fiero tune up
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=226
Printed Date: 22 April 2025 at 1:42pm
Topic: fiero tune up
Posted By: Guests
Subject: fiero tune up
Date Posted: 05 June 2007 at 12:45am
n e one have an idea of how much a  full tune-up would cost for a 1986 pontiac fiero gt.... i think its in need of service also need to know wat exactly i should just get done to get it serviced properly for a good low rate or jus stuff i shoudl be doin my self thnks
Date Posted: 05 June 2007 at 5:55am
Plugs NGK V-Groove UR5 $15
MSD Wires $100 or cheap ones $50
Cap and Rotor $20 make sure they have BRass contacts
O2 sensor, if you don't know when it was changed last replace it $100
Oil and Filter $30 Castrol GTX 10w30 or 20w50 for high milage motors.
Thats the basics.
Date Posted: 06 June 2007 at 11:01am
If you take it to an aircare certified shop and the O2 sensor is good, the a general tune-up is about $200 nowadays.  The includes 6 plugs, oil and filter and cap and rotor, if required.
The last O2 sensor I bought was $70.  You should also consider changing the gas filter, which is not usually included in tune-ups anymore.  But then my original gas filter that came with my car lasted 10 years before I replaced it.  The filter outlasted the fuel pump but may have been the cause of the pump going.
Posted By: Guests
Date Posted: 06 June 2007 at 3:46pm
o alright thnks guys
Posted By: Guests
Date Posted: 20 September 2007 at 12:10am
its been a while since i got it serviced last time was about wen i started this topic do i only need a oil change cuz i did all of the above listed... or is ther en e thin else?
Posted By: Guests
Date Posted: 10 May 2008 at 12:55am
hey captain. the stuff u listed above? how often should the plugs and wires be changed? and how about the cap. rotor. ignition coil often shudl that be changed?
Date Posted: 16 May 2008 at 4:10pm
Cap and rotor should be changed around 15,000 miles, wires every 30,00 miles, coil, every 50,000 miles or when it goes bad, plugs every 6-10,000 miles. Or every weekend if you are running nitrous. :)
Posted By: Matt
Date Posted: 16 May 2008 at 9:52pm
Heh, show off. You're so proud of yourself aren't you?
I wanna go fast.
Date Posted: 16 May 2008 at 10:24pm
   Na I have not ran nitrous on any of my motors in a fair while. Just saying with the "NOS" generation of new comers, if you do run a small bottle shot on your car, you are gonna need to change plugs very often.
