newbie questions about racing a Fiero
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2029
Printed Date: 24 April 2025 at 5:22pm
Topic: newbie questions about racing a Fiero
Posted By: bearmtnmartin
Subject: newbie questions about racing a Fiero
Date Posted: 22 August 2010 at 9:00am
Hi All,
I am in the market for a new Hornet race car. Thats an entry level class at our 1/4 mile paved oval in Agassiz. It allows for a N/A 4 cylinder of up to 150 hp. Right now I share an Asuna Sunfire with a friend, but we want our own cars for next season. I want a rear wheel drive this time, and I am finding my options are pretty limited, but the 4 cyl Fiero seems to fit the bill. My problem of course is that on paper it looks very uncompetetive, being heavy and underpowered. Our current car weighs about 2200 pounds with the interior stripped out and a pretty good cage, and it is 140 hp stock, although we probably have slightly more than that due to a couple little tweaks. We get absolutely blown out of the water by the Hondas. Mostly due to the fact that it pushes so bad on the corners.(and our lack of driving skill) At any rate, i don't want to be beaten even worse, so any lack of power needs to be made up by improved cornering.
So here are my questions.
  • how much power can that pushrod engine make with some basic porting and a cam change? Maybe if I had it apart, a little off the head?
  • how much might it weigh if the interior, lights etc was stripped out?
  • how fast is it in second gear? (most of the cars run in second only. 17 seconds a lap means no time for shifting.) We had to swap a different tranny into the Asuna and change the computer to get the speed out of second. We need to hit about 110 km on the straights and have really good torque coming out of the turns at probably 80 or 90.
  • how adjustable is the suspension for rear toe and front and rear camber?
  • Where is the fuel tank located?
Thanks in advance for the help.....
Date Posted: 22 August 2010 at 9:40am
The 4cyl Fiero HP varied from 92hp to I think 97hp the best motor for power is the 87 duke, as it does not have balance shafts to rob power.  The duke is very torquey motor, and with a good driver can beat a 5.0 Mustang through an intersection.  Getting the weight down to 2200lbs if very easy, as I believe a full interior car weighs in around 2450lbs.
      With head work and cam work 140hp is attainable from a duke, however reliability becomes an issue at or above 150hp.
       2nd gear I don't think will get you near 110, you would need 3rd gear for that.  However with the close ratio's in the trans I don't see that being an issue.   The duke has no issue with torque at low rpms coming out of a corner.
Suspension is very adjustable, most alignment shops find there to be too much adjustment and can never get the damn thing right.
Fuel tank is located between the seats.  Yes you heard right, its between the seats.  That huge hump in the middle of a Fiero, thats not for a driveline, LOL.  GM put it there to keep weight distribution near perfect regardless of an empty tank or a full tank.
Small bits of info that you might find useful.
All 86-88 Fiero's have a factory hydraulic roller cam.  All 87-88 Fiero's use a DIS ignition system.
Head decking up to about 10.5-1 has proven to increase power especially when used with higher octane fuel and a larger duration cam.
You might want to consider the duke and then transplanting the 4spd Muncie from a V6 Fiero into the car as the Muncie will handle much more abuse. (not that I think you will break the Isuzu 5spd thats in the car stock, but the Muncie is a stronger trans)
Hopefully you can find some of this useful and a few of the people like Colby and Brian that race Fiero's can post up some extra info.  Colby Races a 4cyl Fiero on the Autocross tracks, so he might be able to give you a better more well rounded reply than me, as I drive V6 and V8 Fiero's.
Date Posted: 22 August 2010 at 10:07am
Thank you for the quick reply. That actually sounds fairly promising. I thought they were a lot heavier. I have read anywhere up to 3000 pounds. The fuel tank location is great as it means I wouldn't have to use a fuel cel. The second gear thing bears some thought though, as no one ever seems to do well in third gear. Its usually just too tall, and I am not sure a Fiero would be any different. How about a tranny from a different pontiac model with taller gears? Or a different rear end perhaps. As long as I can lurch it onto the track, all I really need is really good torque between about 80 and 110km/h. Every 9 seconds for 100 laps........
Date Posted: 22 August 2010 at 10:42am
i wouldn't worry about second gear.  This motor is a low reving high torque engine with a wide smooth power band.  Even in third you will be ok.
Like you said, you will make up for any slowness in the straights when you get to the corners.  Put some money into brakes and tires and you'll be impressed.
There are so many well documented modifications for these cars.  I can't imagine you having any trouble building what you want.
There are several talented guys on this list that together could make anything I think.
And as a bonus, the good Captain has the perfect car in his back yard.  Ask him about it..
Cheers,
Date Posted: 22 August 2010 at 11:59am
My '84 (notchie, 4-banger, manual) weighs 2400 lbs.
My '86 GT (fastback, V6, auto) weighs 2650 lbs.
Keep in mind there is no separate "rear end". You have everything in the one transaxel. Having said that, yes, there is a selection of Fiero transaxels with different gear ratios.
I wouldn't worry about using a Muncie over a Isuzu tranny for the durability factor. Use whatever tranny gives you the gear ratios you're after. People use the Isuzu successfully with V8 swaps in their Fieros.
A little 4-banger duke isn't going to be blowing up transaxels on an oval race track.
Date Posted: 22 August 2010 at 1:28pm
That's not completely true, the front camber on stock 84-87 cars has only a single adjustment which is made by rotating the ball joint 180 degrees, fortunately you can buy ball joints like http://rodneydickman.com/catalog/product_info.php?cPath=26_44&products_id=201 - this one which will give you more adjustment.
In my 5-speed (Isuzu) duke, the top speed in second gear is about 80km/h. This isn't so much of a problem in autox since the speeds are lower, I think the fastest I've gone in my car during autox was just below that. If I remember correctly, the peak torque for the duke is around 3k rpm, and coming out of 2nd (shifting at 5k rpm) into 3rd you should be somewhere near there. Some of the 84's had a performance 4-speed transmission which I believe gave them a faster 0-60 time by a second or two (compared to the 5-speed in my car). There's actually a scan of an old magazine in the archives ( http://www.captfiero.com/paperbased/Mag%20Scans/RdTracSep83b.pdf - here ) with some performance info on the 84 duke with the 4-speed performance trans.
Not sure what to add for power. The stock 92hp likely won't enough and most people seem to think the duke can't handle anywhere near 150hp. I've left my engine stock on purpose since the car is also my daily driver so I wanted it to be reliable. Plus when I replaced my engine with a rebuilt one I had no idea I would be autoxing.
Oh yeah, in case you're confused, the "Iron Duke" is the name for the 4cyl in the Fiero.
Date Posted: 22 August 2010 at 1:37pm
You all out to lunch...lol...JOKING
Our suspension has NO real ability to adjust especially for racing (track/road), autocross or drag sure, but with most R-Comp tires, our configuration (and I have almost all the upgrades) get eaten up...trust me, I have the worn tread to prove it and the testiments from the shops who have done my alignments in frustration as they cannot get the settings for the application needs I have.
Date Posted: 22 August 2010 at 1:43pm
Actually I've been meaning to ask you, what are your alignment settings? I'm planning to replace my front upper ball joints with the adjustable kind (actually I'm just waiting for the parts to arrive) and so I'll need to get an alignment done.
Date Posted: 22 August 2010 at 5:59pm
Thanks for all the input. I may go this route. My other options are an older Celica or a Pinto. There really isn't much else out there for a rear wheel drive econobox any more. Part of the equation is that it is very cheap racing. We are not allowed (don't get caught!) any modifications, and we have to run a 65 series tire. No headers, no chips, no cold air intakes, etc. We are allowed a cherry bomb muffler, which adds more noise than horsepower. Its a lot of fun and I highly reccomend it to anyone who wants some cheap excitement.
For the record, I paid 300 dollars for my Asuna, and we have a total of about 2000 dollars invested for car, a seasons worth of race entries, racing gear, and upgrades to date. We spent a little more than planned because we had to do a tranny and ECU swap to get the gearing right. But I have also won 250 dollars to date, and not all of that went to beer But that car needs nothing now, and next year should be very cheap unless we pile it into the wall.
Date Posted: 22 August 2010 at 6:02pm
[/QUOTE]
I can email or scan my last alighment, but max is still not enough
Date Posted: 22 August 2010 at 6:04pm
Hey Brian with the moog adjustable's up front and the camber kit in the back you should be able to get enough camber in the tires to actully eat the inside of the tire right up.  If you can't you either don't have the right ball joints or the shops are being lazy and are not changing the caster. (which requires removing the upper control arm bolts)
End of day, if you are racing on a budget then you can only go so far...Celica's are great, I see one often, and older mid 70's that a guy has put a lot into...
Have fun, be safe
Date Posted: 22 August 2010 at 6:20pm
Ok, you had to question...OMG
As you know, I have both above, here is my last stats, and these are better than what In had from Dales and I was under the car with Jason helping trying to negative camber...below is the Toyo R888 spec, notice the camber
Setup Guidelines
  •  Operating Temperature: 71°c to 104°c (160°F to 220°F) I was lucky on a 30+c day on the track, after each round I tested with David's digital temp gauge and did not peak past 155 F
  • Tire Pressure:
VEHICLE
WEIGHT
COLD INFLATION
PRESSURES
HOT INFLATION
PRESSURES
Less than 800 kg.
17 -  22 psi
22 – 29 psi
800 kg. – 1000 kg.
20 – 26 psi
24 – 32 psi
1000 kg. – 1400 kg.
23 – 27 psi
28 – 40 psi
More than 1400 kg.
27 – 35 psi
37 – 42 psi
  • Camber: -2.5° to -5.0° (the Proxes R888 generally  requires less negative camber than the Proxes RA1)
  • Caster: As much positive as possible
  • Shaving: 4/32” is recommended for competition  (grooves remain until 2/32”)
  • Rim width: a tire size that falls within the range of midpoint to maximum rim widths is recommended
At Burquitlam Auto (Which has provided me the BEST alignment to date):
FRONT (all degree):
Caster: left 5.5 / right 4.6
Camber: left -0.2 / right -0.2 (Killing the tires, minimum -2.5 required, I am WAY off). Max out of 5 alignments in 3-4 years has been -0.75, so maybe time to look at other options and invest money here, or budget for tread...
Toe: left .010 / right 0.15 / total 0.25
REAR (all degree):
Camber: left -1.2 / right -1.5
Toe: left 0.05 / right 0.05 / total 0.10
Date Posted: 22 August 2010 at 6:24pm
[/QUOTE]
Have fun, be safe
[/QUOTE]
Hornet Racing is designed to be cheap. Its an entry level class. You can spend all you want in racing, and the little baby I am building for road racing will be over 20 thousand just for the car by the time I am done. But I am not sure at this point whether it will be as fun as going around a closed track in a 300 dollar beater with 29 other cars bumping and rubbing!
Date Posted: 22 August 2010 at 6:29pm
If I had the chance in my youth, I would have started to Kart, pretty affordable start, then build to the Hornet.
I have friends who are in many types of racing, all cost something, but getting back all that fun is what it's all about...I luv having those stats after a autox day and out of 60 or so, I'll be in the top 15 with my FIERO...that feels good
Keep us posted, post some pics
Date Posted: 22 August 2010 at 6:52pm
I am not actually sure Hornet isn't cheaper than Karting. A decent used Hornet can be had for 5 or 600 dollars ready to run. Often including race suit. We just looked at a Civic and decided against it because i wanted a rear wheel drive. It sold for 600 dollars to a kid who is now running rings around me.
Date Posted: 22 August 2010 at 7:41pm
Brian's been doing very well in autocross this year with his Fiero, and at the last event he was 10th out of 40 drivers. Quite an accomplishment considering some of the high price horsepower he was competing against. However, in 9th place just ahead of Brian was... a 1989 Honda Civic.  That ugly thing went like stink!
Date Posted: 22 August 2010 at 8:47pm
I know it. most of the Hornets are Hondas. I don't think most of those guys even know where their suspensions are and yet they corner like a slot car. Its a little discouraging!
Date Posted: 22 August 2010 at 9:48pm
HI bearmtnmartin,I allso live out in Agassiz an have 2 Fieros,i know wheres
theres a 86 2M4 that might work for you in the Hornet class over at the
track, allwas wondered how the Fiero would do in that class,you would have
to do a few mods to the Fiero to run on that track,but it would be nice to
kick those Honda guys butts a few times.the 86 Fiero is in a farmers field
just sitting there with all of his outer junk,vary cheep or free!!no motor,no
glass no interiors,just about reddy for the track as is LOL
cheers
Date Posted: 23 August 2010 at 7:24am
He only beat me that day by 200th of a second...if I was more competitive and social that day I know I would have taken place over him:)
Date Posted: 23 August 2010 at 8:04pm
cheers
Well, I would be interested in looking at it except for it not having a motor.... I would rather start with a complete car, but thank you though.
Date Posted: 23 August 2010 at 8:09pm
Drop in a V6. Then you'll be somewhat competitive. Drop in a V8 - you'll win for sure.
Date Posted: 23 August 2010 at 8:19pm
Are you feeling alright?...lol
Posted By: Matt
Date Posted: 23 August 2010 at 10:18pm
Hornet class is 4cyl only.
I wanna go fast.
Date Posted: 24 August 2010 at 10:03am
He only beat me that day by 200th of a second...if I was more competitive and social that day I know I would have taken place over him :)
Brian, should that have read, "...if I was more competitive than sociable that day..."
If so, I'll accept part of the blame as I was a passenger in your GT for at least three of your runs!
Date Posted: 24 August 2010 at 5:31pm
Killed the last Civic I raced... I'm thinking with an extra two cylinders strapped on I'd rip their faces off.
Date Posted: 24 August 2010 at 7:20pm
Tristan, read the following and then go to your room.
Posted By: Matt
Date Posted: 24 August 2010 at 7:28pm
And they usually only allow steel body cars.
General Rules to oval track hornet racing can be found here.
http://www.pentictonspeedway.com/hornetsrules.html - http://www.pentictonspeedway.com/hornetsrules.html
I wanna go fast.
Date Posted: 24 August 2010 at 7:38pm
"Car horns, radios/speakers and third (high mount) brake lights must be in working condition."
Radios and speakers must be in working condition? Now that's just weird!
Posted By: Matt
Date Posted: 24 August 2010 at 7:43pm
Has to do w/ weight. Could have a gutted stereo or magnet-less speakers. How do you know if ppl have tried to lighten their car by gutting stereo components? Get them to test it to see if it works!
Every lbs counts!
I wanna go fast.
Date Posted: 24 August 2010 at 7:47pm
Every lbs counts!
Fill every body cavity (on the car!) with helium.
Date Posted: 24 August 2010 at 9:28pm
We have dropped the car radio rule. And there is really no standardised rule book for hornet class. Every track is different. So at Agassiz a Fiero is OK. And weight can actually be your friend, if it is in the right place. At least one car was DQed a few years ago for filling part of his cage with lead.
Date Posted: 25 August 2010 at 6:51pm
I am guessing the "Hornet" names stems from the engine sound of a 4cyl which is why all cars must be a 4cyl?  Just curious.  I would bet a Fiero with an HO Q4 would be interesting.  Those are cheap motors that made nearly 200hp in stock trim and could be wound out to 240hp. Pretty much sounded like a sack of hornets even in there best days.  You can still find entire cars with the Q4's kicking around for 500 bucks.  Most are now in need of a head gasket though as they have not been made in nearly 20 years.
Date Posted: 25 August 2010 at 7:34pm
Doesn't an Ecotec bolt up to the tranies?  Aren't they pretty darn powerful?
Date Posted: 25 August 2010 at 7:49pm
Way too cost prohibitive.  Ecotec swaps start at $5000 and go up I have seen people drop 13,000 on a running Ecotec swap that was not much faster than a hopped up 2.8 V6.
Date Posted: 25 August 2010 at 10:30pm
Hornet is a stock car class. You have to run it the way it was made. Thats why car choice is so important. The guys who choose the wrong car run way at the back....
Date Posted: 26 August 2010 at 5:37pm
Alright, so we're all in agreement then...
Nitrous.
