Speedo plastic gear for ’85
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=227
Printed Date: 22 April 2025 at 11:41am
Topic: Speedo plastic gear for ’85
Posted By: littleV8fiero
Subject: Speedo plastic gear for ’85
Date Posted: 05 June 2007 at 10:11am
Just wondering where I can get another gear for my speedo? The Fiero store doesn't sell them. My friends '86 is not the same. Any ideas please and thanks,
Andy
Date Posted: 05 June 2007 at 5:08pm
The dealer should sell or be able to get them.  This is going to be a more common problem now that our cars are getting older.  Having a good knowledge of trannys and what gears went with what tires, it is sometimes possible to get a gear to make an aftermarket wheel and tire swap read more correctly on the speedometer as well.
Date Posted: 05 June 2007 at 5:29pm
The plastic gear I'm looking for was connected to the little shaft on the sensor. Does anyone know if any years are compatable?
Date Posted: 05 June 2007 at 5:41pm
No one can answer your question without a few more details.
What Year do you have
What Trans Do you have
If a 5spd is it an Isuzu or a Getrag
What colour is your stock gear
Date Posted: 05 June 2007 at 6:15pm
'85, getrag 2.5 5 speed, bought the car without gear, so don't know color. My friends is bright red, it doesn't fit on mine.
Date Posted: 06 June 2007 at 6:29am
There's something else wrong then - as they'll all "fit" - the speedo just won't read correctly!
Each color is just a different tooth count.
Date Posted: 06 June 2007 at 8:13am
oh, got ya. Thanks for the help. So what color gear should I be looking for? I put in my friends sensor with his gear. Haven't test driven it yet. Working on the master cyl, slave and new centerforce clutch.
Date Posted: 18 June 2007 at 3:59pm
Hi, I'm still looking for the plastic gear for my speedo. I don't know the color it was. It's a 2.5L 5 speed tranny. 1985 notchback.
Thanks Andrew
Date Posted: 18 June 2007 at 8:08pm
Unless someone has gone to a great deal of work, all 4cly 5spd cars used an Isuzu trans.  Just go to your local dealer and ask for a new one for your car, or hit up a wreckers and find a 4cly trans and pull one.
Date Posted: 19 June 2007 at 10:33am
I checked the wreckers and called GM, it's discontinued. I even called across Alberta to all the wreckers. No fieros in stock. Any more ideas?
Thanks
Date Posted: 19 June 2007 at 5:42pm
It doesn't NEED to come from a Fiero - All the trannies from almost all GM products are going to use the same sender - just the tooth count is different.
If you check your RPO sheet there will be various codes - one of which will be what the original sender and tranny was.
The trannies are:
MD9 3-speed automatic transmission (THM125C)
MG2 Transmission, manual, 5-speed (Muncie) 3.61 ratio
MG3 Transmission, manual, 5-speed (Muncie)
MM4 Transmission, manual, 4-speed, provisions (84-86)
MM5 Transmission, manual, 5-speed, provisions (85-88)
MT2 5-speed manual transmission (Isuzu) 3.35 ratio
MV9 3 speed automatic transmission (THM200C)
MX1 3 speed automatic transmission
MY7 4-speed manual transmission (Isuzu)
MY8 4-speed manual transmission (Muncie) 3.32 ratio
M17 4-speed manual transmission (Muncie) 3.65 ratio
M19 4-speed manual transmission (Muncie) 4.10 ratio
The senders are: D4N Gear, speedometer driven (N) 29 teeth 10041031 (red)
D4O Gear, speedometer driven (O) 30 teeth 10041032 (purple)
D4P Gear, speedometer driven (P) 30 teeth 25519845 (blue)
D4Q Gear, speedometer driven (Q) 31 teeth 25519846 (white)
