Alright here we go, there is about 30 pics to go through. Many of them are of the same thing just from a different angle or quality of shot.
Fist off the "over drill" of the intake, there are 2 holes that went through, however only one did damage to the head.
You will see the 2 holes, just look for the blue gasket goo
Alright here goes.
Underside of Fiero V6 intake, you can see where the bolt holes punched through. There is nearly Zero distance between the bottom of the intake and the head, which made it really difficult to realize that the drill had went into it in the first place.
The real damage "The Head" At the upper right corner of the water jacked you can see where the bit drilled in and destroyed the gasket sealing area.
The 2nd problem is that a combination of both water, steel dust and chips, and Aluminum bits are now coating the enter lifter valley as well as metal chunks in the water jacket. The steel bits for the most part we were able to remove with a magnet, however the aluminum we could not really get out, and obviously the oil mixed with the water was a bit of an issue as now all the bearings would be sitting in a pool of water in the crank case.
This is the lifter valley and push rod area, you can see all the mixed metal, water and other junk, pretty messy job.
We chose to wash it all down with about 2 gallons of diesel to clean most of it and rinse it down to the crank case so it could be safely drained out the bottom.
The Repair, after talking to a few people, they all said for this issue, JB Weld would be the trick, hard as steal and easy to apply. Can handle the temps we needed and should never need attention ever. So I mixed up a batch of JB and started applying it like putty, I went back every 30mins and re shaped it, then after 8hrs of setting up, I took a razor blade and skimmed over the top of it. Giving it a razor smooth finish to the head. Then we waited another 8hrs for it to totally harden up. I still felt there was a tiny bit of a sinked grade, so I used some black RTV as a finishing compound. It worked perfect, the end result, if you moved your hand across the patch it was dead smooth you could not tell where it went from metal to patch and back to metal surface again. I was happy.
Since we had to remove all the push rods I had Tim clean then all up on the wire wheel as well as all the bolts. We then got to work setting the valve train up. I used my personal choice of 1 full turn on used valve train. I got 1.5 turns on new valve train.
Just a quick snaps of Dawg's premium distributor, coupled with Tims MSD Wires, MSD Cap and Rotor and MSD Coil.
We drained out 14 liters of mixed water, oil and diesel out of the car, and put in 4 liters of cheap Lordco branded oil.
Well we got it all together and got it running, it ran amazing well after we sorted out a minor wiring glitch thanks to Dr.Fiero for some over the phone wiring tech support. We ran the engine for about 20 mins to circulate the new oil and allow as much of the crap could not get out, to get sucked into the oil filter, then we drained out the cheap oil (which came out black as black can be) We installed a new Delco filter and filled it up with 5 liters of Penzoil 10w30.
End result. The car runs amazing, better than ever before. We are betting that intake had not been off since the engine was built 25 years ago. Which means the valves had not been adjusted in that long. With everything clean and valves adjusted back to perfect the car is running amazing, better than ever. Runs smoother, more pep and I am guessing it will even give him a few extra mpg as well as MPH on the highway if he boots on it.
