Hard Starting v6 fiero
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1812
Printed Date: 24 April 2025 at 8:35am
Topic: Hard Starting v6 fiero
Posted By: Rickrose21
Subject: Hard Starting v6 fiero
Date Posted: 12 April 2010 at 12:36pm
Hi, anyone know what could cause my fiero to have long start times?  I am not sure what this could be, injectors? fuel pump? plugs? wires? distibutor? any suggestions would be much appreciated.  Thanks
Date Posted: 12 April 2010 at 1:26pm
Make any difference whether the engine is cold or hot?
Date Posted: 12 April 2010 at 2:06pm
Leaking injectors, weak ignition, really old engine with bad rings causing loss of compression, lots of reasons.
Date Posted: 12 April 2010 at 5:25pm
If the engine is running, it idles a little rougher than my other one, but it only has 128000km on it and starts up first crank if i turn it off then start it again right away, could a fuel pressure regulator be the cause also?  the exhaust seems to be running rich as there is quite the strong gas/exhaust smell from it.  HELP
Date Posted: 12 April 2010 at 7:33pm
Really dirty fuel filter could cause this and it's easy to try.
Date Posted: 12 April 2010 at 7:49pm
just changed the fuel filter about 2 months ago,
