Plastic Rivets
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1872
Printed Date: 09 April 2025 at 7:17pm
Topic: Plastic Rivets
Posted By: fiero052
Subject: Plastic Rivets
Date Posted: 21 May 2010 at 5:20pm
Hi Has any one installed the plastic rivets that hold the bottom of the door skin in place? conventional rivet gun does not seem to work- oddball mandrel size...
  glenn
Glenn
Date Posted: 21 May 2010 at 5:30pm
Yes, many times and I have the gun for that
I'll be at Capt's tomorrow, I can bring it there if you want to pick it up,
probably He has one also Dr. Fiero ??
Date Posted: 21 May 2010 at 6:19pm
I have the mega-huge one (like 2ft long) for pulling 1/4"+ steel ones.
Date Posted: 21 May 2010 at 6:41pm
Then mine is for plastic only, ( 6 inches ) short like me
Posted By: fiero052
Date Posted: 21 May 2010 at 7:35pm
that would be cool, i live close by the captain. depending on how long you will be there i might even be able to borrow and bring back all in same day. what time will you be there? or is this a cheap tool i can buy some where?
 Glenn
Glenn
Date Posted: 21 May 2010 at 7:52pm
I just have a small rivet gun for putting small items onto
things, like door lock plates and such. We ran into the
large rivet problem with Nigels car when we were re-
installing his window motor. A glass shop had the proper
tool and only charged like 10 bucks to install.
Do you want to borrow mine or the Doctor's ? I think it was cheap, not sure ??
I'll be at Capt's 10-12 only, I can leave it there for you and I don't need it back until next meeting.
Date Posted: 21 May 2010 at 8:06pm
Bring your short one. Just in case I don't make it.
I'm also not sure what time I'll be there.
Date Posted: 21 May 2010 at 8:09pm
Okay, mine is for plastic rivets for under your door.
I'll leave it with Dave anyway.
Posted By: fiero052
Date Posted: 21 May 2010 at 9:03pm
ok great. much apreciated. will see you between 10 and 12
g
Glenn
