Scan readings
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2280
Printed Date: 24 April 2025 at 11:16pm
Topic: Scan readings
Posted By: mxracer208
Subject: Scan readings
Date Posted: 18 January 2011 at 4:21pm
I used a scan tool on my car today and im not to sure if
these numbers are okay. I know some are bad.
TPS .7
IAC 41
Block 120
Base PW 1.4
MAT 15
MAP 31
MAP V 1.18
EGR 0
EGR vacuum 0
V 14.1
Prom ID 42
IAC position 51
Coolant -39 very bad
Date Posted: 18 January 2011 at 5:40pm
You need more details.
Was the car running at the time?
Was it dead cold?  Just shut off after 15 min's, 4 hrs?
Idling?  Revved up?
(etc etc)
Date Posted: 18 January 2011 at 7:27pm
engine was running, at idle. running for about 10 minutes
Date Posted: 19 January 2011 at 6:11am
They all look 'close' to normal except for the coolant.  That one alone will throw everything for a loop.
It's reading the one that goes sideways, just above the water pump, and below the filler neck.
Date Posted: 19 January 2011 at 10:41am
I know that it's that one, and the car idles really high. It also said code
22 for a low tps sensor
