Audio/Battery Question
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2092
Printed Date: 24 April 2025 at 4:01pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Audio/Battery Question
Subject: Audio/Battery Question
Date Posted: 21 September 2010 at 5:31pm
Although my audio system is on hold at the moment (Suspension is more of a pressing concern at the moment, and I just paid for schooling), that doesn't mean I can't prep a battery box in the mean time for a new battery (Pretty sure the current one is cooked, heavy, up high and out back). So for any of our electrical aces, or sound gurus, do you think this would be sufficient as a battery: http://www.kinetikaudio.com/2009/product.asp?P=KHC600&C=1 - http://www.kinetikaudio.com/2009/product.asp?P=KHC600&C= 1
Bare in mind that while I will have a fair bit of audio stuff in the car, I don't intend to be playing it overly loud, and I do have an upgraded alternator to try and keep her juiced. Just basically wondering if that should be sufficient to turn her over in the morning, as the next size up is 26 pounds, it would be nice to save those 8 pounds.
Date Posted: 21 September 2010 at 6:41pm
Why...lol, depends on how much in amps your driving, Cap is good to have, again get a Optima Yellow and you'll be fine
------------- Brian (Bassman)
Posted By: kharmata
Date Posted: 21 September 2010 at 6:46pm
And what about the alternator...?
Date Posted: 21 September 2010 at 6:57pm
Again...what are you running, how much amp's, etc...I play my system LOUD and have a 6 channel JBL at 600 watts...have never even come close to draining.
I know any audiophile will suggest to upgrade the world...Right Zander, Tyler & Waylon...lol
Date Posted: 21 September 2010 at 7:35pm
Get a good Optima a red is good enough, or a yellow is better. I can and have ran my Stereo for over 4hrs straight with amp and sub and am still able to start the car. I can also run a 110v 350w inverter for up to 8hrs powering a Laptop with an external set of speaks with sub. Anything under 750w you won't need more than a good battery and possibly a cap. If you go over 1000w then I would say upgrade to dual batteries and a good cap.
Posted By: Fire451
Date Posted: 21 September 2010 at 8:05pm
i would recommend just getting a yellow top, it will do exactly what you want from it, I have had a red top for years and just reciently upgraded to a yellow top myself.... if you need a cap I have one here that is still brand new in the package and will sell it cheap (unless brian still has/wants dibbs)
Date Posted: 21 September 2010 at 8:10pm
It's not so much the capacitor aspect of the Kinetic that interests me (The subs I have are tiny, and I don't intend to work the sound system at all) so much as the weight. That one I linked to is 600CCA, and weighs just 14 pounds. 14! If you guys don't think it's possible to use it for true battery duty, I suppose I will invest in an Optima instead, but they're a bit heavier, and significantly larger...
Date Posted: 21 September 2010 at 8:13pm
I see a trend..."Optima Yellow Top"
YellowTop Group 75/25 Dual Purpose (Deep Cycle & Starting):
Weight 37.8lbs. Length 9.38inches Height 7.75inches Width 6.81inches
http://shop.optimabatteries.com/products/productdetail/YellowTop+Group+75/25+Dual+Purpose+%28Deep+Cycle+%26+Starting%29/part_number=D75/25/1737.0.1.1.62466.0.0.0.0?pp=8 - Or
INTERSTATE BATTERY MEGA-TRON PLUS - 85 MONTHS - 700 CCA
Weight: |
32.8 |
Width: |
7.25 |
Length: |
9 |
Height: |
7.63 |
Had me thinking Colby...Yellow Top worth the Weight...haha, get it
Date Posted: 21 September 2010 at 9:45pm
Wow nice to see Mr Fire451 posting up, haven't seen you in a while. You and the ladies should come out on the 25th with everyone. 6 Fiero's will be on the track racing.
Date Posted: 21 September 2010 at 9:53pm
Fire451 wrote:
if you need a cap I have one here that is still brand new in the package and will sell it cheap (unless brian still has/wants dibbs) |
Cheers man:)...no need
Date Posted: 21 September 2010 at 9:54pm
Capt Fiero wrote:
Wow nice to see Mr Fire451 posting up, haven't seen you in a while. You and the ladies should come out on the 25th with everyone. 6 Fiero's will be on the track racing. |
Performance driving
Date Posted: 21 September 2010 at 10:19pm
Bah, 32 pounds is still waaay more than the next size up in the Kinetic range, which moves up to 26 pounds. And at 800CCA, I'm sure that model will be more than enough to start my car in the morning.
Date Posted: 21 September 2010 at 11:25pm
Bassman wrote:
Had me thinking Colby...Yellow Top worth the Weight...haha, get it |
No? Do you mean Tristan?
lol, was about to write the same thing.
------------- 88 Formula 5 speed
Date Posted: 22 September 2010 at 6:06am
Date Posted: 22 September 2010 at 7:13am
Both of ya..Tristan's the one looking and Colby advised on spec
Date Posted: 22 September 2010 at 7:40am
lol
Aw, and here I thought you were just ignoring lovely little Tristan.
Date Posted: 22 September 2010 at 5:02pm
Well, I might have to go to the larger 800 model, it's tough to say... The 600 only has a 20A/H rating, which means the alternator will kill itself trying to charge it up in the mornings, and more than a day or two and I wont start up... On the other hand, it's almost 150% the weight of the 600... Decisions, decisions...
Date Posted: 23 September 2010 at 9:53am
Keep in mind with your calcs that music is about 30% duty cycle. Meaning, if you run your 600W flat out, it will only suck about 200W for real (15A).
So it's like leaving your lights on basically.
As far as batteries go, my limited understanding is this:
The tradeoff is between deep cycle and starting amps. A deep cycle has less plate surface area, but thicker plates. The oposite is true for a starting battery...mores surface area but thinner plates (For any given battery package size). The combo batteries are just that, some thin, some thick, or all medium thickness.
Caps help reduce the transient requirements on the power system (Battery and altenator). They are best when mounted really close to the main power device, in this case the pwer amp. This is because of the impedance of longer leads lessens the transient help the cap can give.
It should 'clean up' and base distortion due to lack of supply which can occur in setups with long, small supply wiring to the amp. Another way to look at it is if you buy the big cap, you can tell the guy trying to sell you the 4/0 cable for you amp the big finger, 'cause really you only need #10 (Which will easily pass 30A). This will more than pay for the cap in a longer supply run.
It won't help in your amp-hour energy requirement.
If it was me, I'd stick with the smaller deep cycle battery, and a larger altenator, plus a nice juicy big cap stuck next to the power amp.
1 more thing...if you run this setup, have a really good low impedance ground from the power amp to the head unit. This will prevent ground rise oscillations from occuring.
------------- 86 SE 3.4
Date Posted: 23 September 2010 at 12:15pm
Deep cycle = mega heavy though. And they splash. The reason I was looking at batcaps isn't actually the sound system, but rather the weight of them. They're feathery, even when compared to pricey gel cells.
Date Posted: 23 September 2010 at 1:24pm
Yup they're heavy alright. Cake...eat it....you get the idea.
batcaps? Is this a composite word, or are you looking a super(ultra)capacitors?
Date Posted: 23 September 2010 at 10:25pm
A batcap is quite literally the love child of a battery and a capacitor. Effectively, it ends up leaning far more heavily to capacitor than battery, as they can be made as power as 100 1-farad capacitors (You read that right), while still possessing enough capacity to run the vehicle and start it in the morning. The trade-off, of course, it that unlike a true capacitor, they cannot expel all their energy in one go, and unlike a battery, have pretty poor sustaining qualities (As I mentioned, the one I want is only a 20Amp-Hour reserve. Eighty is usually considered dangerously low, to put that into perspective). Audio guys love them for their ability to throw more juice out on demand than batteries. I love them for the fact they're approximately 1/4 the weight of a lead acid battery, and about 2/3 the weight of a gel cell battery. They're also splash-proof.
Date Posted: 24 September 2010 at 2:33am
You should post up link to a place selling them. Id be interested in reading about them. If I can find the info, there are high output mini gel batteries about the size of a motorcycle battery weigh under 10lbs can be mounted to a firewall in any direction and put out 800ca. Last I checked they were in the $275 range.
Date Posted: 24 September 2010 at 8:51am
I know that device as a super or ultra capacitor. Of course, it may be a bit different, because the ones I was looking at were 20F and above, and could be drained right down. Also, charging time is limited only by thermal characteristics of the unit (In other words, very high current charge) yeilding charge times of less then 5 seconds from a source capable of it.
It's starting to be the solution to wasted brake energy in hybrid vehicles because they can absorb large amounts of charge in small amounts of time (Unlike a nicad/nmh, etc), and they are light as you're said (Weight is the enemy of efficiency in a vehicle).
I was looking at a bank to run my electric bike for 30 minutes at 6A, 30V and it was going to cost $2500. I think you'll run into the same cost prohibitive numbers if you look at the capacity you'd need.
Lets examine a starting situation:
Let's say you want 500A for .5 seconds, then 150A for 2 seconds, and you need the voltage to stay above 12V. Let's assume you charged them to 14.5 volts from the car's system.
cap current = C*dv/dt (D = change in)
rearanging, dv = (dt*i)/c. For the 2 stages, you have to seperate two occurances:
Dv = (dt1*i1)/c+(dt2*i2)/c Where dt1 = .5sec, i1 = 500A, Dt2 = 2sec, i2 = 150
For DV = 2.5V For (14.5V-12V),
so 2.5V = 250/c+300/c, 2.5 = 550/c
c= 220F
500A and 150A may be pretty marginal. I'm not sure what the starter actually draws...
How much is 220F worth for the devices you are talking about?
A couple more things to think about...why not diode isolate the cap unit from the battery, and run the stereo off the caps, rather than try to start with them.
If you run 15A on the stereo, and you had a 200F bank, and you could accept running between 14.5V and 12V it would last:1200 MINUTES.
The only trick would be to control the charge current when you charge them back up. It will max your alt out until they are charged, because they look like a dead short to voltages above what they are charged at.
For example, if the 200F cap was at 12V, the alt would have to pump it max current (Let's say it has 30A extra to charge the caps) for 600 minutes. You could limit this (Which is what i would definately do) with a power resistor. For example, to limit the current charge to 20A, and a max diferential voltage of 4V (Let's say you ran them down to 10.5V) the resistor would be 1/4 ohm. The power is high though, 100W.
The diode would have to deal with this charging current as well, but that can be had no problem.
Date Posted: 24 September 2010 at 9:06am
Loked up the batcap...I don't know how informed the posters are, but it seems to be just a thin film low impedance battery. If so, my guess is it will wear out fast.
Date Posted: 24 September 2010 at 9:12am
Check this out:
http://www.maxwell.com/ultracapacitors/products/medium-cell/bcap0350.asp - http://www.maxwell.com/ultracapacitors/products/medium-cell/ bcap0350.asp
Date Posted: 24 September 2010 at 9:25am
http://www.tecategroup.com/store/index.php?main_page=product_info&cPath=18_20_32&products_id=1220 - http://www.tecategroup.com/store/index.php?main_page=product _info&cPath=18_20_32&products_id=1220
Wow. These came way down in price! These caps are 310F (Huge) and only 2.5V. Series them up and you loose capacitance....
So, 6 caps in series (To acheive the require voltage rating of 15V) yeilds a measly 55F. Then parallel some chains to up the capacitence again, 4 chains will give you 220F. Total cost = $16*6*4 = $384...not too bad.
Date Posted: 24 September 2010 at 9:28am
http://www.tecategroup.com/store/index.php?main_page=product_info&cPath=26_62_66&products_id=112 - http://www.tecategroup.com/store/index.php?main_page=product _info&cPath=26_62_66&products_id=112
Looks like they thought about automotive too. Cost = unknown. 100F box, the size of a big shoebox.
Date Posted: 24 September 2010 at 11:18pm
Only thing is, if I don't go with a batcap, I'll just go straight to battery. My sound system wont be excessive enough that it will require a seperate capacitor, the fact that the batcap had one integrated was just a convenient detail. My main concern with a batcap is that it doesn't hold charge very well. A capacitor is even worse in that regard.
Date Posted: 24 September 2010 at 11:19pm
Oh, and David, the first post of this thread has a link in it. That will take you to the exact model I want, which also has a description of what they are and what they do.
