Big Brake Booster
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1988
Printed Date: 24 April 2025 at 11:40am
Topic: Big Brake Booster
Subject: Big Brake Booster
Date Posted: 03 August 2010 at 7:11pm
Sweet ...
http://rodneydickman.com/catalog/product_info.php?products_id=279&osCsid=8ae46bc0302505f72d880bf471d18e35 - http://rodneydickman.com/catalog/product_info.php?products_i d=279&osCsid=8ae46bc0302505f72d880bf471d18e35
Date Posted: 03 August 2010 at 7:13pm
"Product not listed" brother. As for brakes, I should have a pleasant surprise for you to see next weekend.
Nevermind, you fixed it. lol
Date Posted: 03 August 2010 at 7:27pm
Larger Brake Booster $189.99
javascript popupWindow'http://rodneydickman.com/catalog/popup_image.php?pID=279&osCsid=8ae46bc0302505f72d880bf471d18e35'">Larger Brake Booster
Click to enlarge
Coming later this fall!
This larger brake booster will significantly increase the braking ability of your 84-88 Pontiac Fiero. This is a direct bolt in replacement.  Some modification to the sheet metal under the brake booster is necessary.
See the whole story on Pennocks:
http://www.fiero.nl/forum/Forum2/HTML/072173.html - http://www.fiero.nl/forum/Forum2/HTML/072173.html
Thanks go to Phil from Coventry RI for starting this larger brake booster idea.
 My larger diameter brake boosters will have the correct size/length banjo. No cutting or welding is needed. Typically a brake banjo is 9 mm in diameter. Mine will have a heavy duty 10 mm banjo.
NOTE: Do not add to cart. They are not in stock yet.
Shipping to be determined after I have them in stock.
Date Posted: 03 August 2010 at 7:39pm
Huh?...lol
Date Posted: 03 August 2010 at 7:57pm
Then there is this from FS...I just need part details, need to call Blair:)
http://www.fierostore.com/Product/Detail.aspx?s=56057&lp=56820 - http://www.fierostore.com/Product/Detail.aspx?s=56057&lp =56820
Date Posted: 04 August 2010 at 8:38pm
Ok, after reading I am going to wait for Rodney's Booster, and I have arrangement for a Big Bore cylinder, install both your good, if one then Booster first, then Cylinder.
Next year:)...Xmas presents:)
