Fel-Pro gasket numbers
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1355
Printed Date: 02 August 2025 at 4:37am
Topic: Fel-Pro gasket numbers
Subject: Fel-Pro gasket numbers
Date Posted: 03 June 2009 at 5:54pm
Part TypePart NumberCommentQty
Exhaust Pipe Flange Gasket javascript PartDetails'60650','Exhaust%20Pipe%20Flange%20Gasket','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 60650 Pipe to manifold1
Intake Manifold Gasket Set - Fel-Pro javascript PartDetails'MS%2093020','Intake%20Manifold%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - MS 93020 Valve cover gskts. not incl.; Upper set incl.1
Auto Trans Extension Housing Repair Sleeve javascript PartDetails'99139','Auto%20Trans%20Extension%20Housing%20Repair%20Sleeve','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99139 GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Input Shaft Repair Sleeve javascript PartDetails'99139','Auto%20Trans%20Input%20Shaft%20Repair%20Sleeve','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99139 GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Manual Shaft Seal javascript PartDetails'8792S','Auto%20Trans%20Manual%20Shaft%20Seal','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 8792S GMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Oil Pan Gasket javascript PartDetails'TOS%2018656','Auto%20Trans%20Oil%20Pan%20Gasket','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - TOS 18656 (16-bolt holes); GMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Output Shaft Repair Sleeve javascript PartDetails'99139','Auto%20Trans%20Output%20Shaft%20Repair%20Sleeve','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99139 GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Output Shaft Seal javascript PartDetails'3543','Auto%20Trans%20Output%20Shaft%20Seal','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 3543 GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Shift Shaft Seal javascript PartDetails'8792S','Auto%20Trans%20Shift%20Shaft%20Seal','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 8792S GMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Torque Converter Seal javascript PartDetails'4072N','Auto%20Trans%20Torque%20Converter%20Seal','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 4072N GMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Valve Body Gasket javascript PartDetails'TOS%2018661','Auto%20Trans%20Valve%20Body%20Gasket','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - TOS 18661 (11-bolt holes); GMC THM125C 3 Spd. Automatic Transaxle1
Conversion Gasket Set - Fel-Pro javascript PartDetails'CS%208699-1','Conversion%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - CS 8699-1 Oil pan gskt. for Goodwrench® replacement eng. not incl.1
Crankshaft Repair Sleeve Tool - Fel-Pro javascript PartDetails'16304','Crankshaft%20Repair%20Sleeve%20Tool%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 16304 Crankshaft1
Dowel Pin (Cylinder Head) - Fel-Pro javascript PartDetails'ES%2074013','Dowel%20Pin%20Cylinder%20Head%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - ES 74013 Cylinder Head; Cyl. head alignment2
Drain Plug Gasket - Fel-Pro javascript PartDetails'70822','Drain%20Plug%20Gasket%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 70822  1
Exhaust Manifold Gasket Set - Fel-Pro javascript PartDetails'MS%2093045','Exhaust%20Manifold%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - MS 93045  1
Head Gasket Bulk - Fel-Pro javascript PartDetails'512%20SD','Head%20Gasket%20Bulk%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 512 SD Head bolts not incl.; Head bolt replacement recommended; PermaTorque Severe Duty™; 2 Req'd.2
javascript PartDetails'8699%20PT-2','Head%20Gasket%20Bulk%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 8699 PT-2 Head bolts not incl.; Head bolt replacement recommended; PermaTorque®; 2 Req'd.2
javascript PartDetails'P512PER','Head%20Gasket%20Bulk%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - P512PER Head Gasket Bulk; Head bolts not incl.; PermaTorque Severe Duty™; 2 Req'd.2
Head Gasket Set - Fel-Pro javascript PartDetails'HS%208699%20PT-5','Head%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - HS 8699 PT-5 Head bolts & exh. pipe packing not incl.; Head bolt replacement recommended; PermaDry® molded rubber valve cover gskts. incl.; Premium valve stem seals incl.1
Head Gasket Spacer Shim - Fel-Pro javascript PartDetails'8699%20SP-1','Head%20Gasket%20Spacer%20Shim%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 8699 SP-1 HeadSaver®; 2 Req'd.2
Oil Filter Gasket - Fel-Pro javascript PartDetails'70672','Oil%20Filter%20Gasket%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 70672  1
Oil Pan Gasket Set - Fel-Pro javascript PartDetails'OS%2030512%20C','Oil%20Pan%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - OS 30512 C Exc. Goodwrench® replacement eng.; Cork1
javascript PartDetails'OS%2034501%20R','Oil%20Pan%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - OS 34501 R Goodwrench® replacement eng.; PermaDry® molded rubber gskt. incl.1
Rear Main Seal Set - Fel-Pro javascript PartDetails'BS%2040625','Rear%20Main%20Seal%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - BS 40625 Rear Main Seal Set; 11.0mm thick; PTFE Rubber; One-piece1
javascript PartDetails'BS%2040464','Rear%20Main%20Seal%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - BS 40464 Rear Main Seal Set; 11.0mm thick; Rubber; One-piece; Improved design1
Main Bearing Repair Sleeve - Fel-Pro javascript PartDetails'16257','Main%20Bearing%20Repair%20Sleeve%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 16257 Crankshaft; Use w/installation tool1
Timing Cover Repair Sleeve - Fel-Pro javascript PartDetails'16212','Timing%20Cover%20Repair%20Sleeve%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 16212 Timing Cover; 1.040" sleeve length; Use w/installation tool1
Timing Cover Repair Sleeve Tool - Fel-Pro javascript PartDetails'16312','Timing%20Cover%20Repair%20Sleeve%20Tool%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 16312 Timing Cover1
Timing Cover Gasket Set - Fel-Pro javascript PartDetails'TCS%2045467','Timing%20Cover%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - TCS 45467 Timing Cover Set w/Sleeve; w/Sleeve 'N' Seal®; 1.040" sleeve length1
javascript PartDetails'TCS%2045466','Timing%20Cover%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - TCS 45466 w/o Sleeve 'N' Seal®1
Timing Cover Seal - Fel-Pro javascript PartDetails'9845','Timing%20Cover%20Seal%20-%20Fel-Pro','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 9845  1
Valve Cover Gasket Set - Fel-Pro javascript PartDetails'VS%2050077%20R','Valve%20Cover%20Gasket%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - VS 50077 R Services both covers; PermaDry® molded rubber gskts. incl.1
Valve Stem Seal Set - Fel-Pro javascript PartDetails'SS%2072530','Valve%20Stem%20Seal%20Set%20-%20Fel-Pro','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - SS 72530 Premium valve stem seals incl.1
Water Pump Mounting Set javascript PartDetails'35220','Water%20Pump%20Mounting%20Set','FL','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 35220  1
Camshaft Repair Sleeve - National javascript PartDetails'99176','Camshaft%20Repair%20Sleeve%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99176  1
Crankshaft Repair Sleeve - National javascript PartDetails'99298','Crankshaft%20Repair%20Sleeve%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99298 Rear; 2nd Design1
Crankshaft Seal - National javascript PartDetails'5210','Crankshaft%20Seal%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 5210 Rear; Radial; 1st Design1
javascript PartDetails'4307V','Crankshaft%20Seal%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 4307V Rear; Viton®; 2nd Design1
Repair Sleeve - Fel-Pro javascript PartDetails'99176','Repair%20Sleeve%20-%20Fel-Pro','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99176  1
Timing Cover Harmonic Balancer Sleeve - National javascript PartDetails'88176','Timing%20Cover%20Harmonic%20Balancer%20Sleeve%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 88176  1
javascript PartDetails'5000','Timing%20Cover%20Harmonic%20Balancer%20Sleeve%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 5000 Kit1
Timing Cover Repair Sleeve - National javascript PartDetails'99176','Timing%20Cover%20Repair%20Sleeve%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 99176  1
Timing Cover Seal - National javascript PartDetails'9845','Timing%20Cover%20Seal%20-%20National','NW','1985%20PONTIAC%20FIERO%20GT%20%20V6%202.8L%20173CID%20VIN%209' - 9845  1
Date Posted: 03 June 2009 at 5:55pm
After about 100 click throughs...  I finally found this list.  This is for an '85 V6.  If you click a part number, you should get a window with a picture, etc.
edit: oops.  no popup.  Guess that only worked from there site.
