Front air suspension build, how to
Forum Name: Build Threads
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1963
Printed Date: 05 July 2025 at 8:53pm
Topic: Front air suspension build, how to
Posted By: Fire451
Subject: Front air suspension build, how to
Date Posted: 17 July 2010 at 4:48pm
well there have been some questions as to how to do a front air suspension in a fiero and I have been ablr to build one up that still has the ability to use the sway bar..
First remove your stock front springs, spindles etc...
next you are going to have to drill out the 4 rivits that hold the lower spring bucket in place
you should end up with this
and
you will then have to cut the lower bucket like this
you will have to cut out your bump stop and the bump on the lower control arm
the next step is to cut and weld in the upper air bag mount
the lower bucket needs this lip removed like this
the lower mount can be bolted in with some 5/16" bolts
and then you can mock up and tack the previously bought air bag mounting plate, pull out and weld, make sure your air bag is as straight as possiable.
then clean up, paint and bolt it all back togeather
plumb you air, bolt on the rest of the stock suspension, brakes, wheel and enjoy
Date Posted: 18 July 2010 at 1:34pm
WOW thats a tone of work, looking great though.
Date Posted: 18 July 2010 at 2:16pm
Holy eff, that is an amazing amount of customization you did there. Good luck with the rest of the build!
Posted By: Fire451
Date Posted: 18 July 2010 at 5:39pm
suprisingly it only took about 4 hours / side which actually flew by, well the first side took a little longer as I was tring to figure out how to go about doing it.  Now all I need to get it the 2 fittings that I didn't get (thought I had thought of every possiable one that I would need) and put it back togeather and test it out, there will be a video of that once it happens
Posted By: Fire451
Date Posted: 24 July 2010 at 2:28pm
well here are a couple of pics:
no air
full air (sorta) compressor was getting low at this point
Posted By: Fire451
and a vid
http://www.youtube.com/watch?v=IMZh89Gtm1c - http://www.youtube.com/watch?v=IMZh89Gtm1c
Date Posted: 24 July 2010 at 4:50pm
Looks Great.  Can't wait to see it in motion as you are driving down the road.  Just might want to put a stopper of some sort so that it can't bottom out the tire while driving.
Date Posted: 24 July 2010 at 5:34pm
Very cool:)...
Date Posted: 24 July 2010 at 9:18pm
Slammin'!
Date Posted: 26 July 2010 at 12:29pm
Looks good!
I see you're able to continue to use the front shocks. Perhaps I'm jumping ahead here, but what are you going to use as dampers in the back?
[EDIT] I found the answer on page 2 of your http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1803&PN=1&TPN=1 - other thread .  (Don't know how I missed that three months ago.)
