Removing door windows
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1793
Printed Date: 24 April 2025 at 6:25am
Topic: Removing door windows
Posted By: mxracer208
Subject: Removing door windows
Date Posted: 31 March 2010 at 6:53pm
How do you remove the windows in the doors?
Date Posted: 31 March 2010 at 7:39pm
Brick.
Method 2: Remove inner door panels, raise/lower until you can see what look like sewing machine bobbins.  Drill out the rivets (assuming they've never been changed).  Reassemble, but use 1/4-20 bolts and nuts in place of the rivets.
Date Posted: 31 March 2010 at 9:47pm
thank you
Date Posted: 01 April 2010 at 7:31am
Its not easy, as the glass is riveted in place.  You have to carefully drill the rivets out.    City Center glass came to my house and removed the glass from a spare door of mine to install in my 85GT when it was broken into.  I think he charged me 60 bucks for the complete re and re.
Posted By: fiero052
Date Posted: 02 April 2010 at 5:07pm
ive done a couple- you have to be patient and methodical- give your self lots of time to screw around. the doc's advice on 1/4 " screws to replace the rivets works well, i also recomend nylon lock nuts. a good time to consider replacing your outer dew wipes also (fiero Store). be carefull on your selection of screw length, to make sure they dont hit anything when operating your window- test it fully up and down before putting your inner door panel back on. Its also a good idea to get yourself a trim pad tool (cheap at Lordco), to avoid stripping the x mas tree retainers on your door pannel when you pull it.
G
Glenn
Date Posted: 04 April 2010 at 1:27pm
thanks, ive got the window out and replaced the dew wipes, which wasnt so easy and im working on replacing the locks which the previous owner glued to the door...
Date Posted: 04 April 2010 at 6:59pm
Awesome!  Did you use my brick method of removal?
