (As if a circuit breaker is going nuts) and really struggles to kick over... Think it's the wires starting to lose their insulation?
Date Posted: 16 September 2009 at 7:24pm
Romeo, yours, with the way we hatched your battery wire. If you have not replaced the battery yet, that will totally explain your issue. That was suppose to be a temp solution to keep you on the road just long enough to get a new battery.
Date Posted: 16 September 2009 at 7:28pm
Romeo wrote:
I'm also starting to have trouble starting. The car makes a rapid clicking (As if a circuit breaker is going nuts) and really struggles to kick over... Think it's the wires starting to lose their insulation? |
I think you have a http://www.westcoastfieros.com/forum/forum_posts.asp?FID=1&TID=1512&PN=1&get=last - broken starter bolt .
Date Posted: 16 September 2009 at 7:33pm
Capt Fiero wrote:
Romeo, yours, with the way we hatched your battery wire. If you have not replaced the battery yet, that will totally explain your issue. That was suppose to be a temp solution to keep you on the road just long enough to get a new battery. | Well, battery isn't so weak it should be straining this badly, but I'll look into it.
Yes Patty, must be the bloody bolt.
Date Posted: 16 September 2009 at 8:00pm
Romeo wrote:
The car makes a rapid clicking (As if a circuit breaker is going nuts)... |
That would be your starter solenoid clicking.
Put a voltmeter on your battery while the engine is off and while the car is running (if you can get it started). What are the readings?
Date Posted: 17 September 2009 at 6:01pm
No idea yet, haven't had a chance to find my dad's voltmeter.
Posted By: Bobz0r
Date Posted: 17 September 2009 at 9:04pm
This is what mine is doing now, except I've noticed it's only in the mornings, or when it's getting chilly. I think maybe the battery is on the way out? It's a 4 or 5 year old Optima Red Top in there now.
Date Posted: 17 September 2009 at 10:42pm
Oh, damn. That battery shouldn't be dead already... Oh well. Time to relocate!
Date Posted: 18 September 2009 at 8:15am
The Optima's have a 10 year warranty, so if you can find your recpit, take it back and get a new one, assuming you bought it new.
Date Posted: 18 September 2009 at 8:44am
'Tis the season to have hard starting.
Cold weather and high humidity both are conducive to making things go wrong. Corrosion will form easily on all sorts of things in these conditions. Including but far from limited to ground straps and battery terminals.
As for the terminals, I'm not talking only about the cable to battery mating surfaces. It's the hidden area that'll bite you. You need to pull the terminal assy off the battery, then carefully stick a small screwdriver between the rubber boot and the 'bolt' on an angle. Now pull it around in a circle, popping the 'bolt' out. If the 'bolt' is even slightly damaged from improper tool usage over the last ~25 years, just replace it. You can get new ones at Lordco in the Pico section for a couple bucks each. They're honestly not even worth cleaning up the old ones.
Check the contact face of the terminal. Good chance it'll be covered in a film of crud. It might even LOOK like metal! So get in there and clean it up really well until it's REAL metal. Coat all surfaces in Noalox (etc) and reassemble.
Next remove all your ground straps, clean clean clean them until they shine (sand paper, wire wheels, brushes, etc) then coat them too, and reassemble.
You'll find your distributor caps will get layers of corrosion on the terminals more at this time of year too. Pull the terminals off and make sure they're clean. Here is another good place to put a thin layer of your new friend - on the terminals.
Date Posted: 18 September 2009 at 9:34am
Dr.Fiero wrote:
Coat all surfaces in Noalox (etc) and reassemble. |
I'm familiar with dielectric grease, but not with products such as Noalox. So I did a google search and found http://www.sw-em.com/anti_corrosive_paste.htm - this interesting article . Makes for good reading (for anyone who deals with electrical connections).
Actually, there's a lot of good info at the site the above article came from. Have a look at the http://www.sw-em.com/Product%20Reviews.htm - Product Reviews page.
Date Posted: 18 September 2009 at 12:34pm
Has anyone here done the battery re-location here? If so, is it overly difficult?
