Bushing install... Advice and Ideas?
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1785
Printed Date: 27 November 2024 at 9:19pm
Topic: Bushing install... Advice and Ideas?
Posted By: grokan
Subject: Bushing install... Advice and Ideas?
Date Posted: 25 March 2010 at 11:09pm
Well on Saturday im gonna put my sexy aluminum Cradle
bushings in! Does any have a good plan of attack for doing
the front ones without removing the cradle completely from
the car? And would it be safe to loosen off the rear bolts
and lower the front?
oh and the cradle has been out recently so im thinking
everything should cooperate
Lets get it sideways
Posted By: dodgerunner
Date Posted: 02 April 2010 at 8:00pm
think you should be able to drop it enough.
What I would try is drill out the rubber around the center sleeve so you can get the center sleeve out. (not the easiest but doable since I would not want to use fire near the tank)
Once you have most of the rubber out use a hack saw to carefully cut just through the outer sleeve. (put the blade in upside down so you can saw with the frame below) It should them be loose enough to knock it out.
That is what I would try anyway..
Date Posted: 03 April 2010 at 1:25pm
Rory, we sometimes have the same problem here as at PFF... more than one thread about the same issue.
Bushings have been changed as reported http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1780&PN=1 - Here , but I'm sure your advice will come in handy for future reference.
Posted By: grokan
Date Posted: 04 April 2010 at 10:48pm
well i just winged it with out ....pff and ya everything
went good i didn't even loosen the rear cradle bolts just
undid the front and lowered it, mind you the rears were
still rubber... a pretty easy install
