Tech Session Check List-Work Sheet
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2326
Printed Date: 04 July 2025 at 8:16am
Topic: Tech Session Check List-Work Sheet
Subject: Tech Session Check List-Work Sheet
Date Posted: 20 February 2011 at 12:50pm
I've been thinking about this for a while now.  Our cars aren't getting any newer.  Lets face it, we need to treat them well or they will bite us again and again.  Most of us it seems just drive and drive till something breaks or starts acting up.  Then it's panic stations.
How about a well thought out tech session work sheet.  Lots of tick boxes and room on the bottom to write details, just like you would find at the repair shop.
-- Tristan, you could help by sending me some actual shop examples you've used in the field --
If we put our heads together, we could list all the likely Fiero issues.  This would be a Fiero specific check list.
Here's my vision.  We show up to a tech session and everyone gets their car checked out.  As a group we take each car and go through the check list.  Maybe we put the car up on stands, take all four wheels off and start going through the list.  If something is found it gets written down.  Then drop the car and roll the next one up.  On and on till every car has been looked at.
If there is some time left, maybe we start fixing stuff.  If not, then at least the owner knows what he or she needs to do.
If we get to the point where everyone has their sheets filled out.  Then the tech sessions can concentrate on repairs.  This in my opinion is what a car club if for.  Working on our cars together.  Enjoying our cars together.
I am willing to do the design work for the actual form but I will need lots of input from the group.  This could end up being quite the list.
Send me ideas and I will tabulate them.
Date Posted: 20 February 2011 at 3:09pm
Door handles...my drivers is ready to fall off...lol
Date Posted: 21 February 2011 at 5:34am
This is a list that I think was a BCAA type check list when buying a used car:
BODY
1.    Body/sheet metal damage
2.    Frame/Cross member
3.    Paint
4.    Chrome/mouldings
5.    Upholstery/interior trim
6.    Safety belts
7.    Glass/Windshield
8.    Door stays
9.    Door locks/latches
10. Hood locks/latches
11. Trunk lock/latches
12. Tailgate (p/u)
13. Van
14. Motorhome
15. Bumpers
16. Body rust
BRAKES
17. Drums
18. Rotors
19. Wheel cylinder leakage
20. Calipers
21. Flex hoses
22. Fluid leaks/level
23. Power assist
24. Emergency brake operation
25. Brake pedal reserve
26. Lining remaining:
COOLING SYSTEM
27. Radiator
28. Upper hose
29. Lower hose
30. Heater hose(s)
31. Bypass hose
32. Frost plug(s)
33. Fan/shroud
34. Water pump
35. Coolant level
36. Coolant condition
37. Anti-freeze protection
38. Pressure cap
39. Expansion tank
40. Pressure test level
DRIVE LINE
41. Trans. Road test
42. Shift indicator
43. Shift linkage
44. Trans. Mount
45. Clutch operation/adjustment
46. Auto fluid level/cond.
47. Cooler lines
48. Drive shaft(s)
49. U-Joints
50. CV joints/boots
51. Rear axle noise/bearings
52. Seals/gaskets
ELEC. SYSTEM
53. Battery cond./level
54. Terminals/hold downs
55. Wiring/cables
56. Instruments/switches
57. Horn
58. Headlights/lenses
59. Tail/park lights/lenses
60. Stop lights/lenses
61. License plate lights
62. Back-up lights/lenses
63. Turn signals
64. Emergency flashers
65. Marker lights/lenses
66. Starter operation/solenoid
67. Charging system
68. Charging voltage
69. Wiper/washer cond.
70. Heater motor/defroster
71. Ignition system
72. Accessories
73. Neutral safety switch
74. Mirrors
ENGINE
75. Cylinder power balance
76. Engine mounts
77. Engine noise
78. Valve train noise
79. Valve covers
80. Cyl. Head area (external)
81. Intake manifold
82. Exhaust manifolds
83. Timing cover/frt seal area
84. Rear seal area
85. Oil pan/plug
86. Belts
87. Pulleys/brackets
88. Oil filter
89. Oil level/condition
90. Oil pressure sender
91. Emission control devices
FRONT SUSP. & STEERING
92. Stabilizer Bushings/links
93. Control arms/bushings
94. Lower ball joints
95. Upper balls joints
96. King pin bushings
97. Idler arm
98. Pitman arm
99. Tie rod ends
100. Center link
101. Steering box
102. Rack & Pinion assy
103. Steering shaft/joint(s)
104. P/S Pump/reservoir
105. P/S Operation
106. P/S hoses/fittings
107. Springs/shackles
108. Torsion bars
109. McPherson struts
110. Shock absorbers/bushings
111. Wheel bearings
112. Alignment (visual only)
REAR SUSP.
113. Springs/shackles
114. Torsion bars
115. Mountings
116. Control arms/bushings
117. Stabilizer bushings
118. McPherson struts
119. Shock absorber/bushings
120. Axle housing/mounts
121. Oil plug/seal
122. Wheel bearings
123. Hubs/seals/gaskets
FUEL & EXH. SYS.
124. Accelerator pedal
125. Carburetor
126. Fuel injection
127. Linkages/controls
128. Air cleaner/filter
129. Pre-heat/fresh air ducting
130. Fuel lines
131. Fuel pump
132. Gas tank
133. Seals/gaskets
134. Exhaust pipe
135. Muffler
136. Resonator
137. Catalytic converter
138. Tail pipe
139. Hangers/clamps
140. Exhaust system noise
WHEELS & TIRES
141. Tire tread remaining
142. R/frt %
143. L/frt %
144. R/rear %
145. L/rear %
146. Spare
147. Wheel rims
148. Lug nuts/bolts
149. Wheel covers
150. Odometer reading ________ ML’s/KM
Posted By: Boxin' Robin
Date Posted: 21 February 2011 at 6:18pm
Great suggestion, Damien!! It will be awesome if we can make this
happen!!
Date Posted: 21 February 2011 at 9:58pm
Ok....here's another one.
How many Fieros out there are still totally stock?  Less and less as the years go by.  Wouldn't it be cool to have a car journal?  Basically it would be a list of non standard modifications that have been made along with where the parts came from.
Caliper from this car and it's part number.  Idler from here and the number for the longer belt.  Larger oil filter number.
Get the idea?  Never mind an engine swap, holy crap.
Then if some poor bugger buys your car, he's not totally lost.  Some of the Fiero's bad reputation in mechanical shops is this very thing.  The poor mechanic has to try and figure out where the goodies came from.
What do you guys think?
Date Posted: 22 February 2011 at 11:04am
Ok....here's another one.How many Fieros out there are still totally stock?  ...Wouldn't it be cool to have a car journal?
Mine is still totally stock. I also have all service receipts from day 1, including work done by our own Dr. I also have my original order confirmation.
There is so much there that, frankly, a buyer probably couldn't be bothered so sort through all of it.
But I guess it could look good at car shows.
