Pacific Performance Parts Centre
Category: Buy / Sell
Forum Name: Vendor Area
Forum Description: A Place for Commercial Fiero Parts Suppliers
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1514
Printed Date: 01 June 2025 at 1:34pm
Topic: Pacific Performance Parts Centre
Subject: Pacific Performance Parts Centre
Date Posted: 20 September 2009 at 12:24am
Now Closed and Out of Business
    Just wanted announce a new parts place that a few members have found and have been keeping them busy with all of our questions.    Performance Parts Centre in Langley seems to have some of the best prices going and some of the most knowledgeable staff around.
Well the list starts like this.
K&N Air Filter for V6 Fiero $30
MSD Blaster II Coil PN 8226 for 85-88 V6 or 85-86 4cly $46.00
MSD Cap and Rotor Bright Red with Brass Contacts PN 8430 Fits 85-88 V6 $22
MSD 6AL with Rev Control $ 235.00
MSD 8.5mm Red Superconductor Spark plug Wires PN 31189 "CUT TO FIT" These have to be cut and assembled by the end user.   $ 82.00
MSD 8mm Blue Ready to install Spark plug Wires PN 3172 $48.06
Lowering Springs 84-87 All Cars Suspension Tech  P# 60120  $230.00
V8 Fiero Flywheel from Centerforce PN 700502    $346.00  this is the flywheel you need when you put a small block Chevy in your Fiero.
ADJ Fuel Pressure Regulator. PN 512-501 Fits 85-88 V6  Holly, Polished Aluminum can be adjusted with plenum on the car, $115.00
Prothane Poly Bushings
Pontiac Fiero
 CONTROL ARM BUSHINGS
84-88 Front. C-Arm Bushing Kit, w/o Shells 7-207   63.83
84-87 Rear. C-Arm Bushing Kit, w/o Shells 7-304    35.83
MOTOR & DRIVE TRAIN
84-87 Engine Cradle Mount Kit 7-502  57.11
84-88 Engine Torque Strut Bushing Kit, 4 Cyl. 7-501 23.51
85-86 Engine Torque Strut Bushing Kit, 6 Cyl 7-501 23.51
TRAILING ARM BUSHINGS, REAR
88 Rear Link Trailing Arm Bushing Kit 7-305  75.03
SWAY BAR BUSHINGS, FRONT
84-87 Sway Bar Bushing Kit, 23mm Bar 19-1122 15.76
SWAY BAR END LINKS, FRONT
84-87 End Link Kit 19-408 17.91
TOTAL KITS
 84-87 Total Kit 7-2034 117.59
Most  prices at the Performance Parts Centre are about 20-30% Less some are even 50% less than there competitors.   Note that Performance Parts Centre is just that a Performance Parts store, not a tune up shop for ball joints or brakes or what not.  But if you need Cam's Lifters, Nitrous, Ignition parts or anything along those lines you should really drop them a line and get a quote from them, it could save you a lot of money.
Posted By: Guests
Date Posted: 20 September 2009 at 2:13pm
+1 for PPC!
Date Posted: 20 September 2009 at 10:09pm
Haha, they've changed the prices on the Cap/Rotor and Ignition Coil since I was there last, and that was like... A month ago.
Date Posted: 21 September 2009 at 12:52pm
Hopefully, the price has gone down.....    They just like any other parts places that can offer a better discount to a more established clientèle.    If we can manage our our part numbers, and don't have to go in there and ask them to look stuff up every time or have to guess on what will work for what we need, it should make it really worth while for both sides.
Date Posted: 21 September 2009 at 8:39pm
It wasn't more expensive or anything, the prices have just shuffled around. $2 off here, $2 more there. Great store though. They had a 13", Six-Piston, Slotted and Cross-Drilled brake system in there last time. It was like automotive artwork.
Posted By: Fire451
Date Posted: 31 October 2010 at 8:51am
how much was it???
Date Posted: 31 October 2010 at 9:03am
I am going to have to Un Pin this thread as Performance Parts Centre is closed down and out of business.  Our only fall back is Mopac and Lordco Performance Parts division.
Posted By: Fire451
Date Posted: 31 October 2010 at 1:51pm
that sux.....
Date Posted: 31 October 2010 at 4:03pm
God damn it! I didn't even mind the commute, it was worth it to wander among sexy superchargers, big brakes and incredible intakes... Wonder what happened, they always had people in the store every time I went there...
Date Posted: 31 October 2010 at 5:28pm
Yeah, but were they actually buying anything, or were they simply wandering through the store oogling at all the sexy superchargers, big brakes and incredible intakes?
Date Posted: 31 October 2010 at 8:50pm
Hey, the first time I went there, I went there for nothing else but a cap/rotor. I left with a cap, rotor, coil, spark plugs and plug wires.
Date Posted: 31 October 2010 at 9:56pm
Sure, but if you had instead left there with sexy superchargers, big brakes and incredible intakes... they'd still be in business. Sorry Tristan, but it's all your fault they went kaput.
Date Posted: 01 November 2010 at 7:31am
Awww, man... But I do have big brakes now, by Fiero standards. And I have half an incredible intake.
