MSD 6AL
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1623
Printed Date: 01 March 2025 at 12:52am
Topic: MSD 6AL
Posted By: grokan
Subject: MSD 6AL
Date Posted: 01 December 2009 at 4:24pm
I've got my hands on a MSD 6AL and was wondering if anyone
noes the part numbers for the two plugs that go on the
coil?
Lets get it sideways
Date Posted: 01 December 2009 at 4:39pm
 Just buy this from Mopac and you are set.  It wires in and does not require you to cut your old harness at all.  Makes it all plug and play.  Price was around 24 bucks when I bought the last couple.
Harness, MSD 6 to GM Dual Connector Coil
Part No. 8876
Features
  • N/A
Posted By: grokan
Date Posted: 01 December 2009 at 5:30pm
awesome! I have to go out to mopac anyhow to grab a rev
chip for it too, thanks much
Posted By: Roadfury
Date Posted: 02 December 2009 at 10:28am
Just an interesting piece of info that at least I didn't know until recently about the MSD system, it only provides a multiple spark discharge until about 3000 RPM then it only gives off one spark because the system cannot physically spark that fast
Date Posted: 02 December 2009 at 11:54am
 Yep but what a spark that is...   (very big spark)
The Fiero does benifit more than most by having the multiple spark at low rpm, just due to the fact that these cars run PIG RICH at WOT in the low rpm range.   The computer ignors the O2 sensor and pumps as much fuel as possible, so having the extra spark helps to make sure that the spark is at least "there" when it needs to be.
Posted By: grokan
Date Posted: 07 December 2009 at 6:40pm
hey, MSD is in, i took it for a drive, i have a 6800 rev
chip in and my car is auto... i some how hit the limiter
before it shifts. Any suggestions on whats wrong?
Date Posted: 07 December 2009 at 6:58pm
Originally posted by grokan grokan wrote:
hey, MSD is in, i took it for a drive, i have a 6800 rev chip in and my car is auto... i some how hit the limiter
Perhaps your tranny likes to shift at 7000 RPM.
Posted By: grokan
Date Posted: 07 December 2009 at 9:33pm
lol seems like it!
Date Posted: 07 December 2009 at 10:18pm
Does the engine feel like it "shuts off" when it hits the rev limit, or does it just kinda stop accelerating, like the engine is missing, aka not firing on all cylinders.
If it feels like the key is shut off, that means you are hitting the stock rev limiter in the ECM.  If it feels like it missing then you are hitting the MSD limiter.   Drop by here when you are not busy I have a few low rpm rev limit chips you can test with.
      6800 is too high for your motor, more like 6200 is the best shift point.
Posted By: grokan
Date Posted: 07 December 2009 at 11:21pm
I'm for sure hitting the msd limiter, but my car normaly shifted super
high and I just thought nothing of it, since my tach is way off, could it
be the kick down mechanism?
Date Posted: 08 December 2009 at 11:15am
Yep a miss adjusted TV cable can cause that.  Didn't I remember you having a torn up TV cable going to your trans?  If the TV cable is that messed up, it must shift horribly soft at part throttle and feel like a wet noodle.
I just checked I have a 6200,6400,6600, and 6800 chip here if you needed a lower one for testing.  Just remind me they are in the top right drawer of the small tool chest, if you needed one.  Trust me I'll forget in about 20 mins.
Posted By: grokan
Date Posted: 08 December 2009 at 3:40pm
ya i just checked it out and its broke! it shifts nice and
hard tho. would you happen to have one that i can purchase
off you? and i just bought that set of chips when i picked
up the harness adaptor
Date Posted: 08 December 2009 at 3:47pm
I just checked and all my TV cables went to the dump on my last clear out.  I have a nice stack of standard transmission cables though. LOL.
          Ask the Dr, he might have one kicking around, but I think he did what I did and scrapped all his Auto stuff.
Posted By: grokan
Date Posted: 08 December 2009 at 3:48pm
k, no worries how hard are they to change? everything looks
easy except for the part where its in the tranny
Date Posted: 08 December 2009 at 3:57pm
I think the last one took me 5 Min's, 3 of those Min's was fighting with the damn plastic clip where it attach's to the TB.  I have never heard of the trans end falling into the trans so you should be fine, however if it has fallen into the trans, I don't know if it is possible to fish it out.  Might be able to pull the side pan off and attach it through there.
However that is "worst case" scenario, it should just be un-hook it, hook on the new one, attach it and your done.
Date Posted: 08 December 2009 at 6:02pm
...it should just be un-hook it, hook on the new one, attach it and your done.
There is an adjustment to be made so that it works properly. When I got my GT it was the first automatic Fiero I'd ever worked on, so I had to go to Pennock's and search for the correct procedure.
It turned out that the "ratchet" type connector on the TB end of the TV cable on my GT simply would not adjust the way it was supposed to (according to "the book").
I had to use other means (involving brute force and much swearing) to get the proper adjustment, but I did finally get it and now all is well.
Posted By: grokan
Date Posted: 08 December 2009 at 9:07pm
its adjustable? i guess i could cut down the cable so it
shifts sooner couldn't i
Date Posted: 08 December 2009 at 9:55pm
its adjustable? i guess i could cut down the cable so it shifts sooner couldn't i
I think you better go to Pennock's and do a search for TV cable adjustment.
Oh heck, just click http://www.fierosearch.com/cgi-bin/search.cgi?forum=-1&where=SUB&SearchQuery=TV%20cable%20adjustment&Action=DoSearch - This .
Posted By: grokan
Date Posted: 08 December 2009 at 10:20pm
k, my TV cable definitely doesn't have a button to adjust
it... it seems to be that the plastic is just broken where
the cable housing meets the plastic so I'm gonna look at it
better tomorrow and see if i can come up with any better
ideas like cutting down the cable housing a hair till i can
find another cable, what would recommend as a safe rev
limit? the stock limiter is 6800 correct? john bumped mine
when he burnt me a new chip.
Date Posted: 08 December 2009 at 10:32pm
my TV cable definitely doesn't have a button to adjust it...
Check it again. I doubt the TV cable on your Fiero is different than everybody else's.
Note: Apparently there are generic TV cables out there of some sort (and I have no idea what they look like), but all OEM cables will have the adjustment button.
Posted By: grokan
Date Posted: 08 December 2009 at 10:43pm
hmmm my cable had no box like the ones in the photos
Date Posted: 08 December 2009 at 10:52pm
Okay, it's possible then that your Fiero has a non-OEM cable on it.
Although I have no idea how you'd adjust that type of TV cable, it still needs to be adjusted properly for correct operation.
Date Posted: 12 December 2009 at 9:57pm
Luke, you told me at the meeting tonight that you thought the adjustment button was on the tranny end of the TV cable.
Was there something about my earlier post you didn't understand? Check the bolded part!
What's the problem with kids these days anyway?
Posted By: grokan
Date Posted: 12 December 2009 at 10:13pm
Lol I've almost got it dialed in but feels like the torque converter can't
deside weather to lock up or not under full throttle any sujections?
Seems to not matter where the tv cable is set
Date Posted: 12 December 2009 at 11:01pm
Luke, as far as I know, the torque converter does not normally lock up under full throttle no matter how you might have that TV cable adjusted.
Posted By: grokan
Date Posted: 12 December 2009 at 11:55pm
Ya it it kinda shutters really slow... I hate automatics
Date Posted: 13 December 2009 at 12:10am
I hate automatics
That makes two of us.
Date Posted: 13 December 2009 at 10:04pm
Luke, I came across a couple pages in the service manual that talk about TV cable diagnosis and adjustment. These may or may not be helpful to you...
Date Posted: 14 December 2009 at 11:46am
Lots of relevant info in http://www.fiero.nl/forum/Forum2/HTML/105193.html - This thread as well.
More good info http://www.fiero.nl/forum/Archives/Archive-000001/HTML/20090219-2-083502.html - Here  including http://www.tvmadeez.com/article/index.html - This link .
Posted By: grokan
Date Posted: 14 December 2009 at 12:19pm
Thanks Patrick, looks like I have a few
more things to check
Date Posted: 03 January 2010 at 12:16am
 So any updates, how is the box working for you, now that you got the cable setup right?
