Custom Dash
Forum Name: Build Threads
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1940
Printed Date: 19 April 2025 at 1:30am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Custom Dash
Posted By: fourpoint9
Subject: Custom Dash
Date Posted: 06 July 2010 at 8:37pm
I posted this on Pennocks but I know you guys will have good input so I'm doing a thread here too.
My plan for a custom dash using the stock speaker and defrost vents:
 I'm creating a plug to make a mold from.
 The gauge pod is still very rough and needs alot of work still
 The vents are from a Taurus X
 The vent pods are modified Home Depot Plumping section 90 degree bends
Posted By: Fire451
Date Posted: 06 July 2010 at 10:27pm
that looks good can't wait to see it when you have a finished shape
Date Posted: 06 July 2010 at 11:10pm
I'm amazed, brother. Keep this one updated - frequently.
Date Posted: 07 July 2010 at 8:22am
I really like the concept as as the others, keep us posted with updates
------------- Brian (Bassman)
Date Posted: 07 July 2010 at 10:15am
That is very cool.
Just make sure the two secondary gauges below the main one (speedo and Tach I presume) are in your line of sight and not blocked by the steering wheel or signal lever.
Would love to see the finished product.
Date Posted: 07 July 2010 at 11:22am
I also like the concept. It's clean. I've made several molds over the years and I'm concerned about the "vents". If it was me, I would make them bolt-on's. It looks like you're planning on classing them in.
Even if this is a one off, you'll have one hell of a time digging out the insides after applying the first skin.
Same goes for the dash pod.
Date Posted: 07 July 2010 at 1:55pm
I'm going to put the plug dash into my parts car to make sure the gauges are in the correct line of sight. The vent pods and small gauge holes will be filled and the two large gauge pods will have plates inside to put the gauges at the correct angle. I can make the mold multiple parts that bolt together. I'll take more pics when I get it in the parts car. Thanks for the input.
Date Posted: 07 July 2010 at 2:40pm
It's going to look so modern, and nice... What gauges are you intending to use? I know I've brought them up probably four and a half dozen times already, but Autoloc will make you a set with any backgrounds, colors, needles, fonts and trims that you want. You could get a sexy Pegasus put in them!
Date Posted: 07 July 2010 at 2:56pm
I have speedhut overlays, oil press and volts gauges already, so I bought matching gauges from them.
Date Posted: 07 July 2010 at 4:14pm
Might have to buy some warning lights too.
http://www.cbsonline.co.uk/warning-lights-441-c.asp - http://www.cbsonline.co.uk/warning-lights-441-c.asp
Posted By: Fire451
Date Posted: 07 July 2010 at 7:47pm
you bad bad man, that place is like a candy store... soo many ideas so little money. lol
Date Posted: 07 July 2010 at 10:21pm
The temp and fuel gauges have warning lights but I'll need turn signals, high beams, check engine, oil, and brake. (I think that covers it) maybe a door ajar light ? :)
Date Posted: 07 July 2010 at 11:44pm
They had all those on that site you posted. =)
Date Posted: 11 July 2010 at 7:56pm
Did some work on the gauge pod and test fit it into my parts car
Posted By: Fire451
Date Posted: 11 July 2010 at 7:58pm
looks good steve
Date Posted: 11 July 2010 at 9:26pm
Here's a photochop of the direction I'm headed with it
Posted By: Fire451
Date Posted: 11 July 2010 at 10:08pm
that will totally suit your car
Date Posted: 11 July 2010 at 11:19pm
GASP! No glovebox? What are you doing Steve? Where are you going to keep all your tickets, receipts and insurence?
Posted By: Fire451
Date Posted: 11 July 2010 at 11:28pm
Romeo wrote:
GASP! No glovebox? What are you doing Steve? Where are you going to keep all your tickets, receipts and insurence?  |
hey brother take a look at the last pic again, there is a glovebox in there
Date Posted: 12 July 2010 at 6:54am
Check your finger clearance between the lip of the main gauge pod, and the front of the wheel.
Looks like the tilt isn't tilted - if it was up a bit, you might not be able to turn if your hand was in there.
Date Posted: 12 July 2010 at 10:53am
Dr.Fiero wrote:
Looks like the tilt isn't tilted - if it was up a bit, you might not be able to turn if your hand was in there. |
Who drives their Fiero with the steering wheel tilted up, except for perhaps retired bus drivers?
Date Posted: 12 July 2010 at 10:54am
I did tilt it up and could still steer with out hitting. But I may recess the pod a little to get some more room there.
Date Posted: 12 July 2010 at 11:14am
| As low as it goes.
Date Posted: 12 July 2010 at 12:05pm
Romeo wrote:
| As low as it goes. |
Is that comment in regards to my question or to the angle of your steering wheel?
Date Posted: 12 July 2010 at 11:06pm
Both. And neither.
Woah, mind explosion imminent.
Date Posted: 18 July 2010 at 10:13am
Made covers for the holes in the pods, glued everything together and started on the center section.
Date Posted: 18 July 2010 at 2:11pm
Lookin' fab, brother.
Posted By: Fire451
Date Posted: 18 July 2010 at 5:40pm
yep definatly looking good
