April Tech Session - Idler pulley
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2317
Printed Date: 02 July 2025 at 4:42pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: April Tech Session - Idler pulley
Subject: April Tech Session - Idler pulley
Date Posted: 15 February 2011 at 4:52pm
I would like to gauge the interest in the idler pulley part of this tech session. There will be all the regular stuff going on that day too but I'm offering everyone the opportunity to have this useful modification done to their stock V6's.
If you have a stock 2.8L, 3.1L or 3.4L motor in your car this is a great enhancement. It makes your alternator belt function much better and in turn last a lot longer.
This thread outlines what I built for myself:
http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2278 - http://www.westcoastfieros.com/forum/forum_posts.asp?TID=227 8
What I am offering to do is build the bracket you need to mount the pulley itself. Once you have this part you also need to buy a pulley, a bolt and a longer belt. Other than those additional parts, it's a simple bolt on affair.
I will supply the brackets for $30. I will supply everyone with the proper part numbers for the additional goodies needed.
On the day, we all get together and do the modifications. It will be a great time doing something useful to our cars.
Pipe up if you think this would be a fun project.
Date Posted: 15 February 2011 at 4:56pm
Another note about this project.
I've been looking high and low and all I find is the same basic metal idler pulley for about $30 club price at Lordco.
Some have said they've seen cheaper pulleys around. I will eventually need to make a choice. Anyone have a better idea?
Date Posted: 15 February 2011 at 6:06pm
I just checked my car, and I have a nylon idler, however it is on the wrong side of the belt, so it has ribs on it. I also have a metal smooth tensioner on the motor as well on the other side. All the extra pulleys were due to deleting the A/C and Power Steering pumps.
Sorry to get your hopes up, I honestly thought it was a smooth nylon pulley.
Date Posted: 15 February 2011 at 9:09pm
For those who need them, it would be convenient if it turned out that some common GM engine platform used the type/size of pulley required. Then people would have the choice of buying a new one at any auto parts dealer or taking a run to the wreckers.
It would be helpful if anyone knew what pulley Rodney Dickman uses with http://rodneydickman.com/catalog/product_info.php?cPath=22&products_id=71 - his kit .
Date Posted: 15 February 2011 at 10:11pm
I spent over 2 hours poking around the Internet and the Lordco site. They all use the same pulley. There are some different ones but over all I kept finding the same item.
So just about any GM metal idler with a smooth face and a single bearing will work. If it looks like the one in that picture above, it's the right one.
I'll bring the idler in question to the next meeting as soon as I get a confirmed participant.
Then everyone can have a good look at it.
Date Posted: 05 March 2011 at 12:09pm
I'm still looking for one person to commit to having this installed. Any takers? Once I have one person on the list I will go and buy an idler wheel and finalize the generic design.
Tristan, could you send this out to the mailing list?
Cheers,
Date Posted: 08 March 2011 at 7:37pm
Since I would need 3 or 4 people involved in this to make it viable I'm going to declare a deadline for registration.
This is going to be in about a week. So that is Sunday March 13th.
I'm looking at the calender and realizing I need prep time to make this all happen. Next month will be a busy one for me.
Cheers,
Date Posted: 12 March 2011 at 11:49pm
OK, I have my quota. At tonight's meeting, 3 people confirmed interest in the idler project.
So it's a go. I may make one extra for good luck but no more unless I hear from others. Anyone interested get back to me soon.
For those that showed interest, please bring $30 to the next meeting to cover my costs.
As soon as I buy the idler wheel for Jim, who paid me already for his bracket, I will post the part number for this wheel and the longer belt.
Don't forget to use your club discount card!
Cheers,
Posted By: tk_85redgt
Date Posted: 13 March 2011 at 7:32am
I would like the pulley set up.if u post the part #'s and the price before next weekend.i would like to see what they go for in the states see if they are cheaper or not.i'm going down for 2 weeks.thanks Dawg
Date Posted: 13 March 2011 at 4:10pm
Here's the idler wheel # Tino:
AC Delco 38006
GM# 88909587
It ends up that this wheel is indeed 3" in diameter. My wheel was 2.5" in diameter. So now I'm not sure about the belt since the one I used was tight already.
I will have to adapt one way or another. So I'm not going to decide on the belt just yet.
Also, it looks like the bolt needed is 17mm! Wow, big. It might be hard to find. So I'm going to buy a box of them.
I'll adjust the bracket price to compensate.
Date Posted: 18 March 2011 at 2:20pm
Update:
I've decided to simply fabricate a custom shoulder bolt for this project. As suspected, 17mm bolts are not common.
So I bought a bunch of long shoulder bolts which I will modify for our purposes. So the fee is now $35 and obviously includes the bolt now.
Here's some pics:
This is what the wheel looks like:
Once I finish the new design I will shorten and thread the bolts to their final size. This should be a very clean install.
Posted By: kharmata
Date Posted: 18 March 2011 at 9:32pm
Nice light weight ilder!
------------- Kevin
08GSXR1000
Date Posted: 18 March 2011 at 9:38pm
I think you will find that you need to put a few washers behind the pulley or it will rub on the back side. (Found this from experience on my 4.9)
Date Posted: 19 March 2011 at 12:12am
You're right Dave. There needs to be a stand off or the pulley will rub. I'm making a one piece shaft that will be part of the bracket.
Date Posted: 21 March 2011 at 9:47pm
Had some time today to work on the idler project. Here's the shoulder bolt and the stand off it will screw into.
Tomorrow I'm going to try and get the bracket done. Then it's off to Dave's to dry fit it to the spare motor he has there. If all goes well, I'll then start making the rest of them.
Date Posted: 22 March 2011 at 6:38pm
Ok, first new group install bracket is done my friends! If Dave is free tomorrow I'll trial fit it.
Neat and tidy I think. Thicker material than my original. Longer slotted holes. Should be great!
Date Posted: 23 March 2011 at 3:21pm
OK. I've got all the info I need to complete the final design. I was over at Dave's today and had a chance to do a trial fit. You will notice that the wheel is sticking out a little too much. So I'm going to shorten the post to compensate. And the slots I cut are wider than they need to be so 1/2" it is.
Other than those two minor changes it's all good. As you can see, the alternator adjustment is about half range. We're good!
This weekend I should have all 4 done.
Just a note. The 4th one is a spare. If anyone else wants in let me know.
Posted By: Nexus
Date Posted: 24 March 2011 at 5:03am
Nice and clean!!
Looks good
------------- Charlie
84 SE
Date Posted: 24 March 2011 at 8:35pm
I'm seeing the end coming soon......:)
Why don't I wrap this up with the final part numbers so you guys can go and buy your parts.
As mentioned earlier, I'm providing the bracket and bolt for $35. Please have this for me at the next meeting.
The idler wheel (pulley) is a generic GM part:
GM# 88909587
AC Delco# 38006
The belt I bought:
AC Delco# 5K459 (17mm X 1179mm)
Cheers,
Date Posted: 31 March 2011 at 9:54pm
All painted and ready for the tech session.
Cheers,
Date Posted: 03 April 2011 at 7:33am
Nice work Dawg they look very nice.Got home late last night, 2 cold here but nice to be home.Let las vagas at temp of 31.did not get a chance to see if the parts where cheaper.
Date Posted: 06 April 2011 at 1:14pm
Thanks Tino.
See you at the meeting.
Date Posted: 06 April 2011 at 5:27pm
Hi Dawg are u going to bring the brackets to the meet?thanks Tino
Date Posted: 06 April 2011 at 10:52pm
I sure am.
Date Posted: 09 April 2011 at 11:12pm
It looks like everyone got their brackets tonight at the meeting except for one person. Glen you need to get a hold of me.
I also sold the last bracket to Tim.
See you all at the Tech Session.
Date Posted: 21 April 2011 at 10:41am
OK everyone, here's a reminder that the tech session is this Saturday at Dave's place. We will be aiming for a 10:00AM start (right Dave?). Everyone is welcome of course, this is not just about the idler project.
Bring any tools you might have and lets get some work done. The weather is improving every day. Soon it will be cruising friendly till 10 at night again. Lets get our cars ready for it.
See you all there!
Date Posted: 21 April 2011 at 8:49pm
Hi Dawg do we need any bolts to mount the braket?
Date Posted: 21 April 2011 at 8:50pm
Address is 16908 104th Ave. Surrey B.C. 10am is fine for a start time.
Date Posted: 22 April 2011 at 12:40am
Nope....it was designed to use existing alternator bolts. Fits right in there no problem.
Dave, if you have any way of getting a hold of Glen to remind him to show up that would be great.
tk_85redgt wrote:
Hi Dawg do we need any bolts to mount the braket? |
Date Posted: 22 April 2011 at 4:28pm
Will be sending out the reminder email in just a sec. For those of you reading, remember, it's tomorrow at 10am-whenever. Would love to be able to toss in the suspension Harrison so graciously provided me if I have the time, but I'll have to see, as I have Hockey at 4pm.
Posted By: 86_Fiero
Date Posted: 22 April 2011 at 6:56pm
Are these gatherings on the mainland or the island? Both?
Posted By: 86_Fiero
Date Posted: 22 April 2011 at 6:57pm
BTW I'm very impressed with those idler pulley's. Wouldn't mind getting my hands on one.
Date Posted: 22 April 2011 at 7:15pm
Capt Fiero wrote:
Address is 16908 104th Ave. Surrey B.C. 10am is fine for a start time. |
Date Posted: 22 April 2011 at 7:17pm
Oh and as to the Island vs Mainland stuff, I have tried more times that I can count to get someone on the island to orginize things over there and no one really has stepped up or been able to. So as of now, all official club events are mainland only.
Posted By: 86_Fiero
Date Posted: 22 April 2011 at 8:56pm
Well that's a problem I'll have to rectify in the near future. The pain in the ass part is the ferry though that's the thing that will probably deter most mainland people from coming and vice versa the islanders going to the mainland. I've tried to organize an island group but everyone is concerned with having to travel to the meets and bla bla. It's really annoying. I've tried I think 4 times and it's failed every time so I've given up. Well I'm off for a weekend of Easter dinner and drinking so I will check back Tuesday. Cheers guys. Wish I could come to the meet and show off my ride. He's torn apart right now. Doing a motor swap and interior refinish.
Date Posted: 22 April 2011 at 10:06pm
Thanks Cody.
Well as chance would have it, Glen has not picked his up. So I have an extra. If he ends up being a no show tomorrow it's yours.
Keep in mind that I only did this as a club event. Once they're gone they're gone.
Rodney Dickman sells a kit. He's got a web site.
86_Fiero wrote:
BTW I'm very impressed with those idler pulley's. Wouldn't mind getting my hands on one. |
Date Posted: 23 April 2011 at 7:18am
Have fun all as I make my way into work
------------- Brian (Bassman)
Date Posted: 23 April 2011 at 4:51pm
Tech session wrap up:
Tino and Tim got their idlers installed without too much trouble. The fit was perfect. Tristan showed up with a set of rear struts to install. Kevin and Dave helped him with that.
Later we noticed that Tinos rear tires were badly toed out. It was decided that we couldn't make it any worse. We managed to get them toed in close enough. A lower control arm needs new bushings before more can be done.
The weather was fantastic. It was great to see everyone.
Thanks to Dave for use of his shop!
ps. I have the last bracket available for sale. PM me if interested.
Date Posted: 23 April 2011 at 10:38pm
Today was awesome (Despite us not winning our Hockey tournement after...)
Thanks again to David and Kevin, you really helped me out. Next up: Alignment & Tires.
Posted By: kharmata
Date Posted: 24 April 2011 at 9:01am
Wonderful day! Who said you can't still have fun without a fiero . Damiens Idlers looked great and fit perfect. I only noticed a slight alignment issue inline with the belts but the bracket can easily be twisted to correct. I love/hate how I can always see imperfection with my eye.
Still can't believe those alignment professionals left the rear of Tino's car in such a horrible 1" toe out condition. When you think about it, where we measured was 1" but if we could actually get the tape measure to the very front and very rear of the tires - I am sure - would have been worse than that. Must have been like dragging an anchor while driving.
After all that playing around, just made me miss my car even more. Good times. Thanks to Tristan for taking me to grab that bottle of NOs
Cheers!
------------- Kevin
08GSXR1000
Date Posted: 24 April 2011 at 10:31am
Had a great time at the teck session.I'd like to thank every 1 that help with my car THANK YOU.Went to look at the 95 Bonneville with the 3800 supercharger,car is in great shape.But could not get it started do to dead battery,hope to go there today and try again with some jumper cables.let u know what happens.
Tino
Date Posted: 24 April 2011 at 11:38am
Hey Tino. How did the car handle on the way home? Did you notice anything significant?
And you're welcome. You've got a nice car there. I can't wait to see it all finished up one day.
Date Posted: 24 April 2011 at 12:48pm
Way better,when we change the ball joint that should fix all of it i hope.thanks Tino
Date Posted: 24 April 2011 at 12:52pm
Went to look at the bonneville again got it started but the supercharger had a grinding noise in it and 1 of the rear brakes was lock and would not brake lose.So we are going to poss on it not sure how much it would cost to fix the supercharger.
Date Posted: 24 April 2011 at 9:35pm
Date Posted: 24 April 2011 at 11:20pm
Wow, my tires look abhorrent in those pictures. lol
...But Gretchin still looks foxy as hell.
