Water Injection
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1464
Printed Date: 24 April 2025 at 12:07am
Topic: Water Injection
Subject: Water Injection
Date Posted: 31 July 2009 at 9:50am
Hey, I know this is kinda out there for most people, but has anyone tried water injection on a Fiero? For those of you who haven't heard of it, water injection injects either pure water, or a water/methanol mix into the intake allowing for massive compression ratios or large turbos to be used, without causing pre-detonation. Now, as you can imagine, the cost of putting in a little bit of water in is miniscule (Far cheaper than buying racing gasoline) yet allows for generous increases in power (Due to the extreme compression ratios, or for allowing for higher boost amounts).
Going back to original topic, has anyone tried doing this on a Fiero?
Date Posted: 31 July 2009 at 2:03pm
On a stock one?  Pointless pretty much.
Got boost?  water/meth is a GREAT way to go.
Date Posted: 31 July 2009 at 3:33pm
I guess there's no stroker kits or anything for the Fiero, hm?
Date Posted: 31 July 2009 at 4:39pm
Yes Stroker kits, there are a few different options.   However you are not going to have any massive compression ratio requirements.  Unless you did a balls out 3.4 and even that will be only 11-1.  Actually wait a min, there is a 12.5-1 piston swap for the 2.8 but will cost you double what simply installing a bigger newer engine will cost ya.
Date Posted: 31 July 2009 at 7:07pm
And if you DID go the 12.5:1, you better not ever run out of the meth mix - since it'll no longer be optional!
You'll also need a pretty stout cam, so you can kiss EFI goodbye.
And at that point...  you've stuffed sooooo much money into it...  Well, see Daves last sentence.
Date Posted: 31 July 2009 at 7:43pm
Awww, man. Harshin' my marshmellow.
