Rough idle, loss of power
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2136
Printed Date: 17 April 2025 at 11:54pm
Topic: Rough idle, loss of power
Posted By: 2Doped
Subject: Rough idle, loss of power
Date Posted: 19 October 2010 at 7:39pm
My 87 Fiero 2.8 V6 has a problem I can't figure out, I
was hoping someone can point me in the right direction!
I've replaced the ignition module about 3 months ago,
when the tach went crazy and it wouldn't crank. However
this time it does crank but idles really rough, it's not
high but according to the tach its steady at about
1000rpm. The motor would just shake, also driving it -
the car would have no power at all. These problems seemed
to occur after I had an alarm system installed.
Please any suggestions would be great!
Thanks in advance!
Posted By: cam2510
Date Posted: 01 November 2010 at 9:52am
well as i have figured out one minor wiring issue can cause alot of problems...
if everything started after the alarm was installed maybe you should start their!
I played with the stock subwoofer got it installed with an aftermarket deck and somehow it now backfeeds into the interior lights and blows the map lights fuse. I am now in the process of ripping all the wires for the stock subwoofer out as they may have causes a short in another system as they hadn't been used in 10 yrs
Posted By: Kennethrogers
Date Posted: 23 November 2012 at 7:18pm
was hoping someone can point me in the right http://www.niceledlights.com - Peimar led direction!
Thanks in advance!
Wires are not properly attached or bit lose please check them
