Tire Tech Info
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1997
Printed Date: 18 January 2025 at 8:56pm
Topic: Tire Tech Info
Subject: Tire Tech Info
Date Posted: 07 August 2010 at 8:43pm
Preparing for tomorrow...need to read up and test
Air Pressure vs. Wet Performance
Lea esta página en español
Most drivers realize that tire load capacity is determined by tire size and inflation pressure. Larger tires and higher inflation pressures provide more load capacity, while smaller tires and lower tire pressures provide less.
An underinflated tire will tend to wear the shoulder areas of the tread faster than the center. This is because there is insufficient air pressure to allow the center of the tread to carry its fair share of the weight. A correctly inflated tire receives appropriate support from the contained air pressure to provide an even distribution of load across the footprint. And while most drivers recognize that this has a significant impact on tire wear, rolling resistance and durability, only a few realize it also has a noticeable influence on how effectively the tires can resist hydroplaning to maintain wet traction.
As they taught us in physics class, you can compress and move a gas quite easily, but you cannot compress liquids and it requires significant energy to move them. Our tires easily push air around and through their tread designs as they roll. However, when water pools in highway ruts and builds up on the road surface during rainstorms, the vehicle's speed and weight, as well as the tires' tread designs, tread depths and evenness of their footprint pressures determines if and when the tires will be forced to hydroplane.
One of the ways tire manufacturers evaluate their products' hydroplaning and wet traction effectiveness is by driving them over a glass plate covered with a specific depth of water. The water is dyed for better visibility and to allow high-speed cameras in underground rooms to photograph the tires from below. Michelin has provided several photographs of its HydroEdge premium All-Season tire to help illustrate this tech feature.
35 PSI The first photograph shows a tire properly inflated to 35 psi sitting still in the water on the glass plate. This provides an accurate idea of the tire's footprint size and shape.
The black area is where the tire's rubber compound is pressed on the glass, and the green areas identify water in the tire's circumferential and high-angle lateral grooves, and on the remainder of the glass plate.
A properly inflated tire will have enough pressure in the center of its tread to resist collapsing.
35 PSI In Motion The next picture is of a tire properly inflated to 35 psi, driving across the glass at 60 miles per hour. If the glass plate were dry, the footprint size would be virtually identical to the first picture because air does not prevent the tread from contacting the plate. However with standing water on the plate, the tire's tread depth and tread design must evacuate the water as the tire rolls across the plate at 88 feet per second. You will notice that the footprint still shows good contact with the plate, but is slightly smaller than the static tire's footprint.
A tire that is slightly underinflated will apply less pressure to the center of the tread and it will become slightly concave.
30 PSI In Motion The next picture is of a tire inflated to only 30 psi, again driving across the glass at 60 miles per hour. With the same amount of standing water on the plate, the center of the tire's tread is lifted as the tread design unsuccessfully attempts to evacuate water as the tire rolls across the plate. You will notice that the actual footprint shows poor contact with the plate and is significantly smaller than the footprint in the photograph of the properly inflated tire.
A tire that is significantly underinflated will allow the center of the tread to collapse and become very concave, trapping water rather than flowing it through the tread design.
25 PSI In Motion The final picture is of a tire inflated to only 25 psi, driving across the glass plate at 60 miles per hour. With the same amount of standing water, the water lifts the center of the tire's tread as its footprint rolls across the plate. You will notice that the actual footprint shows little contact with the plate and has been virtually reduced to the shoulder areas.
Members of the Tire Rack team had the chance to experience the effects of air pressure on wet performance at Michelin's Laurens Proving Grounds. Drivers were given the opportunity to compare identical cars on a wet-handling course with the exception of one car having four properly inflated tires (35 psi) and the other car having significantly underinflated tires on the rear axle (25 psi).
While driving at the edge of a tire's ability in wet conditions is challenging, the car with the properly inflated tires provide handling that was predictable. Driving the car with the underinflated rear tires proved to be much more difficult to drive and forced the driver to slow down to retain control, producing lap times that were several seconds slower than the properly inflated car.
While tire manufacturers can develop tires with great hydroplaning resistance and wet traction, poor maintenance of tire inflation pressures can make a great tire awful.
Adjust your tire pressures as indicated on the vehicle tire placard or in the owner's manual. Check your inflation pressures at least once a month and before highway trips.
Air Pressure/Load Adjustment for High Speed Driving
Driving at high speeds certainly helps make a trip go faster; just ask any driver who has gone "flat out" on the German Autobahn. However with the exception of events like the Silver State Classic's Open Road Rally or a driver's school on a racetrack, it's difficult to find a place that allows unlimited speeds! Remember, the tires on the vehicle should be properly sized, inflated and inspected if you plan to drive fast because the tires will be subjected to tremendous stresses.
Because of the weight they bear, pneumatic tires' sidewalls bulge and their treads flatten as they roll into contact with the road. This results in dimensional difference between the tire's "unloaded" radius (i.e., between the center of the axle and the top of the tire) and its "loaded" radius (between the center of the axle and the road). The engineer's call the difference between the two radii "deflection." Increasing vehicle speed will cause the tires to deflect quicker and increasing vehicle load will cause the tires to deflect farther (if tire pressure isn't increased).
Consider that a 225/45R17 91W Standard Load tire (with a 25-inch overall diameter) will roll about 835 times every mile. Although the number of tire revolutions per mile doesn't change significantly as speed climbs, the revolutions per second become daunting. While the 225/45R17 91W-sized tire rolls a rather comfortable 7 times per second at 30 mph, this same tire will roll about 16 times per second at 70 mph on an American Interstate and an amazing 35 times per second during a 150 mph cruise on the German Autobahn. Thirty-five tire revolutions per second means that the tire is transforming from its unloaded to loaded shape and back every 3/100th of a second.
The European Tyre and Rim Technical Organization (ETRTO) establishes the standards for tires sold in Europe, and recognizes that the tire's deflection must be minimized and controlled in order to surpass high speed driving stresses. In order to accomplish this, the tire inflation pressure recommendations and the tire's rated load capacities are customized when speeds exceed 160 km/h (99 mph) for all tires up to and including a V-speed rating, and when speeds exceed 190 km/h (118 mph) for all tires that are Z-speed rated and above.
The Autobahn's unlimited speed opportunities explain why many German vehicles identify alternate tire inflation pressures to accommodate higher than North American highway speeds and heavier than typical two-passenger loads. In order to accommodate higher speeds, the tire size and inflation pressure recommendations are tuned beyond what is branded on the tire's sidewalls. These increases in recommended tire pressure are usually determined by agreement between the vehicle and tire manufacturers. In the absence of such an agreement, apply the following:
Beginning with the vehicle manufacturer's recommended tire pressure for normal highway conditions, tire inflation pressures are initially increased and then the tire's rated load capacities (branded on the sidewalls) are reduced as speeds climb.
In our example shown below, the vehicle manufacturer's recommended 35 psi for a 225/45R17 91W Standard Load tire installed on a vehicle initially rises in 1.5 psi increments for every 10 km/h (6.2 mph) increase in speed until the inflation pressures max out with an increase of 7.5 psi when the vehicle's top speed has increased 50 km/h (31mph). Then as the vehicle's top speed continues to climb, the rated load capacity of the tire is reduced in 5% increments for every additional 10 km/h until the vehicle's top speed has increased an additional 30 km/h (18.6 mph). In this case the 225/45R17 91W Standard Load size's rated load capacity of 1,477 lbs. is reduced to 1,255 lbs. when applied to a vehicle with a 270 km/h (168 mph) top speed.
For W-Speed Rated Tires
Vehicle
Top Speed
Required Tire
Pressure Increase
Tire Load Capacity
% of Branded Maximum
W-Speed Rated Tire
35 psi O.E. Example
mph km/h psi bar % of value branded on sidewall psi lbs.
118 190 0 0 100% 35.0 1000
124 200 1.5 0.1 100% 36.5 1000
130 210 3.0 0.2 100% 38.0 1000
136 220 4.5 0.3 100% 39.5 1000
143 230 6.0 0.4 100% 41.0 1000
149 240 7.5 0.5 100% 42.5 1000
155 250 7.5 0.5 95% 42.5 950
161 260 7.5 0.5 90% 42.5 900
168 270 7.5 0.5 85% 42.5 850
NOTES: Never exceed the maximum cold inflation pressure branded on the tire's sidewall.
If a vehicle's horsepower and top speed are increased significantly, confirm that the required adjustments are made to the tire pressure and/or load conditions beyond the vehicle manufacturer's recommendations using the following charts.
Date Posted: 07 August 2010 at 10:40pm
Y-Speed all the way, baby. This is a nifty little read Brian. Normally when one thinks of dragsters and their under-inflated tires, it would almost imply that low-pressure equals better traction, but it's interesting to note that on a normal tire it actually hurts peak traction to lower the pressure, and that's ignoring the increased sidewall flex that comes with lower pressures.
Date Posted: 07 August 2010 at 10:57pm
Just quick note, dragster tires are a totally different tire design and they have a growth factor to take into considering.  Watch a drag race tire on a top fuel car, at rest it is flat, however as the car accelerates, it balloons out and gets taller.  When it is short, it gives the car an effect of having a small tire and gets better gearing, as the speed increases the tire grows and gets taller.  This gives the car an effectively taller gearing for better top end speed.  Some of these tires have a 25% growth factor.  Thats like having an entire extra gear at the top end of the track.
Date Posted: 08 August 2010 at 6:29am
Where does the articles refer to dragster application?...lol...that's a different article all together
Date Posted: 08 August 2010 at 10:52pm
Nonono, I was just saying, it's interesting to note how different they are in that wrinklers benefit from the low pressures, whereas street tires are hindered by it. And yeah I have watched my fair sure of fuelies to know what you're talking about there David, it's actually rather ingenious.
Posted By: marcelvdgn
Date Posted: 09 August 2010 at 11:20pm
Brian
Thanks for all this info as it answered a lot of my questions and thoughts.
loved the pics of the tread patterns on the wet glass
I was thinking of changing my tire sizes and ratios to get a better 50/50 weigth ratio in relation to tire footprint.
currently running 225 50 16 all the way arround which actually makes the front feel light even though the tires are pretty good (toyo proxes fz4).
my car weighs 500 kilos up front and 800ks in the back (ran over the truck scales a while back)
but both front and back have the same contact patch area
front patch area should be smaller than the rear to even things out
my thinking takes me to 205 up front and 255 out back.
any comments from the group???????
Date Posted: 10 August 2010 at 7:16am
Tire Rack has a lot of info, KUHMO & TOYO also in their competitive sections especially for autocross...glad it helped Marcel:)
Date Posted: 10 August 2010 at 12:31pm
205 is pretty tiny. You're sure you wouldn't rather just stay 225 up front, and then bump the rears accordingly?
Date Posted: 10 August 2010 at 3:17pm
I would agree considering how big this car is, wider the better for tracktion and control
