Duke water pump
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1535
Printed Date: 24 April 2025 at 12:06am
Topic: Duke water pump
Subject: Duke water pump
Date Posted: 28 September 2009 at 11:05am
Does anyone have a part number for a duke water pump with a metal impeller?
I don't want one with a plastic impeller as they are known to be inferior. (The plastic impeller often works loose from the shaft and then doesn't do anything.)
It's for an '84. I suspect the pump itself is the same for all years. (The '87-'88 dukes have a different pulley.)
While we're discussing pulleys, what is the best method of removing the pulley from the old pump and installing it on the new pump?
So now I've got a few things to do to this car...
1) Drop the cradle to fix whatever is preventing the clutch release lever from moving. (I suspect the clutch fork isn't positioned in the throwout bearing properly.)
2) Drill out a broken starter bolt which has snapped off in the block.
3) Re & re the timing cover to pound out a dent that is rubbing on the timing gear.
4) Replace the water pump which is dripping coolant out the bottom weep hole.
Will it ever end?
Date Posted: 28 September 2009 at 3:22pm
I don't know about part numbers, but I recently had to buy a water pump for my 86 duke. I got a metal one from the Napa in Abbotsford. I've read online that you should try to get one with a closed impeller, however I believe the one I got is an open impeller. I haven't had any issues with it, though. I took a picture of it compared to my old one, I'll upload it, the new one is shown sitting on top of the box it came in.
To move the pulley over I used a power steering pump pulley remover and installer tool. Like this one:
Date Posted: 28 September 2009 at 3:30pm
Geez, I've never even seen one of those types of pullers before. Hopefully one of the club members closer to Vancouver has one and can swap pulleys for me.
I also wasn't aware that there were differences as to whether the impeller was open or closed.
Man, I didn't realize a degree was necessary to replace a leaking water pump!
Thanks for the info, Cheese.
Date Posted: 28 September 2009 at 3:46pm
I wasn't aware that they made them with plastic impellers, that sounds a little scary. At least you'll be able to change it while the cradle's out, there's not much clearance to get at the bolts while its in the car. I had to change right after putting the cradle back in and discovering that it was leaking, that was frustrating.
I believe they sell water pumps with the pulley on already, but again I don't know what the part number would be.
Date Posted: 28 September 2009 at 3:51pm
So did you bother unbolting the "elbow" from the block and then remove the pump from it, or did you leave the elbow attached to the block?
Date Posted: 28 September 2009 at 4:27pm
                    The one and only time I have ever done a water pump on a 4 popper, I only removed the pump section.   As for the pulley, I can't remember it was so long ago, but either the pulley was already on, or I was able to change it with an impact gun, as I know I did not have a puller and I didn't have to go anywhere.  IIRC I was really surprised at how quick a job it was compared to a V6 pump.
Date Posted: 28 September 2009 at 5:05pm
I left the "elbow" attached and just removed the pump. The pump I bought came with the gaskets for the pump to elbow thing and elbow to block gasket. The pump you buy might come with them too, so if you get them you might as well take it all out and replace the old gaskets, although I don't know if there's any real benefit to that if they weren't already leaking.
Date Posted: 28 September 2009 at 7:00pm
If you do indeed need a 'power steering' puller installer, I've got one.  Well, I did the last time I looked anyhow.
Date Posted: 28 September 2009 at 7:21pm
Yes, apparently some replacement water pumps do come complete with pulleys.
Date Posted: 28 September 2009 at 7:28pm
Actually, the "benefit" I was wondering about was whether it actually might be easier in the long run to remove the four mounting bolts that hold the elbow to the block, and then remove the pump from the elbow when it's off the engine.
However, from the sound of it though, it seems like it's not that bad of a job to just unbolt the pump from the elbow while it's still on the engine.
Besides, I'll probably be doing this with the cradle dropped  (to fix a clutch problem), so access shouldn't be an issue.
Date Posted: 28 September 2009 at 7:31pm
Okay, thanks for letting me know John. I won't be needing it for awhile as I have to first figure out how and where I'm going to drop this cradle.
Date Posted: 28 September 2009 at 7:57pm
     Ya know Patrick maybe its just, but I still don't think you have ever gotten the hydraulics operating right to verify the clutch movement.  You said you pushed the pedal and "nothing" happened at the back, well if that is the case, then the hyd stuff is not working.  Any movement from the master should result in movement at the slave.   If the pedal won't move at all, then the master is seized, if it moves halfway to the floor and hits a brick wall so to speak, then the 1st gen master has failed and needs to be replaced.    If the pedal moves freely to the floor while attached however there is no slave movement you have air in the system.
                If you were "just some kid"  and neither myself or him really cared, I would just walk away and let them have at it, however I know you don't want to go through work you might not have to do.  If you want, drop me a PM with your home address, and if I can work it into my Burnaby run, I'll stop by and take a look first hand.     Maybe I can save you the nightmare of dropping the cradle.
Date Posted: 28 September 2009 at 8:32pm
Dave, I appreciate the offer (and I'll probably take you up on it!), but did you have a good look at those pictures in http://www.westcoastfieros.com/forum/forum_posts.asp?FID=1&TID=1533&PN=1&get=last - This thread ? I don't believe there's enough room for the clutch fork to pivot before the clutch release lever would hit the bellhousing on the gimped '84. For the clutch release lever/fork shaft to already be that far rotated, I believe the fork must be positioned beyond where it's supposed to be.
In regards to the hydraulics, nothing would happen when the pedal is pressed if the clutch fork is jammed someplace it's not supposed to be. I'm pretty sure this is what bent up the pedal so bad. I suspect the previous owner must've been standing on the pedal trying to get it to move!
Here's the '84 pedal I took out compared to the one from my '87 I'm "borrowing" to put in the '84.
I haven't got the slave installed at the moment, but when the weather clears I'll put it in and have you over. In the meantime, now that the weather is ugly, I'll return to editing that special video that I know you're interested in.
Date Posted: 29 September 2009 at 1:50pm
Easier solution: Pull the four and put in a LS-Series V8/Large Displacement V6.
Date Posted: 29 September 2009 at 2:00pm
Better... of course.
Easier... not a chance!
Date Posted: 30 September 2009 at 4:17pm
Easier solution to the easy solution: Win the lottery and hire a shop.
Honestly Patty, must I consider every detail for you? lol
