coilovers
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2287
Printed Date: 24 April 2025 at 11:17pm
Topic: coilovers
Posted By: tk_85redgt
Subject: coilovers
Date Posted: 20 January 2011 at 7:38pm
Has any one seen or herd about these coilovers and how good are they.they look like there are ajustable.are they a good deal or what any thouts.are they worth trying?
http://cgi.ebay.ca/MK1-Coilover-Kit-84-88-Pontiac-Fiero-SE-GT-V6-/380308675277?hash=item588c29dacd - http://cgi.ebay.ca/MK1-Coilover-Kit-84-88-Pontiac-Fiero-SE-G T-V6-/380308675277?hash=item588c29dacd
Posted By: kharmata
Date Posted: 20 January 2011 at 8:59pm
I have a set in red for front and rear. I thought maybe
but not sure I trust that the time and effort would be
worth it.
Actually it's not a very educated assumption since i have
only installed factory struts and springs. They just
seem cheap to me.
Date Posted: 21 January 2011 at 9:05am
Coilovers are always adjustable (Otherwise they arn't coilovers). Haven't tried them myself, but there's articles on the internet to make you own, if that's more your thing.
Posted By: orange
Date Posted: 21 January 2011 at 5:42pm
I have a set of these for my 88 cradle conversion and they
work fine for me, yes i would admit they are cheaply or
should i say efficiently made. They are simple and in my
application required some custom manipulation for a perfect
fit but then again I did a cradle swap so that was
expected. They dont lie when they say the poundage of the
spring, mine were 450lbs/inch and when i put a 220lbs
weight on one it depressed a half inch, so quality shouldnt
be too big of a problem. Id say 7 of 10. Yes they are
adjustable, they have about 3 and a half inches of adjust
ability. I proly wont recommend them, but im not denoting
them either, they are i guess average?
Orange 4.9
Date Posted: 23 January 2011 at 8:38am
I was only going buy them if some 1 had a positive reply on them,the price was cheap.Ajusting your suspension for differnet drive is alway good but only is parts are good.They are cheap thats why i was a little interested in them. we are going to change the struts and adding a sway bar on the back.i was only thinking if i'm changing the struts do new springs these we're cheap,but like my dad said don't really need them.
Date Posted: 23 January 2011 at 12:38pm
My advice? Grab yourself a simulator (Gran Turismo-PS3, Forza Motorsport-Xbox 360, TOCA Race Driver-PC), and find what alignment you need first. Cheap, and easy to do. If you get more time with the sim, and you know what you're doing, play around until you find strut jounce and rebound settings, as well as spring ride height and stiffness, and then apply those to the vehicle.
But as a heads up, when I was finding out what a fairly stock Fiero would be running with my optimum tire set up, it took me two days on Forza Motorsport finding out how to set things up. Any effect made in one area (Such as springs) ripples out and affects the rest of the suspension geometry and set. And also don't forget, what may be very effective between 10 and 60 MPH may not function as well above 60MPH, everything is a compremise.
