Wonky Alternator
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2063
Printed Date: 24 April 2025 at 6:39pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Wonky Alternator
Subject: Wonky Alternator
Date Posted: 05 September 2010 at 9:10pm
Well, she couldn't kill me, so Gretchin did the next best thing: She broke. lol
Current condition is that the Voltage Gauge is reaching into the red, where it then bounces off of the regulator (Which can be heard from the alternator itself). Alternator is putting out too much power to try and overcome through lights, heater fan and stereo (Simply slows the bouncing effect). I know it may seem crazy, but I believe it may actually be the battery. I noticed when the alternator would disengage, the lights would dim. As it got worse, the engine would actually follow the bouncing too (Power would fall off when the alternator disengaged) and she seems to be having trouble turninig over. Just my own observations, however. Hopefully I'm wrong, otherwise this will be the... Fourth battery I'll have had to replace in just over two years.
Date Posted: 06 September 2010 at 10:49am
No one? No ideas?
Date Posted: 06 September 2010 at 3:34pm
The charging voltage should NEVER go over 14.4 volts for a liquid electrolyte lead-acid battery. Regardless of the load on the alternator. That regulator is going to cook your battery. Doesn't take long either.
It does sound like there is something drawing tons of current. This is likely the root cause of the regulator dieing. The whole case overheats and takes the diodes and/or the regulator with it. I have a DC clamp meter here if you want to come over. I can measure very high loads without having to disconnect any wires.
Date Posted: 06 September 2010 at 3:36pm
Romeo wrote:
No one? No ideas? |
Put the factory heat shield on that puppy.
Date Posted: 06 September 2010 at 6:48pm
One thing I did not check at the track was that your battery cables were tight. A loose or damaged battery cable can create a resistance point tricking the alternator into charging wide open. Also double check all your grounds. Make sure you have a good battery to chassis, battery to block and block to chassis ground. I know the battery to chassis is a bit redundant, but I like to have it there. Also as an extra point to help, I run an 8 gauge wire direct from the alternator charge stud to the power distribution block that is on the fender just below the main wiring harness connector. (main power distribution just rearward of the battery) Again its redundant if the rest of your wiring is correct, but I am all about the fail safe when it comes to electrical. You can never have too many grounds and I like to have alternatives if a main system starts to fail.
Date Posted: 06 September 2010 at 7:54pm
Capt Fiero wrote:
One thing I did not check at the track was that your battery cables were tight. A loose or damaged battery cable can create a resistance point tricking the alternator into charging wide open. Also double check all your grounds. Make sure you have a good battery to chassis, battery to block and block to chassis ground. I know the battery to chassis is a bit redundant, but I like to have it there. Also as an extra point to help, I run an 8 gauge wire direct from the alternator charge stud to the power distribution block that is on the fender just below the main wiring harness connector. (main power distribution just rearward of the battery) Again its redundant if the rest of your wiring is correct, but I am all about the fail safe when it comes to electrical. You can never have too many grounds and I like to have alternatives if a main system starts to fail. | Thought of that myself, sadly, not the case.
Damien, I just got into the country, does tomorrow work for you?
And alright Patty, you win. I'll put the glorified pop can back on. lol
Date Posted: 06 September 2010 at 8:05pm
PM'd
Date Posted: 07 November 2010 at 12:23pm
Well, rebuild kit number number two (And as a result, battery number two) and the alternator is still full-fielding 24/7. I made sure the voltage regulator was hooked up properly in there, and everything was torqued nice. I have the glorified pop can attatched (Heat shield). Everything was done perfectly, and still this stupid thing isn't working still. Before I invest in a brand new alternator, anyone have any last ideas about why the stupid thing could still be going nuts?
Date Posted: 07 November 2010 at 12:55pm
I'm not at home so I can't send you a link, but there are some excellent websites describing how to check all components in an alternator. Heck, if you do a search here (or was it Pennock's?), I might've mentioned them in my thread describing my own alternator repair a year or so ago.
You need to be checking/replacing the brushes, diode-trio, rectifier, regulator, stator, field... I think that's it.
Date Posted: 07 November 2010 at 2:52pm
You replaced the stator? And what do you mean check the field? As for everything else, I replaced all that and the bearing...
Date Posted: 07 November 2010 at 9:53pm
I am wondering if you have a dead short in the windings or something. At this point, I would just say screw it, break down and buy a new one with a really good warranty. Just make sure and buy the one for A/C as it is rated at about 1.5 X the output. Bosch makes a good one, I put a Bosch one in Shirley's Fiero over 5 years ago and she drives it in rushour traffic 5 days a week and no problems from it at all. Works perfect.
Date Posted: 07 November 2010 at 11:08pm
Take your friend Damien's offer and go to his place where he can determine if the load is indeed external or internal to the alternator.
I doubt there is an internal short but it is possible. Were you not having this very problem before and this is why you purchased this used alternator in the first place???
If so, what are the odds that two alternators have the same internal short?
Date Posted: 08 November 2010 at 1:07am
Romeo wrote:
You replaced the stator? And what do you mean check the field? As for everything else, I replaced all that and the bearing... |
Sorry, I got mixed up with a couple of the terms as I wasn't home when I last posted and was a little rushed. The items I was suggesting you check and replace as necessary were the brushes, diode trio, rectifier, regulator, stator, and rotor. Yes, I replaced the stator as it was toast.
Patrick in http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1485&KW=Patrick&PN=0&TPN=1 - This thread wrote:
]Well, I finally fixed my alternator.
With an automatic tranny and a V6, the alternator wasn't going to drop out the bottom (or out the top or out the side, etc). So I took out the four case bolts and "cracked" it in half while it was still mounted. I was then able to get both halves out the passenger side wheel well.
Went to Edmonds Starters & Alternators, 532 East Broadway, and bought a set of brushes and a diode trio. Total cost - $5, no tax. Such a deal.
Anyway, it turned out that not only was the diode trio shot, but so was the rectifier and the stator! I can't believe the alternator was producing any current at all, but I've been driving around this way for two months (with a dim volt light reminding me that something wasn't quite kosher).
Luckily I had another alternator here that I could rob parts from and I used it's rectifier and stator/front case/pulley.
I reassembled the two halves while in place on the motor and started her up. Put a volt meter on the battery - 14.45 volts at idle. I'm a happy camper.
Oh, and I put a heat shield on the alternator as well.  |
There are plenty of good websites with helpful information on alternators. Have a look http://jeep.zerok.ru/index.php?page=39 - Here , and http://www.tpub.com/content/construction/14273/css/14273_51.htm - Here , and http://www.aa1car.com/library/charging_checks.htm - Here at sites that I used.
Capt Fiero wrote:
Bosch makes a good one... |
If I remember correctly, it was a brand new looking Bosch alternator that Tristan picked up at Pick-a-Part.
Date Posted: 08 November 2010 at 7:45am
Patrick, just to clarify, the diode trio IS the rectifier. In your write up above every time you mention "rectifier", I think you meant to say regulator.
Date Posted: 08 November 2010 at 8:16am
| Only one alternator. I replaced my first alternator because I wanted a higher output alternator as a pre-emptive move for the sound system, however, everything seemed to go downhill a few months back (On the way to autocross, as it were).
It should also be noted that every now and then, it will work normally for a little while, but after a sufficient jolt (Hard 1-2 shift, for example) it will go back to being screwy. I think I may just do a mix of what David and Patty said, I'll head to Edmunds Alternator and either get them to fix this one, or simply pick-up another from them.
Date Posted: 08 November 2010 at 11:05am
Dawg wrote:
Patrick, just to clarify, the diode trio IS the rectifier. In your write up above every time you mention "rectifier", I think you meant to say regulator. |
No no no, what I said IS what I meant.
Damien, the diode trio and the rectifier (bridge) are separate entities. Have a look at the diagrams from http://jeep.zerok.ru/index.php?page=39 - Here .
Exploded View of Model 12SI Alternator
Exploded View of Model 17SI Alternator
Date Posted: 08 November 2010 at 11:58am
Oh well. In either case I'll make this Edmund's Alternators' problem to deal with.
Posted By: kharmata
Date Posted: 08 November 2010 at 12:39pm
Charging basics. just in case.
http://www.bcae1.com/charging.htm
Oh and a good warning.
Warning!
Some people tell you that you can check your alternator
by disconnecting it from the battery to see if the
alternator can produce enough current to keep the engine
running. BAD IDEA! Disconnecting the battery will subject
the voltage regulator to significant voltage spikes which
may cause an otherwise good alternator to fail. Even if
there were no damaging spikes, this test would not
indicate whether or not the alternator was good because
the engine will easily run with a weak or failing
alternator.
Date Posted: 08 November 2010 at 1:15pm
Yep yep. I know just how well the alternator is working - it cooked an 8-month old battery in no time flat.
Date Posted: 10 November 2010 at 2:53pm
Alright, so before I order in another alternator from Edmunds (I already have mine out) is there anything else that could cause the alternator to full-field all the time? Especially something that the in-car voltage monitor could pick up?
Date Posted: 10 November 2010 at 3:06pm
Actually, a more specific question: Could it be the actual connection to the regulater (The wires) that's causing the failure?
Date Posted: 10 November 2010 at 6:59pm
Absolutely it could be that.
When I had lost the feed to the reg on my car, it would run ok due to self excitation from the altenator residual flux, but when I loaded it (Like turning on the headlights), the engine would skip a beat and the voltage of the whole car would go down.
No reg = no field current = low voltage under load.
------------- 86 SE 3.4
Date Posted: 10 November 2010 at 8:21pm
Could it promote the opposite effect? If the wiring was wonky (ALLITERATION! YES!) could that cause the alternator to always try and pump out max voltage?
Date Posted: 15 November 2010 at 10:03am
That's more a sign of a busted voltage regulator (Stuck on boost).
An altenator requires higher field current for the voltage to go higher. This could only happen with good connections, and a reg stuck on boost, maxing out the field current.
Your voltage should not exceed 14.2 or so. Higher and your bat will cook.
Date Posted: 15 November 2010 at 11:40am
Well, I took a reading of the new alternator and it's at 14.7V Maybe the battery will take that?
Posted By: kharmata
Date Posted: 15 November 2010 at 12:47pm
Romeo wrote:
Well, I took a reading of the new alternator and it's at 14.7V Maybe the battery will take that? |
Did you measure open circuit...?
Date Posted: 15 November 2010 at 4:09pm
Of course meaning no load on the alternator. It's possible that this alternator isn't charging at all or very little. That might cause it to have a higher than normal voltage for sure.
Good idea Kev.
The only way to know this is to measure the actual charging current. If it's pumping 14.7 volts 30 amps+ into a regular starting battery there won't be much battery left for long.
kharmata wrote:
Did you measure open circuit...? |
Posted By: kharmata
Date Posted: 15 November 2010 at 4:15pm
If you measure it when you first start the car (battery connected) - and perhaps the battery is not fully charged - the voltage will be higher for a short time and as the battery builds up bit more of a voltage drop the volts will drop. If the battery is fully charged and you have this high...hmmm not sure. seems high.
Date Posted: 15 November 2010 at 9:07pm
Was flipping through my old notes about alternators though, and it doesn't seem that unrealistic. As far as I can see, an alternator tries to keep the battery at 14.5-14.7V.
Date Posted: 15 November 2010 at 9:43pm
To me, that's too high a voltage. Over the long term, my opinion is that it will cook.
Start the car and idle. Measure the voltage. Rev up the car slowly to 2500rpm or so. Does the voltage level off, or keep climbing incrementally over the next minute or so?
What does it top out at?
My experience is that the voltage works like this:
1) Before starting, lowest voltage at the battery 2) Start. Idle. voltage is sub 14.2. voltage increases as car is reved indicating increased ability to send current to the battery as the engine speed increases 3) Voltage tops out quickly (On a decent battery) at a max of 14.2 or so. Voltage should not creep. There should be a hard limit on the upper voltage
I found this after looking for a bit. Maybe 14.4 before it gasses...
I've never seen one top out that high though.
Voltages for common usages
These are general voltage ranges for six-cell lead-acid batteries:
- Open-circuit (quiescent) at full charge: 12.6 V to 12.8 V (2.10-2.13V per cell)
- Open-circuit at full discharge: 11.8 V to 12.0 V
- Loaded at full discharge: 10.5 V.
- Continuous-preservation (float) charging: 13.4 V for gelled
electrolyte; 13.5 V for AGM (absorbed glass mat) and 13.8 V for flooded
cells
- All voltages are at 20 °C (68 °F), and must be adjusted -0.022V/°C for temperature changes.
- http://en.wikipedia.org/wiki/Float_voltage" title="Float voltage - Float voltage recommendations vary, according to the manufacturer's recommendation.
- Precise float voltage (±0.05 V) is critical to longevity; insufficient voltage (causes http://en.wikipedia.org/wiki/Sulfation" title="Sulfation - sulfation ) which is almost as detrimental as excessive voltage (causing http://en.wikipedia.org/wiki/Corrosion" title="Corrosion - corrosion and http://en.wikipedia.org/wiki/Electrolyte" title="Electrolyte - electrolyte loss)
- Typical (daily) charging: 14.2 V to 14.5 V (depending on manufacturer's recommendation)
- Equalization charging (for flooded lead acids): 15 V for no more than 2 hours. Battery temperature must be monitored.
- Gassing threshold: 14.4 V
- After full charge, terminal voltage drops quickly to 13.2 V and then slowly to 12.6 V.
