WTD Clear Fiero Stickers
Category: Buy / Sell
Forum Name: Everything Else Wtd or FS
Forum Description: If it doesn't fit into the above - it goes here
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1834
Printed Date: 05 April 2025 at 11:12am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: WTD Clear Fiero Stickers
Subject: WTD Clear Fiero Stickers
Date Posted: 02 May 2010 at 2:25pm
So I suppose I should explain. I have four of the stock Fiero brake calipers, and I was planning on doing them up nice and glossy red, followed by the Fiero (Like the way it's on the engine) followed by a few clear coats. Does anyone have anything that can help me out? Or does anyone know of a place that will "print" stickers?
Thanks!
Date Posted: 02 May 2010 at 2:40pm
Oh sorry, and I should clarify, the "face" of the caliper will be getting flat once I'm finished with it, so, no hole and no ribs. Will explain later.
Posted By: Fire451
Date Posted: 02 May 2010 at 2:44pm
that should look good, any print shop should be able to print off those stickers for you i believe
Date Posted: 02 May 2010 at 3:18pm
Okie dokie, gnarley. Yeah, I was planning on doing them up the same way Corvette and Porsche both do them, even though my brakes are teensy weensy. lol
Posted By: Fire451
Date Posted: 02 May 2010 at 3:21pm
other option is get them done if vinyl and put them on that way since you are clearcoating them in after
Date Posted: 02 May 2010 at 4:40pm
Talk to Ken So, he got all our club decals printed up.
Date Posted: 03 May 2010 at 8:27am
I think Dickman was selling stickers sized for putting on calipers.
Date Posted: 04 May 2010 at 11:38pm
Okie dokie, thanks for the input everybody! I'll look around!
Date Posted: 05 May 2010 at 11:01am
So, are these stickers good for an extra 10 hp or what?
Date Posted: 05 May 2010 at 1:56pm
WTF are you talking about?! These are just stickers on his calipers
man!!! They can't make you go faster.
They make it stop 20ft shorter. :)
Posted By: Fire451
Date Posted: 05 May 2010 at 3:08pm
Dr.Fiero wrote:
WTF are you talking about?! These are just stickers on his calipers man!!! They can't make you go faster.
is it only 20 ft.... crap.... i thought it was 20 meters
Date Posted: 05 May 2010 at 5:24pm
Nah Patty, but I do have some NOS stickers lying around. Expecting 50HP per sticker from those bad boys. My 14" exhaust tip should add another 20 too.
In all honesty though, I think it'll be a subtle little way to add some flair to the exterior. Something to break up all the black.
Posted By: Fire451
Date Posted: 05 May 2010 at 5:34pm
Date Posted: 05 May 2010 at 11:16pm
Thanks brother, that's the hope. Was going to wash them today, but decided I'll just cold-tank them tomorrow.
Date Posted: 06 May 2010 at 10:44pm
Romeo wrote:
In all honesty though, I think it'll be a subtle little way to add some flair to the exterior. Something to break up all the black. |
Hey, it'll be great. I'm just razzing ya.
Date Posted: 06 May 2010 at 11:43pm
RAZZ-berried.
Date Posted: 09 May 2010 at 11:12am
Our decals were done by Blitzgear. They should be able to do something. Not sure about using a sticker or vinyl. Brake calipers do get pretty hot. Hotter than an intake plenum, for sure.
http://www.blitzgear.com/catalog/home.php
Date Posted: 09 May 2010 at 11:56am
Looks like Dickman no longer carries them - nor does the fiero store (if they ever had them).
Maybe they found the heat issue was causing too many failures?
Another option would be to stencil it, and use caliper paint.
Date Posted: 09 May 2010 at 2:13pm
Funny you were just saying, I was just thinking of doing just that. lol
I still need to find a means of flattening the face myself now. Does anyone see any huge danger of welding a thin sheet of aluminum over the "face" of the caliper?
Date Posted: 09 May 2010 at 5:51pm
If it was done in TINY spot welds at the corners or something, probably not. But you really don't want to take a chance on warping them with localized heat, and having a piston bind in the bore.
Date Posted: 09 May 2010 at 5:53pm
One of the things I would research more is how a flat surface on a brake caliper would disipate heat and resist warping.
New brakes seem to have fins cast into parts of it to allow more surface area for heat disipation. Curved surfaces, if I remember my physics correctly, have larger surface areas. Also cast metal with curved surfaces, particularly if thicker in the middle, are less likely to warp. A totally flat surface with even thickness can warp due to temperature changes, unless you have areas where heat expansion of the metal can move to and return from.
Alternatively, some big brake kits (Willwood, Brembo etc) have a flat surface because they have fins mounted underneath as well as 3 or more pistons (as opposed to one or two in most OEM applications). Note that the flat surface is on top of something very thick, which might give you some offset issues.
The MINI's JCW brake kit are actually two piston Brembos with the JCW logo printed on the curved surface.
Date Posted: 09 May 2010 at 6:30pm
Yes, the heat dissapation is what has me concerned (Not so much the offset, the sheet will be thin). There is still fins on the underside of the flat piece, however there wont be much, if any, airflow to them, making convection negligable. Will have to look into some heating characteristics prior to going nuts.
Date Posted: 09 May 2010 at 8:06pm
I honestly don't belive any decal or sticker will last more than 30 days on a caliper, they just get way too hot.
Date Posted: 09 May 2010 at 10:44pm
Yeah, that is logical... I do believe it was Chris who suggested stencling in a black painted one instead, which would look very classy.
