Vacuum line question
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1644
Printed Date: 24 April 2025 at 4:21am
Topic: Vacuum line question
Posted By: Roadfury
Subject: Vacuum line question
Date Posted: 16 December 2009 at 10:41am
What is the line that goes off the upper intake right in the middle on the far right side that then goes down towards the front of the car? and there was a fuel filter put on mine just before it went into/under my car and it melted through so im curious as to what its supposed to be and if the fuel filter is supposed to be there??? Thanks!
Date Posted: 16 December 2009 at 11:29am
It's not a "fuel" filter (or it's not supposed to be).
The vacuum line goes to your power brake booster.
From http://myfiero.oceanmoon.com/how-to/brakes/if-it-aint-broke-dont-fix-it - Here ...
Quote http://myfiero.oceanmoon.com/how-to/brakes/if-it-aint-broke-dont-fix-it -
Power Brake Filter
Older models of Fiero have a filter in the booster vacuum line. If the filter is blocked it will cause problems with the brake booster. This filter, or an equivalent to it, can be found in the MotorMite Master Catalog. It may even be on the shelf in some stores.
The filter serves 2 purposes. It will prevent crap from being sucked down the line into the engine. (Especially if the line is unplugged from the booster with the engine running.) It also prevents engine dirt getting to the booster.
Is the Filter needed? Some people would say no. If you have one you should probably replace it every couple years. If you don’t have one, I’d consider adding it. The filter is cheap. It’s easy if a bit awkward to install. You just cut the rubber line, insert the filter, and clamp the line. The purpose of the filter is to keep crud sucked in thru the booster and loose rust inside the steel line vacuum line from reaching your engine. It’s not to protect the booster. If you install one, make sure it won’t melt.
Posted By: Roadfury
Date Posted: 18 December 2009 at 11:30am
Awsome! Thanks Patrick! If you were following what was going on with
my car this melted through filter was the cause of my vacuum leak so
now that it's fixed it runs... Well as good as can be expected on 5 year
old gas :p
