megasquirt
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2471
Printed Date: 25 April 2025 at 10:07am
Topic: megasquirt
Posted By: orange
Subject: megasquirt
Date Posted: 21 May 2011 at 8:33pm
i see no one liked my itb idea on my 4.9 so ill bring up the next part,
megasquirt. I know someone has done megasquirt on a 4.9 but i want to
know more about it and what you have to do. I know little about it.
Orange 4.9
Date Posted: 21 May 2011 at 9:40pm
Send a PM to Dr.Fiero he built a mega-squirt system for a Turbo V6 Fiero.  Although it worked, I think he eventually gave up on it and went back to the stock ECM with a modified chip, then installed an ignition box that had boost retard and added a rising rate fuel pressure regulator.
         The Mega Squirt idea is cool, but in most cases way over the top for what anyone needs.  The OEM computers on GM cars are actually fairly well designed. The most that is needed is to upgrade to a newer model ECM.  In the case of the Fiero V6 just going to the 7730 ECM is a huge improvement.
      As to the 4.9 I have a stock ECM with a heavily modified chip that works amazingly well.
Posted By: orange
Date Posted: 23 May 2011 at 3:49pm
Would the 161 something ecm (cant remember what it was) run itbs? is it
that tunable?
Orange 4.9
Date Posted: 25 May 2011 at 4:34pm
itb? Injected throttle body???
If so, I'd use the ecm from a 93-95 chev truck. They are very hacked at 3rd gen camaros, as some camaros shared the ecm.
I like megasquirt, but the gmecms are VERY reliable, proven etc. You just need a few more tools, like an ostrich (moates.com) to tune them, or a prom burner, etc.
If I didn't have the prom burner already there's no question I'd have done megasquirt. I'd only do it for a radical engine change though, like turbo, new style manifold etc, not just to tweak a standard engine.
Posted By: orange
Date Posted: 25 May 2011 at 10:14pm
ITB's being individual throttle bodies. So 8 throttle bodies, one for each
cylinder.
Orange 4.9
Date Posted: 25 May 2011 at 10:34pm
AWESOME. That's like an F1 car's induction then.
Date Posted: 25 May 2011 at 10:36pm
Oops. I hit sent instead of enter. Anyways, if you can get a TPS and MAF signal from one, it should logically apply to every cylinder. You wouldn't need a special system for it.
Posted By: orange
Date Posted: 26 May 2011 at 10:24pm
No i would not need anything special (Megasquirt) if i could get the volume
of each port from valve to throttle blades the same as stock, otherwise there
would be more or less air to suck at idle and it would run lean or rich. At
least thats what i understand.
Orange 4.9
Date Posted: 26 May 2011 at 11:00pm
Will the O2 not pick up the mixture and adjust fuel trim accordingly?
Date Posted: 27 May 2011 at 8:48am
I think you are headed for trouble. I guess the idea behind single stack is to increase the flow. The tradeoff is that you don't have a plenum to moderate the flow changes. In other words, I think accel enrichment will be very tricky to program.
1) You will still need a single iac valve for the engine. If you try to adjust each throttle valve for idle (IE: Crack them a bit) you will have a bitch of a time tuning them, linkages etc. I had a three carb mercury outboard once and I think tuning a piano would be easier. If you have multiple iac's they very easily could end up fighting each other.
2) Unless you have individual metering (IE: 8 megasquirt systems) I don't see the advantage, except for better flow of course. Each cylinder will be individual. I would guess the F1's use individual tuning to maximize each cylinder.
It may work. It will be a lot of work.
Date Posted: 28 May 2011 at 1:45am
F1 cars pretty much run a TBI set-up per cylinder, yes. However, it isn't necessary to tune uniquely. If the engine needs RPM, it will crack all IAC valves, as they're all part of the same system. Assuming the engine isn't in such poor mechanical condition that there's large discrepancies between cylinders, the system works no differently than a sequential injection engine.
Date Posted: 28 May 2011 at 4:21pm
I guess this is an idea to get around a high rpm restricitive intake? I remember the 4.x guys like the Allante intake, but singles would likely be better for top end. The bottom end may suffer a bit, but I've read it has lots there anyway.
It may be worth the while then.
If the iac's are per cylinder, and small it should work. If they are all the size of the stock size, it will be like moving 8 steps at once. Also, there is the question whether the megasquirt iac driver circuits can handle the low impedance of 8 parallel IACs.
It's not necessary to tune uniqely, but it would give you the max advantage, that's all I'm saying.
I still think getting the linkages to work might be a bit of a nightmare. I had a hard enought time synching 2 tb's.
Posted By: orange
Date Posted: 28 May 2011 at 11:21pm
http://www.youtube.com/watch?v=BZHCTBkcNsM
like this
edit by capt
http://www.youtube.com/watch?v=BZHCTBkcNsM - http://www.youtube.com/watch?v=BZHCTBkcNsM
Orange 4.9
Date Posted: 29 May 2011 at 8:08am
Why not just add a tube under each plate, all coming back to a common point.  Then have a valve that feeds to open air.  The valve of course being your IAC stepper motor.
Problem solved.
Posted By: orange
Date Posted: 29 May 2011 at 9:05am
I think his plan was to do that with the vacuum line he pointed out.
Orange 4.9
Date Posted: 29 May 2011 at 9:29pm
Problem solved.
...My goodness. It's so crazy it just might work!
I am humbled at how simple a solution that is.
Posted By: orange
Date Posted: 30 May 2011 at 9:48am
The original 4.9 ISC might work too, if you saw in the video of the ls2 all the
throttle bodies were connected at a common point in the middle, where the
swiveled on a circular plate. You could just connect the ISC to that and it
would crack the throttle blades accordingly.
Orange 4.9
Date Posted: 30 May 2011 at 11:02am
In all honesty, I never even looked at the video.
Still think getting 8 vac lines to self balance would be easier than
getting 8 linkages all to move at the same level. But.... To each their
own.
Posted By: orange
Date Posted: 30 May 2011 at 6:47pm
Watch the video and it will explain, its how most itb v8s are set up
Orange 4.9
Posted By: orange
Date Posted: 01 June 2011 at 9:33pm
Just scored a free 4.9 and free intake manifold, fabrication thoughts will start
soon.
Orange 4.9
